    Printing Towers Issue
    2.4k
      The usual problem with printing small towers is that each layer prints so quickly that a layer hasn't time to solidify before the next layer is printed. Most slicers have a "minimum layer time" parameter that you can increase to control this. A print cooling fan will also help if you are printing PLA.
      Your grey filament may need a lower extrusion temperature than the green filament.
      • piankocundefined
        piankoc
        That's what i was thinking too. But I have 2 part cooling fans blowing at 100% at this point in the print and tried temps so low that it stopped extruding. I have simplify3d and currently have on "adjust printing speed for layers below 15 seconds, allow reductions down to 20%" I'll increase the percentage and see if that helps. But the way its going I don't think it will fix it.
        Could this setting cause the infill to be "weak" and appear like it is under-extruding?
        • jmjcokeundefined
          jmjcoke
          The chimera hates retraction. I had a problem with heat creeping up past the heat break, I did not get good enough coverage of thermal paste between heat breaks and heatsink, this caused the filament to swell in the upper part of the heat break and then under extrude until that "plug" of swelled filament pushed through. I also have found that installing the silicone covers E3D came out with has reduced the radiant heat onto the part from the bottom of the heater blocks.
          Joshua Coke
          Trick Laser Metal Max with Smart Effector
          Duet Wifi
          Zesty Nimble
          Mosaic Pallette+
          At work
          Renishaw AM250/400/ RenAM500M/500Q Powder Bed Fusion (Metal 3D Printers)
          • piankocundefined
            piankoc
            I didn't think of heat creep, but wouldn't that cause issues on any part I print? After this happens I leave everything on and try again and the base of the part prints well but once it gets to the towers the issue comes up again.
            • piankocundefined
              piankoc
              on a side note jmjcoke, did you get the silicone covers onto your chimera? I can get one on but have trouble getting 2 on and have been searching for a good way to do it but haven't found one yet. right now i just have 1 on and 1 off
              • jmjcokeundefined
                jmjcoke
                I have my heater block at weird angles, when I get back home in a few days I will post a photo. My under extrusion problems changed based on the part and the number and amount of retractions, that print has be sitting for awhile and I seem to remember that I also found that I was crushing the filament by adjusting the extruder pinch too tight, this lead to the same type of weird under extrusion issues with chimera that I never had with E3D V6.
                Joshua Coke
                Duet Wifi
                Zesty Nimble
                Mosaic Pallette+
                At work
                • jmjcokeundefined
                  jmjcoke
                  Oh and cool your extruder drive motor, if it gets hot at all this will deform the filament as well.
                  Joshua Coke
                  Duet Wifi
                  Zesty Nimble
                  Mosaic Pallette+
                  At work
                  • piankocundefined
                    piankoc
                    yeah, i had issues with that on my last delta, extruders are cool to the touch on this one.
                    • piankocundefined
                      piankoc
                      Well, it isn't retraction i turned it off and got the same weak under-extruded towers
                      • jmjcokeundefined
                        jmjcoke
                        Have you done the 100mm filament feed check?
                        Joshua Coke
                        Duet Wifi
                        Zesty Nimble
                        Mosaic Pallette+
                        At work
                        • piankocundefined
                          piankoc
                          yeah and e steps are perfect.
                          Just fixed it. was about to give up and realized I never set up my filament cleaner with a little canola oil on the new printer. just did a test piece and works like a charm on the first try. I guess there was a little too much friction in the hot end that the canola oil is helping with. Forgot how much it helped on my other delta.
