    TB6600 external drives
    3.7k
    • namlecncundefined
      namlecnc
      I found a thread on here about this but it was left hanging. I’m driving nema23 from the expansion breakout board but haven’t got the movement. Should I use level shifter to get 3.3V to 5V? Does anyone have the wiring? The nema23 is 425oz.in
        1. You will need to use a T parameter in your M569 commands for the external drivers. The TB6600 datasheet gives the minimum step high and step low times as 2.2us, but surprisingly it doesn't give the setup and hold times for the direction signal. I suggest you use either T2.2 or T2.2:2.2:2.2:2.2 (these both do the same).
        2. Most external stepper drivers are happy with the signals provided by the expansion breakout board. However, if your driver really needs the full 5V, you can get that by connecting the + inputs (step, dir and enable) of the driver to +5V instead of to the + outputs on the breakout board. You can pick up +5V from the centre pin of either of the servo connectors on the breakout board.
        namlecncundefined 1 Reply Last reply Reply Quote 0
        • namlecncundefined
          namlecnc
          For example:
          M569 P1 S1 T2.2
          Or M569 P1 S1 T2.2:2.2:2.2:2.2 would be the same?
          What is the “:” For?
          • namlecncundefined
            namlecnc @namlecnc
            I’m using this one
            https://duet3d.dozuki.com/Wiki/Expansion_breakout_board
            Can you help me point out the pin? I’m a noob in electronics
            • namlecncundefined
              namlecnc
              And all drive can share that +5V ( extra bed heater)? I was thinking that signal is from + pins because some ppl jump all GRound together.
              • namlecncundefined
                namlecnc @dc42
                @dc42 is this like jumping all + signals together? How does that work since the signal would be sent to all grnd?
                  Connect all the + wires to the external drivers together, and connect then to +5V which you can get from the centre pin of either of the 3-pin servo connectors. Leave the + output pins on the expansion breakout board not connected.
                  • namlecncundefined
                    namlecnc @dc42
                    So all + of the 4 drives ( 5678 ) bundle together to the 5+v? The -(stp,dir,ena) stay where they are? Do i leave all 6 wires connected to the tb6600?
                    Will a 3.3v to 5v bi directional level shifter help in this situation?
                    With this Wiring, can I send signals from 1 drive ( on expansion board ) to 4 external drivers ( trying to run 4 Zs at once )
                      @namlecnc said in TB6600 external drives:
                      Yes. That will give you 5V drive to the external drivers.
                      • namlecncundefined
                        namlecnc @dc42
                        Do I need to enable anything? I still don’t get motion on homing of x y z on this external driver.
                          I didn't expect changing the wiring between the breakout board and the external drivers to change anything, because external drivers are normally happy with the standard signals provided by the breakout board.
                          Did you remap the XYZ axes to the external drivers using M584 in config.g?
                          • namlecncundefined
                            namlecnc @dc42
                            @dc42 I did
                            M584 X5 Y6:7 Z8 E3:4
                            But I remove the T value in M569 because I thought wiring it to 5V should be ok.
                            I will attemp that change later when I go to the shop. What would happen if I change T from T2 to T5? Does this create inaccuracy ?
                            I will check the voltage reading as well.
                            How do I save the settings files to my computer? Is it possible to save different settings to pc and upload what’s needed to be checked ? I kinda want to save variations of set up and not keep changing one
                              Yes you will need to use M569 P5 T2 and the same with P6, P7 and P8. You can try T5 instead of T2. Using a T value that is higher than needed will reduce the maximum step rate you can achieve, but is otherwise harmless.
                              namlecncundefined 4 Replies Last reply Reply Quote 0
                              • namlecncundefined
                                namlecnc @dc42
                                @dc42 step rate as in khz ( not quite sure ) or the microstepping limit? I’m using 32x for these external driver.
                                What is the default pulse time of the board?
                                • namlecncundefined
                                  namlecnc @dc42
                                  @dc42 ; Configuration file for Duet WiFi (firmware version 1.21)
                                  ; generated by RepRapFirmware Configuration Tool on Mon Oct 15 2018 11:27:10 GMT-0500 (Central Daylight Time)
                                  M550 PNamDuetTest ; Set machine name
                                  M551 PTest123 ; Set password
                                  M552 S1 ; Enable network
                                  M587 S"Print Print" P"Nam123123" I192.168.2.100 ; Configure access point. You can delete this line once connected
                                  M586 P0 S1 ; Enable HTTP
                                  M586 P1 S0 ; Disable FTP
                                  M586 P2 S0 ; Disable Telnet
                                  ;M569 P0 S1 ; Drive 0 goes forwards
                                  ;M569 P1 S1 ; Drive 1 goes forwards
                                  ;M569 P2 S1 ; Drive 2 goes forwards
                                  M569 P5 S1 T5 ; Drive 5 goes forwards
                                  M569 P6 S1 T5 ; Drive 6 goes forwards
                                  M569 P7 S1 T5 ; Drive 7 goes forwards
                                  M569 P8 S1 T5 ; Drive 8 goes forwards
                                  M584 X5 Y6:7 Z8 E3 ; Apply custom drive mapping
                                  M350 X32 Y32 Z32 I0 ; Configure microstepping without interpolation
                                  M350 E16 I1 ; microstep with interpolation
                                  M92 X218.73852 Y218.73852 Z1259.84252 E418.5; Set steps per mm
                                  M566 X900 Y900:900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                                  M203 X12000 Y12000:12000 Z180 E1200 ; Set maximum speeds (mm/min)
                                  M201 X500 Y500:500 Z250 E250 ; Set accelerations (mm/s^2)
                                  M906 X1600 Y1600:1600 Z1600 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X1200 Y800 Z150 S0 ; Set axis maxima
                                  M574 X1 Y1 Z2 S0 ; Set active high endstops
                                  M558 P1 H10 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
                                  G31 P500 X400 Y400 Z2.5 ; Set Z probe trigger value, offset and trigger height
                                  M557 X30:1170 Y30:770 S20 ; Define mesh grid
                                  M140 H-1 ; Disable heated bed
                                  M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                                  ;M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                                  ;M143 H2 S280 ; Set temperature limit for heater 1 to 280C
                                  M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  M563 P0 D0 H1 ; Define tool 0
                                  M563 P1 D1 H2 ; Define tool 1
                                  G10 P1 X100 Y0 Z0 ; Set tool 0 axis offsets
                                  G10 P1 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
                                  • namlecncundefined
                                    namlecnc @dc42
                                    even when I commented the P0 out with ; , it stills runs when I tested M584 X0 .
                                    But still no motion from external drive 5 6 7 8.
                                    • namlecncundefined
                                      namlecnc @namlecnc
                                      This post is deleted!
                                      • namlecncundefined
                                        namlecnc @dc42
                                        This is the similar thread but ut is locked out
                                        https://forum.duet3d.com/topic/4935/wiring-up-external-dq542ma-stepper-motor-driver/6
                                        Exactly what I am doing but still no clear answer...
                                        And I got 3.7V on dir- and dir+ when I was trying to home...
                                          Have you tried using the M569 T parameters that were published in the last post in that thread?
                                          namlecncundefined 2 Replies Last reply Reply Quote 0
                                          • namlecncundefined
                                            namlecnc @dc42
                                            @dc42 I tried. I think my driver is bad. I'm buying new ones. I will report the results soon
                                            Thanks so much
