Inductive sensor - Z probe returning wrong measurements
As I said before, the faulty E0 driver is sufficient for you to claim a warranty replacement for your Duet, assuming it is a genuine UK-manufactured one purchased from us or from one of our distributors. See https://www.duet3d.com/warranty.
Thanks for the reply @dc42 .
Maybe a bit of miscommunication, but its more about understanding the fault than about the warranty.
I dont understand the problem with panel Due right now. Its a I7 brand new one directly from duet3d UK website.
But the panel due is not able to read the micro sd card. What could be the possible reason ? Am i missing any connection ? i think there is nothing much from user end because its all straight forward, just connecting the two way wire and power pins.
In order to use the SD card on PanelDue, you need to use the ribbon cable connector on PanelDue to connect it to CONN_SD on the Duet, instead of using the 4-way connector.
yeah. I have used the ribbon cable and connected as per the documentation.
From the panel due 'connect SD' to the duet 'Connect SD'.Is the panel due i7 compatible with duet Ethernet 1.0 electronics and firmware version 1.19 ?
I tried with new board and 2.04 firmware too but it was not successful. -
All Duet Ethernet boards shipped from the factory are PCB revision 1.02 or later. If yours really is a 1.0 then it must have been converted from a Duet WiFi.
Duet PCB revisions 1.0 and 1.01 do not provide the UTXD and URXD signals on the CONN_SD connector, so they need the 4-way cable as well as the ribbon cable. Without it they will remain in the "Connecting" state.
How long is the ribbon cable? The length needs to be limited to about 300mm to avoid signal degredation.
Both 4 way cable and ribbon cable are connected. I double checked the connections, they are as per the documentation.
The length is also less than 250 mm because i read that maximum of 400 mm can only be used.
I think the panel due is not able to read or detect the memory card. I ran the firmware diagnostics also and it reports only one memory card i.e the one in duet.
And the panel due throws an error "Error: 1 accessing SD card" . I tried with different memory cards but it still shows the same error.
If you send M21 P1 from either PanelDue or from DWC, what is the response?
"Cannot initialise SD card1 : card is unusable"
Do you have anything connected to the temperature daughter board connector? Do you have a DueX expansion board connected?
No. I did not use any of them. I have a duet Ethernet and expansion header for the drivers. Thats it.
Please try it without the expansion board ribbon cable connected to the Duet, in case of a problem with the cable or the expansion breakout board.
I tried and it did not work.
I got a new TFT panel display same one and the sd card works fine. So i think its the problem with sd card port in the previous panel.
Thanks for the swift response and support!
