    Question about M106
    1.3k
    • fcwiltundefined
      fcwilt @dc42
      @dc42 said in Question about M106:
      0 to 255 should work as well. Values of 1.0 or lower are assumed to be in the range 0 to 1, values above 1 are assumed to be in the range 0 to 255.
      I just tested it again with LEDs as it is a bit easier to view the result
      0 by itself does turn the LEDs off BUT 1 to 255 all seem to be the same - full on.
      0.00 to 1.00 does yield varying light levels.
      The slider in DWC confirms this.
      Is the number in the 2nd decimal place (x.x#) intended to change the speed/level by 1%?
      I cannot be sure that I am seeing such a small change in the light level.
        The resolution depends on the PWM frequency you have set. It's usually well below 1%.
        What commands are you sending to adjust the PWM?
        • fcwiltundefined
          fcwilt @dc42
          According to the docs the FAN outputs on the Duex5 v0.7 do not have adjustable frequency.
          To test M106 I have tried:
          M106 P6 S0.0 - LEDs are off - DWC slider = 0%
          M106 P6 S0.5 - LEDS are medium - DWC slider is 50%
          M106 P6 S1.0 - LEDS are max - DWC slider is 100%
          M106 P6 0 - LEDs are off - DWC slider is 0%
          M106 P6 2 - LEDS are max - DWC slider is 100%
          M106 P6 255 - LEDS are max - DWC slider is 100%
            OK, you are using fans on the DueX board. I'll re-test those, because I only tested direct-connect fans in my recent tests.
              I found there is a problem using values in the range 2-255 if you have other parameters in the M106 command. For example, M101 P6 S128 sets the fan to half PWM; but M106 P6 S128 F100 sets it to full PWM. I will fix this in the next 2.02RC.
              • fcwiltundefined
                fcwilt @dc42
                Thanks for the feedback.
                But what you found does not match what I found, at least with it comes to a Duex5 v0.7.
                No extra parameters had to be present for the S1 through S254 values to cause the setting (according to the DWC slider) to be 100%.
                  dc42 administrators @fcwilt
                  @fcwilt said in Question about M106:
                  I was unable to reproduce that, it worked perfectly for me provided that the only parameters to the M106 command were P and S.
                  fcwiltundefined 2 Replies Last reply Reply Quote 0
                  • fcwiltundefined
                    fcwilt @dc42
                    I will check it again.
                    • fcwiltundefined
                      fcwilt @dc42
                      Well I went back and tested it and it now works - values from 1 to 255 have the expected effect.
                      Under any conditions does the firmware "remember" that extra parameters were used at one point and apply them for subsequent commands that have only P and S?
                        No, it doesn't.
                        • fcwiltundefined
                          fcwilt @dc42
                          No, it doesn't.
                          Then I will just have to keep an eye on the problem and see if it reappears and under what circumstances.
