    PS_ON no longer going low.
    1.9k
      Yes, the gate voltage should change. The state of the PS_ON output pin from the processor is shown by DWC, and you can also check it by sending M408 S2 and looking for atxPower in the response. If it shows that ATX power is on but the gate voltage is still zero, then there is either a bad soldered joint on the SAM pin 106 (most likely IMO), or on the mosfet gate pin, or a PCB fault (least likely IMO). If instead the mosfet had developed a gate to source short then I would expect ATX power to read as off even after you turn it on.
      • croadfeldtundefined
        croadfeldt
        Here's output from checking pin state via M408.
        After fresh power cycle.
        Push DWC ATX off
        3:14:09 PM M408 S2
        {"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0],"xyz":[0.00,0.00,0.00]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,0.00],"speedFactor":100.00,"extrFactors":[100.00]},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":27.3,"active":-273.1,"state":0},"heads":{"current":[27.5],"active":[0.0],"standby":[0.0],"state":[2]}},"time":135.2}
        Push DWC ATX On
        3:14:26 PM M408 S2
        {"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0],"xyz":[0.00,0.00,0.00]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,0.00],"speedFactor":100.00,"extrFactors":[100.00]},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":27.3,"active":-273.1,"state":0},"heads":{"current":[27.5],"active":[0.0],"standby":[0.0],"state":[2]}},"time":152.4}
        Type M80 on DWC GCode Console
        3:14:19 PMM408 S2
        {"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0],"xyz":[0.00,0.00,0.00]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,0.00],"speedFactor":100.00,"extrFactors":[100.00]},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":27.3,"active":-273.1,"state":0},"heads":{"current":[27.5],"active":[0.0],"standby":[0.0],"state":[2]}},"time":145.7}
        Type M80 on PanelDue Console
        3:17:29 PMM408 S2
        {"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0],"xyz":[0.00,0.00,0.00]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,0.00],"speedFactor":100.00,"extrFactors":[100.00]},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":27.3,"active":-273.1,"state":0},"heads":{"current":[27.5],"active":[0.0],"standby":[0.0],"state":[2]}},"time":335.0}
          So atxPower is always returned as zero. That suggests to me that the processor output pin is either not working, or has got set to the wrong mode by the firmware, or is shorted to ground. One possibility is that the mosfet has a gate to source short. You could check that with a multimeter.
            croadfeldt
            Using the below GDS layout assumption here are the results of checking the Mosfet.
            G–-- V_IN +
            ----- D
            V_IN GND
            S----
            Continuity check
            G - D - open
            G - S - open
            D - S - open
            G - GND - open
            D - GND - open
            S - GND - closed
            Resistance check.
            G - D - 0 / Open
            D - S - 0 / Open
            G - S - 4.69K
            G - GND - 4.70K
            D - GND - 0 / Open
            S - GND - 3
              That all looks OK. There is a 4K7 pulldown resistor between gate and ground.
              Please try sending M42 P79 S1 and then use M408 to read back the ATX power status.
                croadfeldt
                Did a fresh power cycle, had to, DWC was not responding after sitting idle.
                Output from M408 after M42 I/O pin command.
                5:57:40 PM M408 S2
                {"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0],"xyz":[0.00,0.00,0.00]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,0.00],"speedFactor":100.00,"extrFactors":[100.00]},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":27.5,"active":-273.1,"state":0},"heads":{"current":[27.6],"active":[0.0],"standby":[0.0],"state":[2]}},"time":41.3}
                  I can only think of these explanations:
                  1. The microcontroller has developed a fault in the output driver for that pin which can no longer output high.
                  2. An as yet unknown firmware bug has been triggered by your configuration and is reprogramming the function of that pin so that it is no longer behaving as a simple output. You could temporarily switch to one of the standard config.g files and/or an earlier firmware version to see if you can get it working again.
                    croadfeldt
                    It appears #1 is the case. Will reach out to filastruder and discuss getting a replacement. Very much appreciate your help tracking this!
                    Firmware version 1.15e - virgin sys-CoreXY configs from sd card
                    9:27:42 AM M408 S2
                    {"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0],"xyz":[0.00,0.00,0.00]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,0.00],"speedFactor":100.00,"extrFactors":[100.00]},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":25.0,"active":-273.1,"state":0},"heads":{"current":[-273.1],"active":[0.0],"standby":[0.0],"state":[0]}},"time":94.5}
                    Firmware version 1.15c - virgin sys-CoreXY configs from sd card
                    9:30:46 AM M408 S2
                    {"status":"I","coords":{"axesHomed":[0,0,0],"extr":[0.0],"xyz":[0.00,0.00,0.00]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,0.00],"speedFactor":100.00,"extrFactors":[100.00]},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":24.9,"active":-273.1,"state":0},"heads":{"current":[-273.1],"active":[0.0],"standby":[0.0],"state":[3]}},"time":61.4}
                      croadfeldt
                      Received replacement today, Works perfect. Thanks Tim and Dave!
                      • elmoretundefined
                        elmoret
                        Excellent, thanks for the update!
