    Duet WiFi firmware new feature priorities
    Firmware wishlist
    54
    167
    40.6k
      @LeonMF:
      @dc42 My apologies. Everything I'd seen to this point (including this thread) seemed to indicate it wasn't yet a feature (reading comprehension fail).
      Can it ignore the sensor when not actually printing? When my print is finished, the Tunell sensor will trigger a non-moving condition. As a result, the switch would be triggered until I reset it. This would cause the system to go to the "pause position" while at home and that's not so awesome of a result on a Delta printer.
      A valid answer is, dump the fancy electronic sensor for one that doesn't trigger unless it's out of filament but I hope that's not the one you give me. ๐Ÿ™‚
      If you follow the link to the gcode wiki in my previous post, you will see that the M581 command has an option for the trigger to be recognised only while printing from SD card.
      M581 is recently implemented and not much used yet. Please let us know how well it works with your Tunell filament sensor.
      • demonio669undefined
        demonio669
        Another Request:
        Add a switch to M117 Gcode to allow send de message via email (to check via email if the printer started to print or the print finished for example)
        M117 S"This is the subject" -D"john@example.com" -B"This is the message body"
        • Stevebealeundefined
          Stevebeale
          Just got mine. Luverly..
          Can the BL Touch probe be added.
          Steve a newbe
          • PRZundefined
            PRZ
            About the BL touch, Have a look at this thread : http://forums.reprap.org/read.php?416,669287,669287#msg-669287
            Short answer : Not yet
            Longer answer: It may be workable to output a servo compatible signal with a fan/signal output, using M106 code to adjust the PWM, but this is not yet tested.
              In version 1.15 the PWM resolution is greatly increased. One of the main reasons I did this was to provide better resolution of the servo pulse length when a PWM channel is used as a servo output.
              • StephenRCundefined
                StephenRC
                For the BL Touch, you could use https://www.sparkfun.com/products/13118 for the servo signals, then all you need a pin to toggle it.
                • Mattundefined
                  Matt
                  G. Support for three independently-controlled Z motors
                  S. BLTouch
                  F. Support for multiple independent X carriages
                  B. Multi-threaded web server
                  H. Grid-based bed compensation
                  • sgaundefined
                    sga
                    S. Using stallguard for missed step detecion and auto rehome.
                    Apparently the tmc2660 shall be able to detect unexpected high loads.
                    After a few hours of frustration I finally did a semi successful benchy3D the most visible faults are due to the head hitting hardened overhanging corners curling upwards and producing missed steps, or hitting an already printed structure. Unfortunately I generally detect the fault 1-2 layers later.
                    If it could eventually be detected immediatly the delta could be paused, rehomed and restarted with no layer shift.
                    For some reason it does seem to work most of the time when done manually.
                    And yes I could up the current. But I don't want to because it prevents to hard shocks in case of colisions,
                    • croadfeldtundefined
                      croadfeldt
                      Does this include changes requested for webcontrol?
                      If so, Is it possible to have a config.g backup made automatically?
                      I just attempted to make an update to config.g via the web interface to change the offset of my probe after adding a PEI sheet to the build plate. Made the change, hit save and the firmware evidently reset without warning or saving the config.g, taking out config.g in the process. It's now a 0 byte file. Like a fool, I don't have a backup, you can bet I will be grabbing one before changes from now onโ€ฆ
                      Anyhow, my request would be to have the current config.g backed up every time an update is made, that would at least keep a quasi backup file on the SD card.
                      Or if someone wants to point me in the direction of the code, I will add it, if nothing else, for myself. ๐Ÿ™‚
                        deckingman
                        Personally, I always keep the config files in a folder on my PC and keep this backed up. When I want to make changes, I re-name the config as configold or some such and upload the new file, rather than edit it from within the web interface. I've had one too many corrupt SD cards in the past.
                          I've started a new forum heading for Duet Web Control feature requests. Please start a new thread there to request keeping a backup copy of config.g.
                          • jmjcokeundefined
                            jmjcoke
                            1.F/f
                            2.F/f
                            3.F/f
                            Joshua Coke
                            Trick Laser Metal Max with Smart Effector
                            Duet Wifi
                            Zesty Nimble
                            Mosaic Pallette+
                            At work
                            Renishaw AM250/400/ RenAM500M/500Q Powder Bed Fusion (Metal 3D Printers)
                              @jmjcoke:
                              1.F/f
                              2.F/f
                              3.F/f
                              F is multiple independent X carriages. I think it's possible to implement this without any firmware changes. You would use the M584 and M574 commands in homex.g and homeall.g to switch between motors and endstop switch locations, and M584 to switch X motors in the tool change files. You would need to connect the two normally closed X endstop switches in series, and simultaneous homing of both carriages would not be available.
                              • botundefined
                                bot
                                @dc42:
                                @jmjcoke:
                                1.F/f
                                2.F/f
                                3.F/f
                                I was thinking of this the other day. With two x carriages, one may have a different z offset than the other, is there a way to incorporate a move to lower the bed by some amount (to clear any edge clips/obstructions) and then raise it to the other tools z offset during toolchanges?
                                *not actually a robot
                                  Yes, there is a Z parameter in the G10 command that defines the tool offsets. You can define whatever parking moves you want in the tool change gcode files.
                                  • botundefined
                                    bot
                                    I was not aware of tool change gcodesโ€ฆ this is fascinating. The more I use RRF, the more I am impressed by its capability.
                                    Does the mere existence of T0.g, T1.g, etc, allow for their execution upon tool selection?
                                      They are called tpree0.g, tpost0.g and tfree0.g for tool 0, and similarly for the other tools. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Tool_change_files.
                                      • Adamfilipundefined
                                        Adamfilip
                                        Curious if there is a beta of the Grid leveling that can be tested ๐Ÿ™‚
                                        The grid levelling is more than 50% implemented in the 1.17dev5 release that is now on GitHub. You can define the grid using M557 and probe it using G29. Still to do is to finish the interpolation code, then add save/restore of the height map to file, and segment long moves. I may get time to do those next week.
                                        • Pumluxundefined
                                          Pumlux
                                          Hi all,
                                          I have not found a smooth way to have the heat bed cooled down in a controlled (following a temperature function) way.
                                          Just switching the heatbed power off cools down to fast and results (from my opinion) on some filaments in warping on the print object.
                                          How about implement a firmware function to allow the heat bed cool down on a parameter like e.g. 3 ยฐ Celsius per minute ?
                                          The same feature would be useable for those having a heated chamber.
                                          What do you think ?
                                          Regards
                                          Pumlux
                                          Using a own build of a Mendel Max , Duet Wifi, Bed 8 mm Aluminium PEI 500 x 280 x 400 230 V 850 W, original E3D Chimera hotend with bowden length 700 mm, since short time with a BL-Touch, Steppers : mostly Nema 17 and one Nema 23 for Y-axis
                                            That feature could certainly be added. However, I haven't seen anyone else ask for it. OTOH a common complaint is that the bed cools down too slowly and a fan is needed to speed up the process.
                                            What is the construction of the bed on your printer? Does it have insulation beneath it?
