    Heater Fault oscillating curve
    • jaydevdaveundefined
      jaydevdave
      can any one help me control the temperature
      M307 H6 A200 C302.1 D25 S1.00 B0
      M570 H6 P10 T20 S120
      0_1544267619213_01.png ![alt text](image url)
        deckingman @jaydevdave
        @jaydevdave From the Wiki https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
        "................... If the temperature is not stable but oscillates around the target temperature even when the print head is stationary, increase the D parameter".
        Edit. That's assuming that the temperature is not being influenced by some external factor such as a part cooling fan switching on and off.
          jaydevdave
          1. Print head is not stationary, Print is running
          2. and Print head is not affected by Cooling fan
          Please suggest Parameter change.
            @jaydevdave said in Heater Fault oscillating curve:
            I already have - increase the "D" parameter. That's in your M307.
            • mrehorstdmdundefined
              mrehorstdmd
              Was it working OK and then starting doing this, or is this a new hot-end set-up problem?
