    Display characters/text in macro
    • peirofundefined
      peirof
      i d'like do a macro, that "print" in screen some of special characteres...
      This can be do it?
      Explain me:
      I do the temperature tuning in a macro, and at the end of macro y send M307 H1 and M307 H0, for see the config numbers....
      But there is some manner, of put a message in macro, for example: "Tuning parameters of Nozzle heat cartridge" and "Tunning parameters of bed"
        dc42 administrators @peirof
        You can display a message using M117 or M291.
        • Vetiundefined
          Veti @dc42
          does that work for the maestro 12864 as well?
            dc42 administrators @Veti
            @veti said in Display characters/text in macro:
            That's a very good point. I suspect that those commands haven't been implemented on the 12864 display. I will check.
              M117 and M291 are not currently supported on 12864 displays, so I am adding support in release 2.02RC5.
              To display text written by M117, you will need to use a 'value' element with item number 501. A maximum of 1 line of text can be displayed. I believe this conforms to how other firmwares handle M117 on 12864 displays.
              M291 will produce a popup message box.
