    (solved) G28 Error: Bad command
    2.2k
    • Karimundefined
      Karim
      Hey Stephen Thanks, That fix the first error.
      If I move Z axis down 5mm or 10mm and then try home Z axis only, I get this below. I am using a mini differential IR height sensor. I can home X Y U fine. But Z axis only home when I home all axis. Don't know if this is how it suppose works.
      G28 Z
      Error: Bad command: ''' Home Z using the Z probe mounted on the X carriage'''
      Error: G0/G1: insufficient axes homed
        You need to add S2 to moves of axis that haven't been homed yet. In your case it might just be easier to always home x and y first.
        • Karimundefined
          Karim
          Ok, After I home X Y U & Z axis, Everything looks ok, no errors in log, But if I move Z axis down say 10mm and try homing Z axis I get this G28 Z , Error: G0/G1: insufficient axes homed . I am just trying to make sure that Z axis is ok.
          deckingmanundefined Stephen6309undefined 2 Replies Last reply Reply Quote 0
            If you compare the example homing files here: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_files to what you have you'll see what I mean about missing S2 from your G1 moves that try to move an axis before it's been homed.
            Also take care with G90 and G91 to ensure you're in the right coordinate mode for the moves you want to be doing. Do you want to go to Z5, or just move the bed by 5mm?
              deckingman @Karim
              @karim Are you saying that if you home all, everything works fine but if you just want to home Z you get the error? It's a long time since I checked but it always used to be the case that you have to home X and Y before you can home Z, which makes sense if you use a probe.
              • Stephen6309undefined
                Stephen6309 @Karim
                @karim They way I fixed my homing files: In each added S2 to all movements that didn't involve the endstops, the S1 lines.
                • Karimundefined
                  Karim
                  Here a video explaining what I am trying to say. This might be ok,
                  https://youtu.be/BKMrRjuZcC8
                    Phaedrux Moderator @Karim
                    @karim So the homeall button turns red when you hit home z to indicate that the machine is no longer fully homed. If the home z were able to complete successfully, the homeall button would turn back to homed state.
                    Can you post the contents of homez.g as it is now?
                    • Karimundefined
                      Karim
                      ; Home Z using the Z probe mounted on the X carriage'''
                      G91
                      G1 Z4 F200 ; raise head 4mm to keep it clear of the bed
                      G1 U429 F2000 ; make sure the U carriage is out of the way
                      G90
                      G1 X245 Y200 F2000 S2 ; move to bed centre for probing
                      G30 ; probe the bed and set Z height
                        And if you change it to this, what happens?
                        G91
                        G1 Z4 F200 S2 ; raise head 4mm to keep it clear of the bed
                        G1 U429 F2000 S2 ; make sure the U carriage is out of the way
                        G90
                        • Karimundefined
                          Karim
                          @phaedrux said in G28 Error: Bad command: ''' Now home Z using the Z probe''':
                          S2 Make the U Axis goes into the endstop. Replace S2 to S1 fix that.
                          Now Z axis works but something wired now, look at the video when homing Z axis, X axis move about 20mm then Z home.
                          https://youtu.be/Her4tOeW25w
                          ;Home Z
                          G91
                          G1 U422 F2000 S1 ; make sure the U carriage is out of the way
                          G90
                          ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool v2 on Sat Dec 01 2018 16:55:23 GMT-0800 (Pacific Standard Time)
                          G91 ; relative positioning
                          G1 S1 X-435 Y-400 U422 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                          G1 S1 X-10 Y-10 U10 F360 ; move slowly to X and Y axis endstops once more (second pass)
                          ;Now home Z using the Z probe'''
                            As I said before, you need to pay attention to G90 and G91
                            G90 moves to the absolute position on the bed
                            G91 moves the amount relative to the current location
                            So for your home all it looks like you're still in relative positioning when you should be in absolute positioning to place the print head for probing Z
                            ; homeall.g
                            G90 ; absolute positioning
                            That should get your print head into the same location for both homeall and homez. Now that may not be the position you expect it to be in, but you can modify that by just changing the coordinates for both.
                            I suspect that your X endstop position is actually a bit off the side of the bed.
                            • Karimundefined
                              Karim
                              @karim said in G28 Error: Bad command: ''' Now home Z using the Z probe''':
                              ;Home Z
                              G91
                              G90
                              I think I got now. Machine Status shows X185 Y210
                              ;Home Z
                              G91
                              G90
                              G1 X185 Y210 F2000 S2 ; move to bed centre for probing
                              • Karimundefined
                                Karim
                                Thank you. This was driving me nuts.
