    Purchasing components
    760
    • irondesk40undefined
      irondesk40
      Are you better off to purchase directly from a distributor in the US such as Filastruder or from Duet directly to ensure you get the latest firmware etc.
        It makes little or no difference. When we make hardware revisions, we try to arrange it so that we and our distributors switch to the new revision at the same time. Firmware can be upgraded easily anyway.
        We recommend that US-based customers by from Filastruder or from one of our other US distributors.
          irondesk40
          Thanks. Is the Duex5 on Filastruder site the expansion board you have recommended in order to drive a external stepper motor amplifier/controller?
          • botundefined
            bot @irondesk40
            @irondesk40 No, this is what they are referring to: https://www.filastruder.com/collections/electronics/products/duet-expansion-board
            This allows you to use external drivers. The Duex has on-board drivers, just like the Duet.
            *not actually a robot
              irondesk40
              A little confused. I thought the following was what was needed to drive external stepper controllers.
              https://www.duet3d.com/Expansion_Breakout
                irondesk40
                Do not see that listed on filastruder.
                elmoretundefined 1 Reply Last reply Reply Quote 0
                • elmoretundefined
                  elmoret @irondesk40
                  @irondesk40 @bot linked you to it, here's the link again:
                    irondesk40
                    bot
                    My fault , i can find it on the filastruder site after i opened your link.
                    is there a wiring diagram for the breakout board? My external driver requires 5v and i understand this board will supply that. I saw a picture of board with a hookup diagram but not clear if i would need to supply a external power source or is it supplied through the ribbon cable.
                    • elmoretundefined
                      elmoret
                      How to connect will depend a bit on what drivers you are using - do you have a model number or data sheet?
                        irondesk40
                        Looking at this one for testing. Then possibly a Yamaha. But for testing in our R&D Lab will be using this one since i have it.
                        https://www.automationdirect.com/adc/shopping/catalog/motion_control/stepper_systems/stepper_drives/stp-drv-6575
                          irondesk40
                          Thanks to everyone. Just ordered the ethernet board, 5 inch display and the breakout board.
