Displaying the IP address using the N520 command
N530 = octet 1
N531 = octet 2
N532 = octet 3
N533 = octet 4I suspect all you need is octet 4. You probably have to build out the whole IP address appending the octets and periods one at a time.
OK,, should each set of octets be on a seperate line or on one single line witht eh spaces counted out. Also is it possible that anyone out there has the display file for the duet wifi hd display? Even though it is HD the basic planning should be the same.
What screen do you use and how did you configure it on the duet wifi?
@patakopecek LCD 12864 and right now I am using a modified factury configuration obviously I have to change it. The first three lines of code are modified here. There is a guide that outlines how to program the menu screen, it is hared to do so far. If I take a few days I could get it done, but how has a few days?
I Would suggest that it is on a Meastro not a WiFi!
Sorry I did not make that clear this is the Maestro, perhaps I mispoke. At any rate the formatting and the question still stands is there any examples perhapos the menu from the Wifi can be translated over, can anyone post the menu files form the Duet Wifi as it lists the IP address on the HD screen
@3dmntbighker Do you have any menu code or formatting that could help with this, perhaps something that could copy and paste?
@novaprint Wifi doesnt support LCD 12864 as far as i know. Only Maestro does. So there are no menu files for Wifi.
@aidar There is code that lines up the commands for the wifi. The code the N commands in the wifi shoild be common between the two platforms. There is no alternaive st of copmmands for the siplay on the LCD screen versus the HD The commands are the same, I would like to see the commands, would someone please post them?
@3dmntbighker Do you have an example of lining up the N commands for this one, I wonder how many different ways the width, the decimals etc would need to be manipulated before I get it correct.
@novaprint Not sure what code and commands you are talking about. LCD 12864 and PanelDue are two completly different things. PanelDue has its own firmware and talks to board via serial connection. Btw PanelDue firmware is open source so if you want to look at it .. https://github.com/dc42/PanelDueFirmware/releases
@aidar I will take a look.
On a PanelDue, to find the IP address go to the Console page, press the keyboard icon and enter M552.
@novaprint said in Displaying the IP address using the N520 command:
No, I'm not displaying the IP on my display.
@3dmntbighker THis is the code that I have so far:
My code: the IP part appearstext R3 C5 F0 T"IP:"
value R3 C30 F0 W27 D0 N530 -
At present you have to display the 4 octets separately, for example:
value D0 N530
text T"."
value D0 N531
text T"."
value D0 N532
text T"."
value D0 N533 -
@dc42 said in Displaying the IP address using the N520 command:
value D0 N530
text T"."
value D0 N531
text T"."
value D0 N532
text T"."
value D0 N533thank you for that line of code, but at present, the display shows a series of asterixs (little stars) after each period. As if it is trying to show the information, but is somehow unable. I Had this unit connected to the internet last night and when I woke up it would not react to the same ISP numbers that it previously was assigned. The display of the little stars is consistent with the behavior that I was able to get before. The operating system is the latest from M3D. Just got it in November.
@dc42 Yes it is connected to the internet and I am getting yellow and green lights on the Connecting network wire.
What firmware version are you using? I don't think M3D has updated to 2.02 yet.
2.01 beta is the firmware that it shipped with. Do I need to update? Is that a new feature in 2.02?
