    Saving Baby stepping value
    Firmware wishlist
    12
    34
    5.9k
      deckingman @jckray
      @jckray said in Saving Baby stepping value:
      @deckingman Oh for sure, something about the way you were responding made me think you might work with/for David.
      Yes, he has been great about responding to my post in the past!
      I'm just an early adopter who had one of the first boards and who has been keeping the firmware up to date ever since. So I know the history of the firmware and the reasons why things were added or changed but that's all. Apologies if my post made you think otherwise.
      jckrayundefined 1 Reply Last reply Reply Quote 0
      • jckrayundefined
        jckray @deckingman
        @deckingman No worries! I appreciate your input/willingness to help.
        John
        Founder of Hydra Research LLC, developers of the open-source 3D printers and providers of 3D printing services.
        https://www.hydraresearch3d.com/
          deckingman @jckray
          @jckray Actually, something like what you are asking may already exist with mesh bed compensation. I don't use it myself so can't say for sure.
            Phaedrux Moderator @deckingman
            @deckingman Mesh compensation saves the topography of the bed and adjusts for it to keep z=0 consistent across the bed surface. Baby stepping is just another offset applied in addition.
            I think the best way to achieve what you're after might be a macro that could automate measuring the Z probe offset with G30 S-1 after a nozzle change and saving it to the config-override.g. I believe M500 already saves changes to G31 probe offset values. https://duet3d.dozuki.com/Wiki/GCode#Section_M500_Store_parameters
            So it may already be possible, though I don't normally use M500, so I'm not really sure.
            The bonus for this is that Z=0 is still Z=0 and any baby stepping applied after is still applied to that absolute value, which is more consistent. If you were to use baby stepping to set your new Z=0 it would actually be Z=0.2 or whatever for the nozzle to be touching the bed, which could be a bit confusing I think.
            Also, i'm not sure how relying on baby stepping would affect other processes like generating a new mesh grid. The real solution is to use G31 to set the real nozzle offset. Baby stepping is intended to be a minor temporary adjustment, using it as a cludge to set the Z offset permanently is just asking for unintended consequences down the road.
            dc42undefined jckrayundefined 2 Replies Last reply Reply Quote 0
              dc42 administrators @Phaedrux
              @phaedrux said in Saving Baby stepping value:
              In later firmware versions the G31 parameters are not written to config-override.g unless you use M500 P31 instead of just M500.
              • jckrayundefined
                jckray
                Is there a way for the user the set the z offset from the panel? If not would it be possible to add such a feature in the future?
                John
                • jckrayundefined
                  jckray @Phaedrux
                  G30 S-1
                  So I got around to taking a closer look at this, from what I can tell this would work if the z probe was attached to the removable cartridges and was a fixed distance from the tip of the nozzle.
                  However, the z probe is attached to the tool head gantry and the tool cartridges mount to this gantry. I want to be able to have the user change the z value in the following line from the panel.
                  G31 P500 X-25 Y25 Z.9
                  Basically, I want the "live Z-adjust" feature from the Prusa mk2/mk3. This way the user can print a calibration file and adjust the z-offset until a desirable first layer is reached. This z-offset would then be saved until the user changed again. The distance between the nozzle and the z probe trigger height will likely change by 25-200um between tool cartridges.
                  I hope I am explaining what I mean in a clear enough way. I attached a couple pictures of my set up to hopefully make what I'm trying to do more clear.
                  ![alt text](2_1539468040878_IMG_0223.jpg 1_1539468040878_IMG_0222.jpg 0_1539468040878_IMG_0221.jpg image url)
                  John
                    Phaedrux Moderator @jckray
                    @jckray Perhaps M500 could be modified to save the M290 babystepping value to config-override.g so it could be automatically applied at startup.
                    Then you could just have a test print macro with an M291 S3 at the end asking if you'd like to save the current Z offset permanently.
                    • jckrayundefined
                      jckray @Phaedrux
                      @phaedrux yes something along those lines is what I'm looking for
                      John
                        Suppose I add an option on the M290 command to shift the current babystep offset into the G31 Z parameter, clear babystepping and adjust the Z=0 position to compensate? Then you could set up a macro to run that command and then send M501 P31 to write the new G31 command to config-override.g.
                        • TheLightSpeedundefined
                          TheLightSpeed
                          David did you ever implement this? This is my biggest issue with Duet. Prusa allows you to fine tune the Z Offset OT Babystep, then it stays until you change it again. In later firmware Prusa has managed to make profiles so depending on the filament you’re using you can have different offsets. Pretty clever that a Marlin function works so good when Duet requires you to adjust baby stepping every single print.
                          M911 ah crap... wipe, and start over.
                          Arlandundefined 1 Reply Last reply Reply Quote 0
                          • Arlandundefined
                            Arland @TheLightSpeed
                            @TheLightSpeed said in Saving Baby stepping value:
                            Seconding this - really would be great to have this feature.
