    Why am I having to run with an extrusion multiplier of 60%?
    143
    28.4k
    • Bobblejotundefined
      Bobblejot
      I also have a couple of titans and run them at the suggested 419 steps per mm on two different machines both running 1.75mm filament with no issues at all. Both my titans have bog standard 1.8° 1.68A Nema 17s.
      I also run E3d V6 hotends with 0.4mm Nozzles and use simplify 3d with a 0.4mm fixed extrusion width and an extrusion multiplier of 1.
      @DjDemonD 290 seems extremely low.
      I don't have mixing hotends though so cant comment on that.
      Have you tried setting the extruders only to non-interpolated microstepping and trying again? it shouldn't make a difference but you never know.
      • DjDemonDundefined
        DjDemonD
        It might be low but its not under-extruding, my objects print with extrusion multiplier in slic3r at 1.00.
        I am using pancake 20mm 1.8 deg nema 17's, but this shouldn't make a difference to the steps/mm or gearing of the extruder.
        www.precisionpiezo.co.uk
        • Dougal1957undefined
          Dougal1957
          I am also using a Titan with 20mm Pancake motor and have no under/over extrusion my S3D is set at 1.0 ext factor with a 0.48mm default width (0.4mm nozzle E3D Hotend) and step's/mm is approx 414 IIRC (would have to switch Printer on and check it)
          Doug
          • piankocundefined
            piankoc
            DjDemonD, if your steps per mm is around 290 with an extrusion multiplier of 1 would that be the same as the 419 steps per mm suggested with an extrusion multiplier of .7?
            Did you set your steps per mm by printing objects and adjusting or by extruding 100mm and measuring the distance?
              deckingman
              @DjDemonD:
              So it seems to me that we effectively have the same setting, In my case it's steps of 424 with extrusion multiplier of 0.7, and in your case it's steps per mm of 290 with extrusion multiplier of 1.00. Others are getting good results with std E3D settings of around 419 steps per mm and extrusion multiplier of around 1.00. What's the common thread? Mine is a CoreXY is yours?
                deckingman
                @Dougal1957:
                Doug
                Doug. Just out of curiosity, is yours CoreXY?
                  Bobblejot
                  The two machines i use with the E3D titans are both deltas with bowdens. Not that it should matter i wouldn't have thought.
                  Normally an extrusion multiplier of 0.92 or thereabouts is for PLA and 1.0 is for ABS. Materials like colorfab xt are normally higher 1.05 or so. But to be fair it depends on the brand of filament more than anything else.
                    deckingman
                    @Bobblejot:
                    For sure I've only ever had to use similar extrusion multipliers on my old RRP Mendel and then only to suit different rolls of filament. Admittedly they weren't E3D titan extruders but similar geared design.
                    What I can't get my head around is why I have to use such a large number for printing when I've set the steps per mm to give me an accurate extruded length when "static". I just have this nagging feeling that it's something to do with CoreXY or the way Slic3R works with CoreXY or something that the firmware is doing. What's bugging me is that CoreXY works differently in that one motor will make the hot end move diagonally. To get X or Y axis movement, you have to drive both motors and in one case, one motor forwards and the other backwards. As far as a slicer is concerned, the volume to extrude is purely a function of axis travel so is the fact that on a CoreXY both motors are driven for pure X movement screwing things up?
                    I'm clutching at straws here but if everyone with CoreXY and Slic3R has to set a really low extrusion multiplier, then I may be on to something. Is there anyone out there getting good results on a CoreXY, using Slic3R with "normal" extrusion settings? If so, that'll blow one theory out of the water.
                    • DjDemonDundefined
                      DjDemonD
                      I have a corexy not using Duet but ramps, I use Slic3r and I have a flex3drive extruder which at 1/8th microstepping needs to be set to 1600 steps/mm. Which it is. And it extrudes normally extrusion multiplier 1.00.
                      Are you providing enough power to the machine (I suspect you have a massive PSU on that bad boy) is the motor current correct for the extruders?
                      My understanding of corexy kinematics is that whilst two motors have to turn for x or y movements and only one turns for diagonal movements this has no bearing on syncing extrusion moves, if you ask for 10mm movement in whatever direction and 10mm extrusion whilst you do it thats what you get.
                      I checked the steps/mm on my titans, one is set to 250 and the other to 333 both printers extruding normally with extrusion multipliers set to 1.00. I can't explain this difference. Its not filament either as I regular swap filaments between machines and get very similar results. Maybe one extruder has a different drive gear to the other.
                        deckingman
                        PSU is 24V 15 Amp (350Watt) but it's only doing the steppers and hot end heater and Duet. The bed is 240V via a SSR. Main motors (X,Y and Z) are 2 amp but I'm running them at 1.8. Extruder motors are the next size up to the pancake ones. 0,4 Amp but I'm running them at 0.3. No sign of any skipped steps. Current draw with everything running is about 7 amps max from the PSU so plenty of spare capacity.
                        I agree about the CoreXY kinematics and that if you ask for 10mm of movement and 10mm of extrusion, that's what you should get but for whatever reason, it seems I'm getting 30% more.
                        I've just printed your test pieces that I found on Thingiverse. Started at 100% extrusion multiplier. Then reduced it to 90% and printed another, and so on down to 60%. I need daylight to see properly but 100% is way too much and 60% is a bit too little. Crazy…...
