DuetWiFiFirmware minor release 1.15c
Firmware installation
11
79
12.2k
    deckingman
    Now you are saying that you have 4 (or 5 ) extruders when previously you said 2. I have no idea how you can be driving them all when the Duet WiFi on it's own only supports 2 extruders. Sorry but I'm going to have to give up with this.
      T3P3Tony administrators
      Guy, how is the jig operated? Do you have 4 seperate extruder motors and 1 hotend or 1 extruder motor and the input is somehow switched?
        guywinslow
        4 separate extruder motors and 1 hotend. Its just a train track for the boden tubes. the jig is not connected to any electronics. just maniacal. no moving parts. Any one can print it
          @guywinslow:
          OK, but the Duet WiFi only has 2 extruder drive outputs, so how are you driving the other 2 extruder motors?
            guywinslow
            not right now, wating for the new expansive board
              guywinslow
              Sorry Expansion board
                guywinslow
                Got [dc42/RepRapFirmware] M572 Loosing steps in XY email, was able to reproduce on my printer, but it made my over extrusion on line changes worse. Hop info helps
                  guywinslow
                  OK, i put new E firmware in. and Still had the same problem. So i put this into the Config.g file:
                  M572 D0 S0.00 ; Set extruder 0 pressure advance
                  M572 D1 S0.00 ; Set extruder 1 pressure advance
                  problem is not as bad. in fact just a little bit of Extrusion error now when the program moves to the beginning of the next line
                    guywinslow
                    Ok, got it to work, this is what i ended up with for a Configuration:
                    ; Configuration file for RepRap Ormerod
                    ; RepRapPro Ltd
                    M111 S0 ; Debug on
                    M550 PTricolour Mendel WIFI
                    M551 Pgdww1620
                    M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEA ; Set the MAC address
                    M552 S1 ; Enable WiFi
                    M555 P2 ; Set output to look like Marlin
                    M575 P1 B57600 S1 ; Comms parameters for PanelDue
                    M906 X800 Y1000 Z800 E800:800 ; Motor currents (mA)
                    M305 P0 R4700 T10000 B3988 ; set bed thermistor parameters
                    M307 H0 A117.7 C395.8 D1.8 B0
                    M307 H1 A759.1 C95.9 D5.8 B0
                    M574 X0 S1 ; Set endstop configuration
                    M574 Y2 S0 ; Set endstop configuration
                    M574 Z0 S1 ; Set endstop configuration
                    M569 P0 S0 ; Set X Axis Direction
                    M569 P1 S1 ; Set Y Axis Direction
                    M569 P2 S0 ; Set Z Axis Direction
                    M569 P3 S0 ; Set E0 Axis Direction
                    M569 P4 S0 ; Set E1 Axis Direction
                    M558 P1 X1 Y0 Z1 ; Set Z probe type
                    M92 X100.25 Y100.25 Z4001.50 E420.00:420.00 ; Set axis steps per unit
                    M570 S180 ; Set heater timeout
                    M667 S0 ; set Cartesian mode
                    M350 X16 Y16 Z16 E16:16 I01 ; Set microstepping mode
                    M563 P0 D0 H1 ; Create tool 0 = Color 1
                    M563 P1 D1 H1 ; Create tool 1 = Color 2
                    M563 P2 D2 H1 ; Create tool 2 = Color 3
                    G10 P0 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 0 operating and standby temperatures
                    G10 P1 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 1 operating and standby temperatures
                    G10 P2 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 2 operating and standby temperatures
                    M106 P2 T45 H1 ; Fan control, Thermostatic on Heater H1
                    ;M566 X600 Y600 Z5 E10 ; Set allowable instantaneous speed change
                    M201 X800 Y800 Z15 E1000:1000 ; acceleration tweaks for improved finish
                    M203 X15000 Y15000 Z150 E3600:3600 ; speed tweaks for improved finish
                    M208 X200 Y200 Z120 ; set axis max travel
                    M208 X0.0 Y0.0 Z0.0 S1 ; set axis minimum (adjust to make X=0 the edge of the bed)
                    G21 ; Work in millimetres
                    G90 ; Send absolute coordinates…
                    M83 ; relative extruder moves
                    G31 P500 Z1.30 ; Set the probe height and threshold PLA = 0.65, ABS = 0.75
                    T2
                    M500 ;Store setting in EEPROM
                      Are you certain that setting nonzero extruder pressure advance in M572 is causing a problem? Also, have you checked on the web interface or by sending M115 that you really are running firmware version 1.15e? Firmware updates do fail sometimes.
                        guywinslow
                        No Actually, it just helped. Things started working right when i put the M667 S0 and the M500. I can set the M572 D0 S0.00 to something other then zero. Whats a Recommended value to start with?
                          guywinslow
                          oww, yes i am running firmware version 1.15e. At least that is what the web interface reads out.
                            @guywinslow:
                            Try S values between 0.05 and 0.25. If you are using more than about 2mm of retraction then be prepared to reduce it when you use high S values. For example, using S0.25 will add about 1mm of retraction at the end of a fast printing move.
                              guywinslow
                              Ok, i set the pressure advance to this, and started a test print
                              M572 D0 S0.05 ; Set extruder 0 pressure advance
                              M572 D1 S0.05 ; Set extruder 1 pressure advance
                              When i got to the 1.00mm Z height, the Y axes started to jump, as if it was moving, braking, moving, braking. i killed the print as it was getting pretty load and i was afraid it was going to brake the printer.
                                guywinslow
                                Ok, Installed the 1.16 Alfa. The Ste-per motor noise is Still there. I did notes its only on coordinated moves. I can calibrate, move the table around and extrude and all is well. But i run a Print and the noise is there. Note - don't get me wrong this is not machanical, its motor drive control
                                  guywinslow
                                  OK, This probably needs to be under the next release of the Firmware (dc42/Version 1.16 beta 2), but i could not find a Blog or forum for it. So hear is the info:
                                  • Ste-per motor noise is down to a Dull rorre (Sounds like a Skipping Hart beet). Its still coming out of extrude motor when i listen to it through a Sc-row driver handle.
                                    Temperature control, the best i can do with Auto-tune is the hot end doing +- 0.3. it is holding that. at lest for the short print times i have been testing.
                                  Going to let this test print finish to see if it finushes.
                                    Bobblejot
                                    you have
                                    Should it not be
                                    M350 X16 Y16 Z16 E16:16 I1 ; Set microstepping mode
                                    or
                                    M350 X16 Y16 Z16 E16:16 I0 ; Set microstepping mode
                                    Depending on whether or not you are using interpolation or not?
                                    Also your X and Y axis steps per millimetre are the same but your motor currents are different? are you using different motors?
                                      guywinslow
                                      Same motors, one is the Y axes, heavy mechanism, it gets slope if there the same. will fix the M350 command. I uploaded the Firmware (dc42/Version 1.16 beta 3). noisy in the steeper motors is gone.
                                        guywinslow
                                        Was ruining another test print. 4mm x 4mm 75mm square. The over extruding started at about 3mm. Looks like its over extruding, then under extruding. Then go's back to normal for 60mm, then it dos it age-an.
                                          @guywinslow:
                                          That sounds to me like either a problem with your extuder drive, or inconsistent filament diameter.