                              Phaedrux Moderator @Arland
                              @Arland @TheLightSpeed
                              You can already achieve this either per print or per filament with the start gcode or filaments gcode sections in PrusaSlicer.
                              If you want it to be per print, add M290 R0 Z0.05 ; set to absolute babystep height to the start gcode section after the printer has been homed. When you want to change it, edit the start gcode.
                              To then add a modification per filament, add another baby stepping command to the filaments gcode section which is applied after the printer start gcode, so you can now modify it for that filament. M290 R1 Z-0.02 ; modify baby stepping height by -0.02mm
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_M290_Baby_stepping
                              com3undefined 1 Reply Last reply Reply Quote 0
                              • com3undefined
                                com3 @Phaedrux
                                @phaedrux I really need to say that the reulctancy to implement this feature properly is really bugging me. The solution you are proposing is none because you still need to fuzz with the start Gcode and/or G31 to get a very very basic thing done. I mean seriously why the hesitancy to add a simple "save offset button" to the interface? (It could then write it as whatever gcode, doesn´t matter) but adding an offset to every print, or fuzzing with start g-code just to set this very simple value is a total nogo for productive use with several operators. I love Duet but it´s things like this which make me think of switching.
                                This feature has been requested so many times over the years and each time someone ends the discussion with use this or that g-code as if it would be the same OP, me and many others were askingfor, but it´s just not.
                                deckingmanundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                  deckingman @com3
                                  @com3 said in Saving Baby stepping value:
                                  As an end user (not affiliated with Duet in any way), perhaps the reason it has not been implemented in the way that you personally would like to see, is because it would cause all sorts of problems for other users with different machine configurations to you (e.g. tool changers, idex, or other designs which have multiple tools). In such instances, using baby stepping and then saving that offset as a "global" setting would screw things up for the other tools. So then we need to save the offset on a per tool basis (which we can already do by other means).
                                  The duet hardware and firmware strives to be all things to all users, unlike say the Prusa ecosystem which can be "tuned" to a particular machine configuration. On the one hand, some users scream for features and flexibility, while on the other hand, users scream for less complexity and simpler ways of doing what they want. Whilst I'm not one to defend the Duet team when I think they need their feet holding to the fire, I do have some sympathy in situation like this where they are being required to satisfy all of the users, all of the time.
                                  • com3undefined
                                    com3 @deckingman
                                    @deckingman I understand that but anyone who uses their Duet for 3D Printing (which should be like 95% right?) would profit from this very simple feature every single day of usage.
                                    • fcwiltundefined
                                      fcwilt @com3
                                      For me that is simply not true.
                                      If you find that you would benefit from a persistent baby-step setting it seems likely to me that something is wrong with your printer, your setup or the way you are using your printer.
                                      The only time I need to use baby-stepping (don't like that name) is when I am trying to rush a print and heat related changes have not stabilized.
                                      If I were to find that I needed to use baby-stepping most of the time I would suspect that something has affected by my Z probe readings and I would look for a problem there.
                                      • com3undefined
                                        com3 @fcwilt
                                        @fcwilt Every. Single. Time. someone asks here for a useful solution someone comes along and washes it away by saying the printer is trash.
                                        "The only time I need to use baby-stepping (don't like that name) is when I am trying to rush a print and heat related changes have not stabilized."
                                        That is great for you but I am printing 24/7 with eight toolchanging printer resulting in 32 Extruders which I need to set up and calibrate. I know this is an extreme but it really is a problem (especially after nozzle change) literally any other firmware has a simple solution for. But with duet it is not possible? Come on.
                                        I will try to hack it toghether as a macro and will share it here if it works.
                                        • fcwiltundefined
                                          fcwilt @com3
                                          Nobody said your printer was trash. I merely mentioned areas that I would investigate.
                                          There are relatively simple solutions but persisting baby-stepping is the wrong way to go.
                                          I can think of two off the top of my head. The firmware already has adjustments for different tool characteristics via G10.
                                          • com3undefined
                                            com3
                                            @fcwilt The biggest problem is the first tool which all the other offsets are applied relatively to. It would just be soooooo easy saving that damn zero point instead of fuzzing around with g-code. Just start a print, check if it´s fine, adjust it if not, save and forget it. And other people think the same about it:
                                            https://forum.duet3d.com/topic/16328/baby-stepping-can-it-or-can-it-not-be-permanent
                                            https://forum.duet3d.com/topic/1226/baby-steps-z-offset
                                            https://www.reddit.com/r/ender3/comments/a4sx14/how_to_save_babystepping_z_values/
                                            https://reprap.org/forum/read.php?415,879905
                                            Also Klipper, Marlin and Repetier offer that feature since years. But as I said, i´ll try to script it.
                                            jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
