    Z Motor weak / one missing [solved for now]
    1.1k
    • SupraGuyundefined
      SupraGuy @Buj
      @buj said in Z Motor weak / one missing:
      System is 24 volts powered
      Core XY
      This is my Driver mapping. I am controlling 4 nema 23 motors
      M584 X0 Y1 Z2:4:5:6 ; Assign drivers to Z axis
      X and Y are fine
      Try
      M584 X0 Y1 Z2:4:5:6 E3 ; Assign drivers to Z axis, unassign 4 from E axis.
      If the motor on drive 2 isn't turning, check that the jumpers are on the second output of drive 2. If they aren't, then that motor will be open circuit, since the second motor boss is in series with the first one.
      Lead screw driven printer, powered by Duet 2 Wifi
      MPCNC powered by Duet 2 Wifi
      CoreXY printer driven by Duet 3 6HC
      LowRider CNC powered by Duet 2 Wifi
      • Bujundefined
        Buj
        @supraguy said in Z Motor weak / one missing:
        Jumpers are present,and installed as per factory. could they be defective? i doubt but at this point... i'll check
        thanks
        • Bujundefined
          Buj
          [Update] From what i hear from theZ axis motor is that the signal frequency is too high and motors start skipping assoonas they recieve a signal . going downward is easier...
          Stephen6309undefined 1 Reply Last reply Reply Quote 0
          • Bujundefined
            Buj
            Reduced the Z acceleration from 200 to 50. Now going up and down as expected.
            Still no output from drive 2 Z motor...
            • Stephen6309undefined
              Stephen6309 @Buj
              @Buj
              Z axis acceleration is probably too high, if there is no mechanical problem.
              • Bujundefined
                Buj
                Mouvement out of 3 motors remapped as per config with low acceleration, still missing the 4th motor connected to Z output of DUET wifi
                  Did you correct the M584 command as @SupraGuy suggested? That's very important, see the bold text at https://duet3d.dozuki.com/Wiki/GCode#Section_M584_Set_drive_mapping.
                  • Bujundefined
                    Buj
                    the assign beeing M584 X0 Y1 Z2:4:5:6 E3
                    i understand that etruder is assign to 3? isnt it?
                    how do i unassign a drive?
                      dc42 administrators @Buj
                      Yes, that M584 command is correct. Do you still have the problem?
                      It may help diagnose the problem if you upgrade to firmware 2.02RC3 because it has better stepper driver diagnostics.
                      • Bujundefined
                        Buj
                        The printer is on the move to the Maker Fair. will persue at a later date.
                        Thanks#
                        • SupraGuyundefined
                          SupraGuy
                          The reason for explicitly assigning E to drive 3 is that by default it would be ... E3:4 -- with drive 4 also assigned as an E axis. (As per the bolded text in the article dc42 linked.)
