    BlTouch randomly deploys probe twice.
    3.1k
      @siblues, which firmware and DWC versions are you using?
      • sibluesundefined
        siblues
        Here is the info you needed and now the wifi led was also turning off after it disconnected.I restarted the Duet wifi to see if I could reproduce the problem and now the only led that turns on with the power supply is teh vin led but when I directly connect to the board with a usb they all light up fine.
        Firmware Version: 2.02RC4(RTOS) (2018-11-18b5)
        WiFi Server Version: 1.21
        Web Interface Version: 1.21.1
        This is the result of M122 after a disconnection
        8:34:34 AMM122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC4(RTOS) running on Duet WiFi 1.02 or later
        Board ID: 08DGM-9T6BU-FG3S0-7J9FJ-3SJ6R-K86ZG
        Used output buffers: 1 of 20 (9 max)
        Static ram: 27476
        Dynamic ram: 98504 of which 0 recycled
        Exception stack ram used: 280
        Never used ram: 4812
        Tasks: NETWORK(ready,464) HEAT(blocked,1232) MAIN(running,3580) IDLE(ready,200)
        Owned mutexes:
        Last reset 00:03:27 ago, cause: power up
        Last software reset at 2018-11-25 07:51, reason: User, spinning module GCodes, available RAM 4712 bytes (slot 3)
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
        Error status: 0
        Free file entries: 9
        SD card longest block write time: 55.8ms, max retries 0
        MCU temperature: min 35.8, current 36.2, max 36.8
        Supply voltage: min 11.7, current 11.7, max 12.4, under voltage events: 0, over voltage events: 0, power good: yes
        Date/time: 2018-11-25 08:34:33
        Cache data hit count 746636395
        Slowest loop: 217.17ms; fastest: 0.07ms
        I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
        Bed compensation in use: none
        Heater 0 is on, I-accum = 0.5
        Segments left: 0
        Movement lock held by file
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is doing "M190 S90" in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 57.61ms; fastest: 0.00ms
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is running
          WiFi firmware version 1.21
          WiFi MAC address 84:f3:eb:82:db:5b
          WiFi Vcc 3.36, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 13336
          WiFi IP address 192.168.1.5
          WiFi signal strength -46dBm, reconnections 0, sleep mode modem
          dc42 administrators @siblues
          @siblues said in BlTouch randomly deploys probe twice.:
          That sounds like the on-board 5V regulator is no longer working. Is the I_5V_EN jumper still firmly in place?
          • sibluesundefined
            siblues
            Yes the jumper is still firmly on the terminals. I am at a loss trying to figure out why this happened.i tested the power supply and it is at 12.8v but when I test at the terminals on the board I get 2.3v. I guess the disconnections could have been that regulator? Any ideas on what may have caused this and what are my options now?
              @siblues, is your Duet still under warranty?
              • sibluesundefined
                siblues
                I just got it maybe two months ago .I am in the process of setting my printer up.i haven't even printed with it yet lol.I checked it was purchased from Filastruder on October 9th.
                  In that case, ask for it to be replaced under warranty.
                  • sibluesundefined
                    siblues
                    Would a bad or shorted heatbed cause something like nthis or do you have any ideas on what would cause this to happen.I know it could have been a bad regulator to start with but it seems weird that it worked fine for a few weeks and just suddenly stopped working?
                      No, a faulty heat bed might damage the bed heater mosfet but it shouldn't affect the 5V regulator. OTOH if you connected external devices to +5V then a prolonged overload might damage it.
                      • sibluesundefined
                        siblues
                        The only thing that changed was I installed a larger bed. I don't have any extra items connected to the board other than the necessary items to operate the printer.
                        • Nylkosundefined
                          Nylkos
                          I do not know if this is the case, but I had this happenning to me a few months ago.
                          I found out that my BLTouch wire were damaged. The BLTouch would "reset" and deploys like when turned on.
                          IMO, you might have a damaged wire or possibly problem with your connectors.
                          I hope this helps.
                          • sibluesundefined
                            siblues
                            I will check again to make sure but was your BlTouch working while it was doing this? Mine keeps working just fine while it is doing this. I do get quite a few the probe was triggered before move messages.
