Issues with M106 and naming of Fan with C option
I recently updated the firmware from 2.01 to 2.02
on a Duet wifi 1.04 board- Firmware: 2.02(RTOS) (2018-12-24b1)
- WiFi Server Version: 1.21
- Web Interface Version: 1.22.6
I noticed that my hotend fan wasn't running
it turns out there may be a bug when using the C option to name a fan with the M106 commandIt used to be like this in the config
M106 P0 S0 I0 F31 H-1 B1 CPartFan1 ; Used to cool the part M106 P2 S0 I0 F31 H1 L1 T60 CHotendFan1 ; Used to cool the hotend However I noticed when running this at the console I'd get spurious errors like this
Error: M106: Logical pin H0 is not available to use for fan 2
It was almost as if the name of the fan couldn't exceed 7 characters for fan 2, or 1 character for fan 0Removing the Fan naming fixed the problem
M106 P0 S0 I0 F31 H-1 B1 ; Used to cool the part M106 P2 S0 I0 F31 H1 L1 T60 ; Used to cool the hotend Sorry for raising this on github originally btw (I should have read the Readme).
I belive the format for name is C"name", so you should try : M106 P0 S0 I0 F31 H-1 B1 C"PartFan1"
@aidar said in Issues with M106 and naming of Fan with C option:
That's correct. In general, string parameters in GCode commands must always be quoted, except for a few older commands that accept filename parameters, where the quotation marks are optional.
