    Problem tevo little monster stepper motors adjust
    • rothundefined
      roth
      Hello
      I have a Problem with my Delta Printer.
      (M92 X80 Y80 Z80 E798 Set steps per mm)
      It always hits the underlying layer when printing.
      I had set everything after a video on Youtube:
      https://www.youtube.com/watch?v=BgkJVgFnPaE
      So scratch with the nozzle and then everything falls off the pressure bed.
      I measured a height difference of about 0,33 mm.
      Means I simply measured with the calliper at different heights.
      ![2_1540833459514_IMG20181029181145.jpg](Uploading 1%) ![1_1540833459514_IMG20181029181124.jpg](Uploading 1%) ![0_1540833459514_IMG20181029181105.jpg](Uploading 1%) 2_1540833561867_IMG201810291811450.jpg 1_1540833561867_IMG201810291811240.jpg 0_1540833561867_IMG201810291811050.jpg
      • rothundefined
        roth
        Under Extrusion is because I tried to solve the problem.
        • boldnutsundefined
          boldnuts
          Are you saying that the bed is to low at one end and to high at the other?
          • rothundefined
            roth
            Or is there anything else that can lead to the problem?
            So I mean besides the belt and the stepper motors and the print quality?
            So more settings except the Z height?
            • boldnutsundefined
              boldnuts
              check your steps per/mm for the extruder, as it seems to high for a 1.8deg motor with titan extruder
                dc42 administrators @roth
                @roth said in Problem tevo little monster stepper motors adjust:
                Looking at the perimeters, I think it is over-extruded, not under-extruded.
