    New RepRapFirmware config tool
    79
    10.4k
    • 3dmntbighkerundefined
      3dmntbighker
      Nicely done BTW.
      Scratch built CoreXY with Maestro
      Heavily modified Ender 3 with Maestro
      MPCNC work in progress with Duet WiFi
      • botundefined
        bot
        Looks nice. Is there support for Duex2/5 that I'm missing? A facility to configure IDEX printers?
        *not actually a robot
        • stewwyundefined
          stewwy
          Looks good,
          one problem the mesh bed page will not let me go back to check my bed size just says "page still contains errors" and will not let me move off the page.
          Some indication of what was in error would be good, the people who use this are likely to be beginners.
          • mikebridgeundefined
            mikebridge
            is there a way to export a config.json from my current setup to import into the tool?
            375x360x415 CoreXY DuetWifi + Duex5
            24v 600w, E3D Chimera, Zesty Nimble CC, BLTouch, X&Y linear rails, dual Z motors
              Can I suggest making it a little more clear how to choose a PT100 sensor as your thermistor. The drop down lists RTD, Thermocouples, etc, but it doesn't actually say PT100 anywhere and the default thermistor values don't change. It could be spelled out more clearly.
                Also I noticed that it still selects probe type P5 for the BLTouch instead of P9.
                • chrishammundefined
                  chrishamm administrators @3dmntbighker
                  @3dmntbighker Sure, done.
                  @bot Yes, support for DueX2/5 is already included. You can configure every heater+motor that is supported on a DueX5.
                  @stewwy I could not reproduce this. What did you do when that happened?
                  @mikebridge Have a look at the System Editor in DWC. There you can download a file called "config.json" which you can select by choosing the "Existing configuration" option on the Start page.
                  @Phaedrux My apologies for the trouble with the wrong Z-probe type, that happened when I removed the old "Ultrasonic" option. It's fixed. Also I restructured the sensor channel selections to make things a bit clearer - I hope that helps.
                  Duet software engineer
                  garyd9undefined botundefined 2 Replies Last reply Reply Quote 1
                  • stewwyundefined
                    stewwy
                    Just tried again from work pc and it's still the same
                    Try bed size on first page as x min: max 20:265 y 20:230 and z 0:280 ( actual size and offsets of my bed). Then page through to to the mesh bed page accepting the defaults.
                    you will not be able to leave that page , unless you alter the x-min and y-min to 20 or greater (i.e inside the print bed area), fine if you understand what you need to do, but the error notice gives no details or clues.
                      chrishamm administrators @stewwy
                      @stewwy said in New RepRapFirmware config tool:
                      I see, thanks for the note. Nevertheless in my browser the min+max inputs of the mesh compensation turn red, is this not the case for you?
                      I'll change the config tool to update the mesh mins+maxes automatically, though.
                      • stewwyundefined
                        stewwy
                        I use chrome at work and opera at home when I get home tonight I'll check with all the browsers
                          Hmm, you are right - I don't see any validation errors in Chromium either. I'll provide a fix for this.
                            Okay, done. It looks much better now.
                            • stewwyundefined
                              stewwy
                              Yes fixed 🙂
                              • garyd9undefined
                                garyd9 @chrishamm
                                @chrishamm said in New RepRapFirmware config tool:
                                ?? There's no such file listed on one of my printers. Is that auto-generated based on the current config.g? Can it be recreated based on current configuration changes made directly?
                                I always thought that config.json was a leftover file from importing a config from the online tool, but never updated (by the duet) when configuration changes are made.
                                  chrishamm administrators @garyd9
                                  @garyd9 This JSON file only contains the inputs you made in the config tool, I thought that is what you meant. The firmware does not update this file, though. If you'd still had that JSON file on your printer, you could have used it to restore the inputs you made before.
                                  mikebridgeundefined 1 Reply Last reply Reply Quote 0
                                  • garyd9undefined
                                    garyd9
                                    Thank you. I have a question on the configuration generated when selecting a PT1000 thermistor. (I'm asking because I'm getting a PT1000 but I'm not quite certain the proper way to configure it.)
                                    The tool generates something like "M305 P1 X501" (no "R" parameter.) However, the duet wiki suggests that a "R" parameter is required for PT1000's (or at least it's shown in all the examples.) (https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors)
                                    Is it needed?
                                    • madhunmundefined
                                      madhunm
                                      @chrishamm Any chance of adding the independant Z motor configuration?
                                        @garyd9 The 'R' parameter is basically obsolete for Duets newer than the 0.6 because it defaults to 4.7kOhm in the firmware. I'll add it back for consistency, though.
                                        @madhunm Yes, I think I can add it soon but in the meantime I still have to have a look at a few DWC requests that have come up.
                                        Edit: The configtool now generates an extra 'R' parameter for PT1000 sensors.
                                        madhunmundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                        • madhunmundefined
                                          madhunm @chrishamm
                                          understood; will look forward to the update when it happens. Thanks!
                                          • botundefined
                                            bot @chrishamm
                                            I'm not sure I'm seeing this, except for extruders. Where can a U, V, and W axis be created?
                                            How would one configure an idex printer using this tool?
