Remapped driver
Thank you very much for your reply. I have made all the changes he suggested, but the E0 continues without disappearing ... And now the E1 does not appear.
; generated by RepRapFirmware Configuration Tool on Thu Oct 18 2018 21:09:21 GMT+0200 (CEST); General preferences
M83 ; ...but relative extruder moves; Network
M550 PENDER 3 ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes backwards
M569 P1 S0 ; Drive 1 goes backwards
M569 P4 S0 ; Drive 3 goes backwards
M584 X0 Y1 Z2 E4
M350 X256 Y256 Z256 E16 I0 ; Configure microstepping without interpolation
M92 X1280 Y1280 Z6400 E514 ; Set steps per mm
M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
M203 X9000 Y9000 Z180 E1200 ; Set maximum speeds (mm/min)
M201 X575 Y575 Z100 E575 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X230 Y230 Z250 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S1 ; Set active high endstops; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
;M307 H4 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M307 H3 A-1 C-1 D-1
M558 P9 H5 F120 T6000 A3 ; Set Z probe type to bltouch and the dive height + speeds
G31 P25 X32 Y-2 Z0.35 ; Set Z probe trigger value, offset and trigger height
M557 X20:200 Y20:200 S45 ; Define mesh grid; Heaters
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0 cambiado para extrusor E0 pase a E1
; M563 P0 D1 H1
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
That's right, it's still E0 even though you have mapped it to driver 4, which is the one whose connector is labelled E1.
Ahhhhh Ok!!
Tahnks!!
Out of interest, how old is your Duet, and how did you damage the E0 driver? It's rare for the drivers to fail these days.
Hello, my duet is a week old, connect an engine (25mm brand pancake bondtech) which did not work, it vibrated a little but it did not turn, one of the times I connected it started to heat up, until they started to jump sparks the duet (my tears also leapt), I think it was the engine's fault despite being new ... I have again asked for another similar one, I'm worried if it happens again ...
Thank you very much for your interest. -
Where exactly did you see the sparks?
In the driver microchip
Please post more photos of the failed chip, in particular one taken from directly overhead and one taken looking towards the side of the chip close to the damage. I want to check that the chip was correctly aligned with the PCB pads on that side.
The soldering looks OK, however it's very rare for stepper motors to have shorted windings. So I will give you the benefit of the doubt and approve a warranty replacement for the Duet if you wish to return it.
Thank you, I appreciate it very much.
@danivv it might be worth checking the motor using one of the other (working) stepper channels as well as that will allow you to confirm the motor is working correctly.
@t3p3tony
I thought about doing it, but the engine got very hot and smelled like burnt, and I did not dare to try it for fear of burning another channel. -
@danivv ahh fair enough. Sounds like you could have the current set very high for that motor however I have checked the config.g and the motor:
https://www.bondtech.se/en/product/nema17-pancake-stepper-25mm/
and if the motor is working correctly the 500mA should be ok, which is what you have it set to. -
@t3p3tony
If just that, from 0.7A, I have asked for another equal ... -
Do you have a multimeter? if so, you can measure the resistance of each phase. Also make sure there is no continuity between the two phases, or between either phase and the case of the motor.
Does the motor have wires coming out of it, or does it have a 6-pin connector on it? If it has a connector, it is possible that the colours of the wires do not correspond to the usual phase colours.
Following the diagram I have attached the winding A and B. In both gives me continuity without resistance, ie short circuit. And endless resistance between them.
I can do some more test, if you want. It seems that the duet works correctly except for the E0 output.
Can your multimeter measure as low as 4.2 ohms?
Coil ACoil B
Could it be that only spool A is damaged?
I have filled in my Duet replacement request, thanks!
Yes, it looks like coil A is shorted and coil B is OK.
