    Paneldue freezes after print begins
    1.5k
    • StephenRCundefined
      StephenRC
      AFAIK, it's a known bug.
        It's been reported by a few others. Please can you tell me:
        1. What are the first 20 or so lines of gcode in the file you were printing? In particular the bit where it heats the bed and waits.
        2. Does the problem occur only when you start the print from PanelDue, or does it also occur if you start the print from the web interface?
        • DjDemonDundefined
          DjDemonD
          Okay this is one file
          [[language]]
          ; generated by Slic3r 1.2.9 on 2016-10-09 at 17:07:59
          ; external perimeters extrusion width = 0.30mm
          ; perimeters extrusion width = 0.24mm
          ; infill extrusion width = 0.40mm
          ; solid infill extrusion width = 0.40mm
          ; top infill extrusion width = 0.40mm
          M107
          M190 S130 ; set bed temperature
          G28                                                       ; home all axes
          G28                                                      ;home again in case of problem
          M104 S160                                         ; preheat extruder without waiting
          G32                                                     ;autocalibration leave OFF until print bite arrives
          M109 S250    ; Set extruder temp
          G21 ; set units to millimeters
          G90 ; use absolute coordinates
          M82 ; use absolute distances for extrusion
          and this is another
          [[language]]
          ; generated by Slic3r 1.2.9 on 2016-10-09 at 10:13:46
          ; external perimeters extrusion width = 0.40mm
          ; perimeters extrusion width = 0.67mm
          ; infill extrusion width = 0.67mm
          ; solid infill extrusion width = 0.67mm
          ; top infill extrusion width = 0.67mm
          M107
          G28                                                       ; home all axes
          G92 E0
          G1 E-1.40000 F3000.00000
          G92 E0
          G1 Z0.600 F9000.000
          G1 X21.800 Y-25.928 F9000.000
          G1 Z0.560 F9000.000
          I start all prints from the web interface.
          If its a known issue then its no trouble, I just expect to look over after starting a print to see my bed temp rising, and it isn't on the panel. So I look at the screen instead and it's fine.
          www.precisionpiezo.co.uk
            What I think is happening is that the PanelDue notices the status change to "Printing" and sends M36 to ask the Duet for details of the file being printed. By then the M190 command is already being executed. M36 cannot yet be executed concurrently with any other commands, so it is held in a queue. Meanwhile the status requests that PanelDue sends are queued after the M36 command.
            If you can arrange for the starting code to have a G4 P2000 command before the M190 command, that should allow the M36 command to complete before heating commences.
            The problem will be fixed when we implement full concurrency of non-conflicting commands, which is planned for version 1.16 but might get postponed to 1.17.
            • DjDemonDundefined
              DjDemonD
              Thanks David, that pause is easy enough to do, I'll try it later on tonight.
                StephenRC
                I added the G4 P2000 before the M190 and the PanelDue showed the bed temp increasing.
                • DjDemonDundefined
                  DjDemonD
                  I could add this manually or by some post processor, after gcode generation by slic3r but I cannot add it before the M190 as slic3r's custom gcode is added after M190 and starts where I have G28. I'll just carry on for now and wait until it gets changed in a later version. Thanks for the help though.
                    StephenRC
                    If you put the M140/M190 and M104/M109 in the startup gcode, Slic3r will use those.
                    Here's my Slic3r startup gcode:
                    T0 ; make sure the only hotend is selected
                    G4 P2000 ; pause workaround for the rrf/paneldue bug
                    M190 S[first_layer_bed_temperature]
                    M104 S[first_layer_temperature]
                    G28 ; home all axes
                    G32 ; bed calibration - RRF
                    M109 S[first_layer_temperature]
                    M117 [input_filename_base]
                    End gcode:
                    M104 S0 ; turn off temperature
                    M140 S0 ; turn off bed
                    G28 X0 ; home X axis
                    G1 Y300 ; move y to rear
                    M84 ; disable motors
                    • DjDemonDundefined
                      DjDemonD
                      Thanks Ill try a variant of that.
                      • DjDemonDundefined
                        DjDemonD
                        Yep that worked thank you.
