RepRapFirmware 2.02RC4 released
Firmware installation
18
72
8.2k
    I've just released this at https://github.com/dc42/RepRapFirmware/releases/tag/2.02RC4. See the upgrade notes at https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for full details.
      deckingman
      David,
      I'm not sure if this is the best thread to report back on but there have been a few threads started by myself and others with seeming boot up and /or I2C errors, so I'll put my feedback here.
      I've updated to this 2.0.2RC4 release and DWC 1.22.5 as recommended in the release notes.
      I don't see any sign of the Duex5 heater LEDs flashing now (someone had problems with lights connected to heater channels flashing).
      I do still get a short "double blip" of the hot end fan when booting but it's much much shorter and the overall boot up time seems to be faster.
      I still get DWC disconnecting if I edit config.g then restart. It takes about 5 to 10 seconds or so for DWC to re-establish a connection. This isn't a huge issue though. Maybe it's something to do with my PC (Win 10 i7) or Browser (Firefox) or network (wired gigabit ) but I can't think what. It's a trivial thing so I'm not too bothered about it.
      Too early to say if I have any I2C errors as these were very intermittent.
      HTH
      undefined 1 Reply Last reply 18 Nov 2018, 15:59 Reply Quote 0
        fcwilt @deckingman
        @deckingman said in RepRapFirmware 2.02RC4 released:
        Seems to me this is to be expected since the firmware is re-booting.
        Has there ever been a time when a restart didn't close the connection to DWC?
        undefined 1 Reply Last reply 18 Nov 2018, 16:18 Reply Quote 0
          deckingman @fcwilt
          @fcwilt said in RepRapFirmware 2.02RC4 released:
          The connection gets lost after the firmware re-boots and in another thread that I started, people told me that 10 seconds or so was an inordinately long time for the connection to re-establish. I'm not too bothered about it but others have told me that the behaviour is abnormal, hence the reason I mentioned it.
          undefined 1 Reply Last reply 18 Nov 2018, 16:37 Reply Quote 0
            dc42 administrators @deckingman
            Are you using a static IP address, or DHCP? If you are using DHCP then the reconnect time will depend in part on how quickly your router allocates an IP address to the Duet.
            Also, I don't know how long DWC waits between connection attempts. It must obviously be long enough to allow the previous attempt to time out.
            undefined 1 Reply Last reply 18 Nov 2018, 16:43 Reply Quote 0
              deckingman @dc42
              @dc42 It's static. We've been through all this in other threads but it's a minor irritation so don't worry about it. I only mentioned because I was trying to point out any behaviours that are changed or unchanged.
                Veti
                my 12864 now initializes correctly
                thank dc42
                  incogizmo
                  Ive updated to RC4 today and the 79, 179 and 279 values are now working as expected on the 12864 display.
                  Thanks dc ๐Ÿ™‚
                  I have noticed a few other oddities with the 12864 display however.
                  The speedfactor is display appears to be multiplied by 100. Using M220 S80 will produce an output of 8000
                  This is the line I am using the display spped factor:
                  value R51 C50 F0 D0 W25 N500
                  Another thing I have noted is loading menus now does not function. I recieve an error stating File "menu", File cannot be found.
                  The line I am using is:
                  button R51 C72 F0 T"Get Started ยป" A"menu" L"e_main"
                  If I create a file called menu it will be loaded when trying to select any button that is a reference to a menu.
                  For now I have reverted to RC3 and all functionality has returned.
                  undefined undefined 2 Replies Last reply 19 Nov 2018, 11:31 Reply Quote 0
                    Veti @incogizmo
                    @incogizmo
                    change the A"menu" to A"e_menu"
                    undefined 1 Reply Last reply 19 Nov 2018, 12:13 Reply Quote 1
                      dc42 administrators @incogizmo
                      @incogizmo said in RepRapFirmware 2.02RC4 released:
                      That line should have been:
                      button R51 C72 F0 T"Get Started ยป" A"#0" L"e_main"
                      but due to a bug that is now fixed, you had to use "menu" instead of "#0". However, @Veti's suggestion is simpler.
                      I will check out the display of the speed factor.
                        incogizmo @Veti
                        This post is deleted!
                          incogizmo
                          @dc42 & @Veti ahhh awesome thanks guys so I was doing something wrong ๐Ÿ™‚
                          So I understand, on a button to launch a menu the file name is to be in both the A and L value? Or A"#0" preferably.
                          Easily fixed! I'll update all my menus and switch back to rc4 thanks again for all your help ๐Ÿ™‚
                          undefined 1 Reply Last reply 19 Nov 2018, 12:33 Reply Quote 0
                            Having looked into it some more, I can see that the person who implemented my specification misread my intentions, and my supposed fix in 2.02RC4 has not helped. For now put "#0" in the A parameter and the menu filename in the F parameter. Don't start the menu name with letter G, M or T. This is a temporary workaround, and I will fix it properly in the 2.02 release.
                              GizmotronX5000
                              I'll likely update today!
                              (This is a test post against the spam filter. I was getting automatically flagged last week.)
                                smoki3
                                @dc42 Hi,
                                i noticed that M1 is calling "ause.g" instead of "pause.g". I think its a typo.
                                Running RC4
                                undefined 1 Reply Last reply 19 Nov 2018, 22:43 Reply Quote 0
                                  dc42 administrators @smoki3
                                  @smoki3 said in RepRapFirmware 2.02RC4 released:
                                  @dc42 Hi,
                                  Running RC4
                                  Are you sure? M1 should call sleep.g.
                                  undefined undefined 2 Replies Last reply 19 Nov 2018, 23:27 Reply Quote 0
                                    fcwilt @dc42
                                    @dc42 said in RepRapFirmware 2.02RC4 released:
                                    M1 does do that - verified.
                                    If something is calling "ause.g" perhaps the P parameter was left off?
                                      @fcwilt, what is your evidence that M1 is calling "ause.g"? Do you have a sleep.g file on your system?
                                      undefined 1 Reply Last reply 20 Nov 2018, 09:22 Reply Quote 0
                                        fcwilt @dc42
                                        I verified that M1 calls "sleep.g".
                                        BUT I speculated that perhaps something (not M1) was executing a command "M98 pause.g", with the P parameter left off by mistake, thus yielding a call to "ause.g".
                                          smoki3 @dc42
                                          @dc42 I get the message "ause.g" cant not found on my paneldue.
                                          But maybe I found the issue. In my sleep.g It calls M98 pause.g instead of M98 Ppause.g
                                          1 out of 72
