Tool to remove heater pins from the Black connector
Smart effector for delta printers
1.8k
    Quadcells
    I pulled the wires out of the pins that are in the black connector for the hotend. What tool do I need to remove the pins from the connector.
    /quadcells
      crynool
      You mean on the Smart Effector? Or which connector are you referring to?
      If so, the pins are Microfit Jr, you can do it with a paper clip, just flatten an end.
        The 6-pin connector is a Molex Microfit 3.0 and unfortunately it needs a special and expensive tool to remove the pins. It's easier to cut it off and fit a new connector. That's why we supply a spare connector shell and extra crimp pins.
        We'd prefer to use a connector where the pins are easy to remove, as with the 8-way Molex KK connector that is used for the low voltage wiring; but we couldn't find one that has a high enough current rating.
          crynool
          As said, I made good experience with a paperclip. Flattened one end, put it between the connector and the housing, wiggled a bit, other side. Et Voila.
            Quadcells
            Yep that's the connector. Wow I only received one black connector with mine. I will try to remove the pins.
            /quadcells
            undefined 1 Reply Last reply 1 Nov 2018, 22:08 Reply Quote 0
              Quadcells
              found the connectors with pins on Amazon:)
              /quadcells
                T3P3Tony administrators @Quadcells
                @quadcells did you get it directly from us?
                  Quadcells
                  No, I got thru Filastruder. It had extra pins and two extra 2 pin connectors. But Only one 6 pin. But That was back in Feb. so it is very possible that I miss placed it but I have to other ones. So no worries I ordered a couple from Amazon and will have them next week.
                  /quadcells
                    Ricky_Grade10
                    Is this the correct tool for removal?
                    https://www.digikey.com/products/en?mpart=11-03-0043&v=900
                    Site says its 22 and some change. I know I only got my grade ten, but thats not that bad when you think about having to buy a new connector, crimp terminal metal thingy and a new fan when they go out. I made my own by taking a small screwdriver to a grinder.....
                      That tool does look correct. I can only assume that they have introduced it recently, because last time I looked the only suitable tool was much more expensive than that.
