    Humidity sensor for Duet 2?...
    • nikkerundefined
      nikker
      @dc42 I know that a sensor can be added to monitor chamber temperature. Is it possible to add a humidity sensor to a filament box? Could this be a feature request as well as have it show up in DWC?
        DHT22 temperature and humidity sensors are already supported on the Duet WiFi/Ethernet and in DWC.
        • nikkerundefined
          nikker
          wow, I have read so much of the Duet documentation and have never seen that! @dc42 you are awesome! Thanks.
            To be fair to you, it's not well documented.
            • imrjundefined
              imrj
              I just got an HDC1080, which is much more accurate than a DHT11, and i tested to confirm....could you point to any documentation on how to attach with I2C ports? I can take care of the 3.3V with a small reg
              https://www.amazon.com/gp/product/B0785FNTHX
                RRF does not support temperature or humidity sensors connected via I2C, so you would need to make firmware changes to use it. It does support M260 and M261 commands to send/receive raw data over I2C.
