PT100 Daughter boards
Order discussion
    terabyte
    Is there a plan to make PT100 daughterboards available for order as a separate item in a normal way?
      T3P3Tony administrators
      You should be able to order one from here:
      https://www.duet3d.com/DuetWifiAddons
      Cheers
      Tony
        terabyte
        Thanks,
        I did not see this link on the main page for some reason. That sounds great!
        However, I ordered the PT100 from Filastruder and did not realize that the complete kit has an amplifier board in it instead of the RTD daughterboard. I have placed a new order with Filastruder, but it is also not obvious how to do that. I had to order "Other part" quantity = 30… Too bad it is unlikely to be here before the weekend.
        2 out of 3
