    Error: motor phase A and phase B disconnected on drivers 2
    18
    6.3k
    • garyd9undefined
      garyd9
      FYI, I'm getting this same error on "2.02RC2(RTOS) (2018-09-07b2)"
      Only got it once, and really didn't even notice it until 10 minutes later. The printer wasn't printing anything at that time, but I might have been going through my "assisted manual leveling" routine. If so, and if it's in relation to my Z motor, my bed leveling routine does move Z slowly (for detecting a bltouch.) I didn't even see the error message until after I started a print (which is working fine.)
      Config.g is here: https://drive.google.com/open?id=1v9pR4ZOSNdoJxDbj4_IW-H9HO2PL0_oR
      bed.g is here: https://drive.google.com/open?id=15ya2fTVWHlyoPdo_iMwawhVKCId2HUlc
      and.. homeall.g is here: https://drive.google.com/open?id=153vnwFq9XBlJzI06V4ZoKemcK2k8DVzE
      I think those are all the files related. If you need more, please let me know.
      Take care
      Gary
      • Helder_Silvaundefined
        Helder_Silva @dc42
        @dc42 Thanks for the followup in a few days i will test it
        Good Work
        • kuhnikuehnastundefined
          kuhnikuehnast
          Get the same error on 2.02RC2(RTOS) (2018-09-07b2). Heated up the Hotend and the bed and Uploaded a file to print- then it happend. (Duet Wifi 2 v1.03 - on my other Duet, a v1.04 it didn't happen yet)
          • Reckhamundefined
            Reckham
            the problem has been solved. - at least for me.
            I had the same issue today:
            It has been caused by wiring. I have seen that 1-2 of the 4 cables have been a little unloosen and the cable diameter had been reduced. This is why the motor hadn't had enough voltage and this caused the problem.
            Check your wiring guys 😉
            • madmattcoundefined
              madmattco
              Got a single line of motor failure just now.
              https://puu.sh/CrHOD/b8e12dd972.png
              https://puu.sh/CrHQa/96b01477be.png
              https://puu.sh/CrHRb/4b31e2f123.g
              • jckrayundefined
                jckray
                I have also been getting this error for both phase A and B on driver 2. Please let me know if there is any information I can provide to help get this bug fixed. The exact same message is present on all 4 of our printers with the same hardware running Firmware 2.02
                John
                Founder of Hydra Research LLC, developers of the open-source 3D printers and providers of 3D printing services.
                https://www.hydraresearch3d.com/
                  @madmattco and @jckray, please let me know:
                  1. Which Duet you are using;
                  2. What M906 motor current you are using on the motor(s) affected;
                  3. What motor(s) you are using;
                  4. @madmattco, please confirm that you are using firmware 2.02 release, not a RC version.
                  jckrayundefined madmattcoundefined 2 Replies Last reply Reply Quote 0
                  • jckrayundefined
                    jckray @dc42
                    I am using Duet WiFi V1.04
                    Motor current is 320
                    Two Z motors in series rated at .4A (https://www.omc-stepperonline.com/linear-motor/nema-17-external-34mm-stack-04a-lead-8mm031496-length-300mm-17ls13-0404e-300g.html?mfp=181-lead-screw-length-mm[300])
                    Could this be an issue with low current motors, especially when in series? I plan to switch to 1A Z motors eventually.
                    John
                      Yes, I think it's caused by using 2 low current motors in series. Try connecting them in parallel to just one of the Z motor connectors (put the 2 jumpers back in the other) and double the current.
                        madmattco @dc42
                        I'm running a maestro.
                        All motors are set to 1 amp.
                        The motors are on an anycubic kossel linear plus. to my knowledge the specs are as follows.
                        Motor Type: Bipolar Stepper
                        Voltage Rating:3.3V DC
                        Rated Current/phase: 1.5A
                        Phase Resistance:2.2ohms ± 10% (20 C)
                        Step Angle: 1.8 deg.
                        Phase Inductance:3.8mH ± 20%(1kHz 1V rms)
                        I am running the 2.02beta2(RTOS) (2018-08-30b3)
                          Upgrade your firmware to the 2.02 release.
                          • JohnnyBeeGoodundefined
                            JohnnyBeeGood
                            Two weeks ago I had a shaft of a nema 17 break, so had to do some maintenance to my CoreXY.
                            Was finished powered the Duet Maestro on and got this message:
                            Warning: motor phase A may be disconnected reported by driver(s)
                            Warning: motor phase B may be disconnected reported by driver(s)
                            Gives it on all drivers.
                            So had to find where this problems was coming from, config? firmware?, wiring?, nothing worked...
                            So I have quite a few Maestro's had 3 from the fitforlauch campaign and had 2 whose U3 burnt out... still need to get the warranty on them.
                            Hooked up a new Maestro and it worked.
                            Two days ago on the same machine I had to rebuild the extruder, finished today and getting the same bloody error.
                            I am running 2.02(RTOS) Motor Currents, M906 X1200.00 Y1200.00 Z1200.00 E1200.00 I70;
                              dc42 administrators @JohnnyBeeGood
                              I see that you've created another thread about this, so I will close this one.
