    TB6600 external drives
    3.8k
      I didn't expect changing the wiring between the breakout board and the external drivers to change anything, because external drivers are normally happy with the standard signals provided by the breakout board.
      Did you remap the XYZ axes to the external drivers using M584 in config.g?
      namlecncundefined 1 Reply Last reply Reply Quote 0
      • namlecncundefined
        namlecnc @dc42
        @dc42 I did
        M584 X5 Y6:7 Z8 E3:4
        But I remove the T value in M569 because I thought wiring it to 5V should be ok.
        I will attemp that change later when I go to the shop. What would happen if I change T from T2 to T5? Does this create inaccuracy ?
        I will check the voltage reading as well.
        How do I save the settings files to my computer? Is it possible to save different settings to pc and upload what’s needed to be checked ? I kinda want to save variations of set up and not keep changing one
          Yes you will need to use M569 P5 T2 and the same with P6, P7 and P8. You can try T5 instead of T2. Using a T value that is higher than needed will reduce the maximum step rate you can achieve, but is otherwise harmless.
          namlecncundefined 4 Replies Last reply Reply Quote 0
          • namlecncundefined
            namlecnc @dc42
            @dc42 step rate as in khz ( not quite sure ) or the microstepping limit? I’m using 32x for these external driver.
            What is the default pulse time of the board?
            • namlecncundefined
              namlecnc @dc42
              @dc42 ; Configuration file for Duet WiFi (firmware version 1.21)
              ; generated by RepRapFirmware Configuration Tool on Mon Oct 15 2018 11:27:10 GMT-0500 (Central Daylight Time)
              M550 PNamDuetTest ; Set machine name
              M551 PTest123 ; Set password
              M552 S1 ; Enable network
              M587 S"Print Print" P"Nam123123" I192.168.2.100 ; Configure access point. You can delete this line once connected
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              ;M569 P0 S1 ; Drive 0 goes forwards
              ;M569 P1 S1 ; Drive 1 goes forwards
              ;M569 P2 S1 ; Drive 2 goes forwards
              M569 P5 S1 T5 ; Drive 5 goes forwards
              M569 P6 S1 T5 ; Drive 6 goes forwards
              M569 P7 S1 T5 ; Drive 7 goes forwards
              M569 P8 S1 T5 ; Drive 8 goes forwards
              M584 X5 Y6:7 Z8 E3 ; Apply custom drive mapping
              M350 X32 Y32 Z32 I0 ; Configure microstepping without interpolation
              M350 E16 I1 ; microstep with interpolation
              M92 X218.73852 Y218.73852 Z1259.84252 E418.5; Set steps per mm
              M566 X900 Y900:900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
              M203 X12000 Y12000:12000 Z180 E1200 ; Set maximum speeds (mm/min)
              M201 X500 Y500:500 Z250 E250 ; Set accelerations (mm/s^2)
              M906 X1600 Y1600:1600 Z1600 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X1200 Y800 Z150 S0 ; Set axis maxima
              M574 X1 Y1 Z2 S0 ; Set active high endstops
              M558 P1 H10 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
              G31 P500 X400 Y400 Z2.5 ; Set Z probe trigger value, offset and trigger height
              M557 X30:1170 Y30:770 S20 ; Define mesh grid
              M140 H-1 ; Disable heated bed
              M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
              ;M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
              ;M143 H2 S280 ; Set temperature limit for heater 1 to 280C
              M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M563 P0 D0 H1 ; Define tool 0
              M563 P1 D1 H2 ; Define tool 1
              G10 P1 X100 Y0 Z0 ; Set tool 0 axis offsets
              G10 P1 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C
              • namlecncundefined
                namlecnc @dc42
                even when I commented the P0 out with ; , it stills runs when I tested M584 X0 .
                But still no motion from external drive 5 6 7 8.
                • namlecncundefined
                  namlecnc @namlecnc
                  This post is deleted!
                  • namlecncundefined
                    namlecnc @dc42
                    This is the similar thread but ut is locked out
                    https://forum.duet3d.com/topic/4935/wiring-up-external-dq542ma-stepper-motor-driver/6
                    Exactly what I am doing but still no clear answer...
                    And I got 3.7V on dir- and dir+ when I was trying to home...
                      Have you tried using the M569 T parameters that were published in the last post in that thread?
                      namlecncundefined 2 Replies Last reply Reply Quote 0
                      • namlecncundefined
                        namlecnc @dc42
                        @dc42 I tried. I think my driver is bad. I'm buying new ones. I will report the results soon
                        Thanks so much
                        • namlecncundefined
                          namlecnc @dc42
                          I got it to run!!!
                          Now here is a new issue. When I run test all motors, I edited to have 32x microstepping. An error pop up saying M350 drive Z does not support 32x microstepping... what is the deal?
                            T3P3Tony administrators @namlecnc
                            @namlecnc M350 sets the internal stepper driver microstepping (over SPI). As you are using an external driver the firmware cannot set the microstepping on the driver, you do that in some other way (normally Dip switches). If you set the steps/mm (M92) correctly for whatever microstepping you use on that external drive that will work.
                            • namlecncundefined
                              namlecnc @T3P3Tony
                              @t3p3tony
                              Yes this is on external drivers(xyz) so m350 for xyz doesn’t matter but the m92 steps per unit (mm) is the deciding factor?
                              Thanks a bunch!
                                @namlecnc yes. just use M350 for any internal drivers.
                                  @namlecnc Can you let us know what you did to fix the issue you were having getting the TB6600 to run?
                                  • namlecncundefined
                                    namlecnc @T3P3Tony
                                    @t3p3tony TB6600 does not work.
                                    I have to change to a more expensive DM542S
                                    I have it running now. At 32x , it runs ebrry time now. 128x doesn’t work.
                                    • johnundefined
                                      john
                                      I am also having issues getting my external drive to work. I attempted to wire the
                                      +(STEP,DIR,EN) to the 5V on the Heater Pins on the expansion, to see if the voltage of the expansion breakout was too low. This did not change my stepper motor behavior (it just vibrates after a few X+1 commands.
                                      See thread here for more information: https://forum.duet3d.com/topic/7703/closed-loop-control-of-stepper-motors-with-rotary-encoder/24
                                      johnundefined 1 Reply Last reply Reply Quote 0
                                      • johnundefined
                                        john @john
                                        @sean, as a follow on. ENA+ is by default at 3.35 V.
                                        If the schematic above says >3.5 V, would 3.35V be an issue? If it were, I would imagine wiring all the + leads to 5V would have remedied my issue.
                                        • JoergS5undefined
                                          JoergS5 @john
                                          @sean The CL57T manual says in 3.1.1 the high mode to be 4.5 to 24 volts, low between 0 to 0.5
                                          • johnundefined
                                            john @JoergS5
                                            @joergs5 If this were the issue, wouldn't it have worked when I wired all of the + leads to +5V?
