    Your Duet rejected the HTTP request: page not found
    Firmware installation
    20.4k
    • sleeplessundefined
      sleepless
      Ive run the checks and it seems the sd is mounted, i changed the files with "new www files" but still nothing
        Is this a brand new genuine UK-manufactured Duet, or an older Duet that has been working but has just started to have this problem, or something else? It sounds rather like an SD card socket issue I remember that used to crop up a long time ago.
        sleeplessundefined 1 Reply Last reply Reply Quote 0
          sleepless
          The board is about a year old. Its direct from you guys. SD card reader checked out when I ran I think it was m92 and a few other check commands that you recommended another customer in another thread. I am using a 4gb microsd card not sure but I think class 10. Also I cant seem to respond on other threads, I can only create new threads.
            sleepless
            Sorry forgit to mention this is the first time I'm connecting it currently running firmware 2.0
              sleepless
              Also I moved the jumper to be vfan so I can use my 12v fans for the always on fans. Now the fan turns on but the screen doesnt and the stepper leds dont. But if I connect only via USB it powers up everything but the fan. Can you please supply some pics of where the jumper should be located when using 12v fan being powered by the power supply not the board.
                sleepless @dc42
                @dc42 anyway I can get a direct line with you so I dont have to constantly stop and go with this install.
                  sleepless
                  I gave up on the fans. That seems like a huge oversight. I dont understand why I have to use 5v fans but I gave in and ordered some. Is there another way to run the endstops check through the LCD screen?
                    sleepless
                    Hello? can I get a direct line with anyone? Im all for the community being able to see the troubleshoot to get help from it but at these response rates I wont have my machine up and running for another year. Is there a phone number or email or something more direct that actually will get a response more than once a day?
                      dc42 administrators @sleepless
                      @sleepless said in Your Duet rejected the HTTP request: page not found:
                      The jumper should be between the centre pin of the fan voltage selector block and the pins at one end labelled VFAN, as illustrated at step 12 of https://duet3d.dozuki.com/Guide/2.)+Wiring+your+Duet/9. If your VIN voltage is 12V, you can use 12V fans with the jumper in this position.
                      By "screen" I presume you mean the PanelDue. The fan voltage selector does not affect the voltage supplied to the PanelDue.
                      Regarding access to the SD card, please connect via USB, run the following commands in this sequence and report the response to each one (with a correctly-formatted SD card in the socket):
                      M39
                      M503
                      M21
                      M503
                      M122
                      (with the M503 commands I just want to know whether it echoes the contents of config.g or reports that it can't find the file).
                        sleepless
                        I finally got connected to web interface by reformating the micro sd and doing a fresh install. Now i am getting a wierd noise from the motors of the y and z axis
                          sleepless
                          when i put the jumper there the fans worked but nothing else powered up. for example the leds by the drivers didnt light up when powered on.
                          • elmoretundefined
                            elmoret
                            The LEDs near the drivers are to indicate endstop status, not stepper motor power. I would recommend reading the documentation:
                              sleepless
                              none of the leds come on except the vin
                                sleepless
                                i will just have to give in to duets engineering oversight and change my fans to 5v. there should be a big clear note on when buying this board. Also right now i need help with the motor problems
                                  sleepless
                                  can i get a direct line with support please. the forum response time is too slow for me
                                    T3P3Tony administrators @sleepless
                                    @sleepless ypou do not need to change the fans to 5V - as has been mentioned previously you can set them to VIN or 5V.
                                    VIN can be between 12V and 24V, either 12V or 24V are the most common.
                                    when you say none of the LEDs come on other than VIN, looking at step 6 here:
                                    https://duet3d.dozuki.com/Guide/2.)+Wiring+your+Duet/9#s27
                                    are the 5V and 3.3V LEDS not lit? in which case there may be no 5V present. Have you set it to use external 5V? the default is internal 5V, set but a jumper marked 5V EN, next to the Fan voltage select jumper:
                                      We do not provide phone support I am afraid. It would make the cost of the hardware prohibitive for most people.
                                        sleepless
                                        oh ok i was supposed to leave the existing jumper and add the otherthanks for clearing that up i will try again
                                          @sleepless Yes, the board should have come with a jumper on V_Fan selector and on 5V EN, did it not? where did you get the board from?
                                            sleepless
                                            ok now everything lights up proper thank you
