Truthiness. Verified Truthiness.
I actually hadn't read the stall detection thread that's running around right now, and that link to the wiki will certainly be good for further reading. Obviously, the "reprap" goal is to find a "good enough" hack that is also cost effective. I will agree that the absolute position may be more out-of-reach, but the rotary encoder you discuss may not be.
The stall detection topic makes reference to several different stepper drivers. Which ones are used with the duet series... and if the best aren't used, what is the cost difference on that?
I would think that the tens of thousands of stepper motor based printers which work just fine would suggest that closed-loop system isn't really needed in most cases.
I would think that in your example of a "glob" stopping the movement you need to figure out why you have "globs" in the first place and why your printer couldn't push right past it in the second place.
That situation is not one I have encountered in hundreds of hours of printing.
Still the pursuit of a closed-loop system is still worth considering if the additional cost is too great.
Closed loop servos also have their own engineering issues, like feedback tuning, jitter, hunting, inertia matching, polling speeds, encoder resolution matching...
The way this typically goes is that someone builds a closed-loop feedback system for 3D printers, everybody goes “ooh, ahh” and then it gets minimal uptake due to added cost and complexity. Mechaduino is a good example; it has a really slick way to read stepper shaft position and had a successful round of sales, but it had kinks to work out and more complexity to deal with and after a year or so everybody kind of lost interest.
If you want to play with servo motion systems, the best ways to start are to either buy a prepackaged motor+encoder+drive that accepts the step/dir signals your Duet already outputs and handles the feedback loop on its own, or get into MachineKit with a Beaglebone setup where servo loops are baked into the controller code. Reinventing the wheel to do it internal to the Duet with some makeshift encoder rig doesn’t make a lot of sense to me.
@rcarlyle The most accurate machines in the machine shop that I work in are Wire EDM machines. The don't use encoders but instead use glass scales to detect movement. That way back lash in the couplers, ball screw nut and uneven wear in the lead screws don't have to be compensated for. The glass scale detects and reads the movement of the head in each direction very accurately. With a machine resolution of .00005".
Encoders are nice but they still only rely on the motor shaft movement and don't account for wear in the lead screw.
Even if you could have the printer head move with extreme precision, can you have the hot plastic squirt out with just as much precision?
In my opinion the reality is these printer are just glorified play-doe fun factories in that they just squirt stuff through a hole.
I have used indicators set up to confirm I am getting great repeatably with my X and Y axis. Much closer than my extruder can print.
@timcurtis67 said in Truthiness. Verified Truthiness.:
Couldn't agree more - (although I prefer the analogy of hot melt glue gun).
Milling is just whacking a piece of metal over and over, breaking small pieces off. EDM is just vaporizing a small piece of material over and over. Casting is just pouring a bunch of molten metal into a hole.
I don't get the point of over-simplifying a process that can be made as accurate or as sloppy as one works to achieve.
@rcarlyle The most accurate machines in the machine shop that I work in are Wire EDM machines. They don't use encoders but instead use glass scales to detect movement.
OK, I am going to be "That Guy".
A glass scale IS "an encoder". Attached to the final carriage instead of the motor shaft, which has tremendous advantages. Still, it is encoding position.
I think what you are saying is that they don't use rotary encoders on the motors. Which, as you point out, attaching the (glass scale) sensor to the final "control point" self-compensates for all backlash, etc. I have a mill that works this way, and it is great.
There's no absolute right or wrong answer to "open" vs. "closed" loop, nor to the kind of sensor and where it is attached when closing the loop.
However... there is tremendous market pressure to hold down cost. And open loop steppers "just work" in the vast, vast, vast majority of 3D print applications.
Furthermore, many of the proposed closed loop sensors, namely those that go on motor shafts, won't detect the two most common failures: A belt that jumps a tooth, or a pulley who's setscrew comes slightly loose and it can move just a little on the shaft.
Yes, an encoder/sensor on the final "control point" item, the effector or hot end or tool holder or whatever, could detect any mis-match... but those are even more complex and expensive. Sometimes, adding complexity to a system makes it LESS reliable. Sometimes.
So again, I'm not saying there is a right/wrong perspective here... I am saying that there is a pragmatic perspective, and it leans very strongly toward open loop steppers on 3D printers. Which is why there's thousands of models that have sold tens or hundreds of thousands of printers with open loop. At this moment, I'd be hard pressed to find a link to a closed loop 3D printer, that is not also a multi tens or hundreds of thousands of dollar commercial specialty unit. I'm sure they exist... they are just rare in the hobbyist market.
I’m of two minds about it. Closed loop offers intriguing possibilities but it has to be done just right to be any improvement. The biggest issue is it will cost more money, be more complicated (and more parts to fail) and it isn’t guaranteed to be an improvement. Unless you’re a big name manufacturer, add $30 per motor on your machine. I’ve even seen a few different examples where closed loop feedback made the print finish look worse.
Also, TMC drivers have eaten away some of the features once thought exclusive to closed loop.
@danal said in Truthiness. Verified Truthiness.:
Yep that's what I'm saying. A glass scale is a type of encoder. A much more accurate one over time for the simple fact that with age the driving forces behind any mechanical movement wear. Rotary encoders on the end of servos (like in most CNC mills) only read the shaft movement, and that is before the coupler even.
But truly my point was the fact that are encoders really necessary on a glorified hot melt glue gun machine? (Thanks Ian
If you like them and feel you will get better prints with them then by all means go for it.
