Advanced: PCB design and development
Most or all of those are LEDs. Any LED of the correct colour in an 0603 package should work. For the red ones we use Kingbright KP-1608SURCK.
i have been trying to integrate GPU for display integration, meanwhile as i was going through the schematics above diodes were just having package info but not any part no, this made me think what would have been its specs i.e voltage regulations and watt rating to keep board from burning.
oh.., by any chance are there any rectifier diodes in these no's, help me with it
You can tell from the schematic which diodes are LEDs.
thanks, i got it but could not understand diode parallel to fan inputs D21, D18, D8
Those are 1A fast rectifier diodes in DO219AB package. For example, Vishay ES07B or ES07D.
nice...!!, whats the current rating for L1 inductor near Lx port of A4403 can you tell me reference part no for it
and also unable to figure out erase and reset component (s1, jp1), as per the schematic they seem to be different speculated components but on the board they seem to be same can you also help me with that. thanks in advance
@nikhil-8333 Just curious as to why you want to know the part numbers and specifications of all the components on the Duet board. Are you perhaps intending to make and sell copies of these boards by any chance?
no, I am trying to integrate a GPU on the same board as a single PCB where i need to understand all the components so that i can design further addition and to prototype the result, I promise to put up a fork in git hub with all the mods.
can anyone help me with these, (whats the current rating for L1 inductor near Lx port of A4403 can you tell me reference part no for itand also unable to figure out erase and reset component (s1, jp1), as per the schematic they seem to be different speculated components but on the board they seem to be same)
L1 is BRL3225T1R0M. Erase used to be a push button like the Reset button, but too many users were pressing it by mistake. So on later Duets we replaced it by a 2-pin jumper block.
