    Triggers for bed leveling
    1.5k
    • iDeveloundefined
      iDevelo
      I want to use 2 microswitches to level my bed. I would attach one switch to the left of the X carriage and one to the right. The X carriage would move to the left edge of the glass and lower until it activates the right switch and report the Z height. It would then move right of the glass and use the left switch to measure the Z height. It would do this front and back. I would then end up with a set of 4 readings that i can adjust to level the bed.
      Would these work in a routine to do that?
      M581: Configure external trigger
      M582: Check external trigger
      Basically what the BCN guys do on the sigma
      https://youtu.be/SZ232J-dnkA
        If you use NC switches and wire them in series, you can use them just like a single switch Z probe.
        • iDeveloundefined
          iDevelo
          Ok fair point. So if i have multiple Z switches how can i use those switches to read the Z height against 0. For example my printer starts with a Z height of 0. Then i move along the bed edge and probe with the switch but as soon as the switch hits the bed it reports 0 Z height.
          G1 Z-200 S1 F100 will stop fine when it hits the bed but this command sets the height to 0?. How do i read the actual height? If i can manage to read the height i can then do the simple math for adjustment.
          Thanks for your help!
          • croadfeldtundefined
            croadfeldt
            When you say "How do I read the actual height?", is your intent to determine the Z probe offset from 0?
            • StephenRCundefined
              StephenRC
              Sounds like he needs to make a macro to use G30: http://reprap.org/wiki/G-code#G30:_Single_Z-Probe
              • iDeveloundefined
                iDevelo
                Thanks guys. I won't defend myself, I was thinking G30 is strictly for an IR probe…
                • iDeveloundefined
                  iDevelo
                  Just to confirm I can use P5 on the M558 command and use the pins on the IR probe connector for the switches is series instead of going the E0 route?
                    I normally recommend using E0 for a switch-type Z probe because it has filtering, an indicator LED and a lower value pullup resistor. However, using the GND and IN pins of the Z probe connector will probably work OK with NC switches.
                    • iDeveloundefined
                      iDevelo
                      Thanks for all your help guys. I've now got a working bed leveling system. I'm just starting to write the Javascript now that reads the 4 point output and calculates how many turns in what direction of what knob to turn to level the bed 🙂
                      Thanks again!
