    Stop during printing
    1.4k
    • synergy41undefined
      synergy41
      Can this be the cause of the wrong setting of the "JERK"?
      I LOVE MY DUET WIFI
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
      Duet WiFi Server Version: 1.26
      Duet Web Control 3.4.1
      Cura 4.10
        dc42 administrators @synergy41
        @synergy41 said in Stop during printing:
        My printer stops at every turn for half a second, which causes some kind of stuffing.
        Please explain what you mean by "turn". Do you mean it pauses at every corner of the cube? Or once per layer?
        Please post your config.g file.
          synergy41
          Hello David,
          The printer stops at the end of each layer.
          I tried with 2 different slicer "Cura and Simplify 3d" and the phenomenon is identical.
          I am attaching my Config file.
          thank you
          0_1545996754847_config (4).g
          I LOVE MY DUET WIFI
          Cura 4.10
            I don't see anything in your config.g that would explain it, so I'll need to see the GCode file too.
              synergy41
              Hello David.
              All my best wishes for this new year 2019.
              I send you as asking for my G.CODE file.
              thank you
              0_1546367486096_cube 25 v2.gcode
              I LOVE MY DUET WIFI
              Cura 4.10
              • Wyvernundefined
                Wyvern
                I can't read any of the config settings, but running it through the simulator I see what you mean, it goes around goes back, pauses then goes around again.
                I see a gap in the cube, which either means you sliced it with coasting on or, there is no junction there and it treats it as a second geometry- also if the object is slightly thicker than one extrusion width, but to thin for a second extrusion line, it will try to stitch it together.
                Also combing can cause this unnecessary pause.
                Try a different model to print.
                • OwenDundefined
                  OwenD
                  In Cura that can. be caused by your minimum layer time and lift head settings
                  If the printer does the layer faster than the minimum time even at the minimum speed set, it will pause (and lift the head)
                  Not sure if the amount the head lifted is arbitrary or set by Z Hop.
                  https://ultimaker.com/en/resources/52674-cooling
                    At each layer change it does these operations:
                    G92 E0.0000
                    G1 X12.260 Y-8.660 E-2.0000 F1080
                    G1 X12.260 Y-7.260 F1080
                    ; layer 12, Z = 1.888
                    G1 Z2.028 F1002
                    G1 X12.260 Y-12.260 F5400
                    G1 Z1.888 F1002
                    G1 E0.0000 F600
                    The last line tells it to re-prime 2mm of filament at 10mm/sec. That will take 0.2sec. Is that the length of pause you observe?
                    synergy41undefined 1 Reply Last reply Reply Quote 0
                      synergy41 @dc42
                      @dc42Yes it is around this time lapse
                      I LOVE MY DUET WIFI
                      Cura 4.10
                        So if you want to reduce the pause time, use a faster re-prime speed in your slicer settings.
                          synergy41 @dc42
                          @dc42 Thanks for the answer David,
                          unfortunately I am limited by the speed of withdrawal of my extruder "ED3" this one mache filament when I put a speed too high.
                          On the other hand I try to print a cube in vase mode and I have no problem, I must find the difference in my setting in my profile Simplify 3D.
                          I LOVE MY DUET WIFI
                          Cura 4.10