                        • DjDemonDundefined
                          DjDemonD
                          Well all I can say is that the steps/mm calculated for this extruder and what it actually needs to be set to are not the same. Unless you want to be running with a 0.6 extrusion multiplier all the time. It doesn't really matter though how you set it, there are a lot of different ways of adjusting the amount of material extruded flow, steps/mm, multiplier they all do the same thing. As long as the amount you get out matches the amount you need you're there. I'd change your steps/mm to a corrected value and set your multiplier to 1.
                          I've always set the steps/mm fairly arbitrarily then adjusted based on calibration objects. When I first got a titan I figured since I was running around 100 steps/mm on a mk8 which was not geared and the titan was 3:1 I'd try 300 and see how I got on. On the mini kossel I nudged it down to 250. On the large kossel I started at 250 and went up to 330. Now that I can't explain but the large kossel has been nothing but trouble, at the moment its a genuine e3d v6 jamming (with abs!) if I even look at it funny. Might send it back.
                            Dougal1957
                            Mine is a Delta and something that maybe of interest is that the first batch of Titans towards the end of that first run had the hobbing tool wear which caused the drive gear to be the wrong size.
                            Myself and a few others that I know had this issue and in my case caused horrendous stripping issues.
                            E3D Swapped them out FOC as indeed they should have done all it needed was to send them a photo of the drive gear.
                            When you calculate your steps/mm you are measuring the amount of filament going into the extruder arn't you and not the length coming out of the nozzle tho I doubt you are making that mistake but stranger things have happened.
                            Doug
                            • piankocundefined
                              piankoc
                              DjDemon, I just don't understand why if you're using the same extruders you have that much variability in the steps per mm. If they are the same extruder it should be the same steps per mm. If i am pushing 100mm into my hotend it should print correctly or close to it with an extrusion multiplier of 1. I understand that a bowden setup could cause some slack in that but didn't think it would be a difference of 30%. But how does the same extruder have such different values and once dialed in to push 100mm through it? if the amount of plastic going into the nozzle is the same it expects why do i have to drop it 30%?
                                deckingman
                                @Dougal1957:
                                Doug
                                Hi Doug,
                                Yes, I'm aware of the bad hobbed bolt issue and I was extra careful to check mine when I got them - they are a later batch and look fine. In any case, if it was stripping the filament, I'd be getting under extrusion issues, not over extrusion.
                                Yes, I am measuring the filament going in to the nozzle and not what comes out. I'm reassured that my settings are about right because they are very close to the theoretical value that E3D state (the theoretical value is 418.5 and I need 424).
                                I'm getting good quality prints but it's bugging me that I have to use such wild extrusion factors to achieve them. I'll continue my investigations.
                                • DjDemonDundefined
                                  DjDemonD
                                  Okay so the first titan I bought was an early one (May 2016) but, and here's another anomaly, it feeds filament very well, no stripping. The second one I bought about a month ago and it strips filament and feeds less well albeit into the v6 hotend I have been having a lot of problems with. Both hobbed drive gears look the same and feel the same.
                                  I understand the accepted calibration procedure perfectly well, measure filament going in and adjust steps/mm to get the exact amount fed in mm that you requested. However If, as is clearly the case when printing (which after all is what this is about) you need only 70% of that amount of filament to make good objects, then either this process is incorrect, or there is some titan related oddness going on, or there is a firmware issue here.
                                  Having so many variables to modify to basically determine the number of step pulses that get sent for each 1mm of filament to be extruded is not necessarily helpful.
                                  Has anyone actually counted the teeth on the gears to check it really is 3:1? That would throw the calculation off.
                                  As for why one of my titans prints beautifully with 250 steps/mm and the other with 330 steps/mm - its interesting sure and I will try to find out why if I get the opportunity, but when its printing well I am not going to take it apart to satisfy scientific curiosity.
                                    Dougal1957
                                    Guys
                                    I was not trying to cast aspersions on you guys at all (But had to ask very tongue in cheek lol).
                                    Mine just works as expected and is now even better since I converted to Flying extruder (Only change was to reduce motor current to around 400) oh and reduce my retraction from 9 to 2 mm again I am using a Genuine E3D V6 hotend with 0.4 mm nozzle and pt100 sensor. oh and use ABS or PETG usually. and only 1.75mm filament.
                                    I will keep an eye on this thread and hope you guys find the answer.
                                    Doug
                                      deckingman
                                      @DJ,
                                      It's strange indeed. I'm leaning towards the fact that it's not Titan related - other users have no probs with different geometry machines.
                                      Ref the difference you are seeing between the two - could it be due to nozzle diameter? Has one got a bit worn compared to the other?
                                        deckingman
                                        Hi Doug,
                                        No probs. I've got a flying extruder variant on my CoreXY. The 3 Titans are suspended above the centre of the bed with a counter weight/pulley arrangement. It means I can have Bowden tubes around 300mm long with a bed that's 400mm square. Like you, my retraction is low - 3mm (but I've yet to refine it).
                                        I'm also using PT100. Printing PLA at 195 which seems best on my machine, with that particular filament in tests I've done. Also, only using 1.75 mm filament (and yes, I've checked the diameter).
                                          T3P3Tony administrators
                                          Ian just going back to basics. If you have the extruder set to move 100mm of filament through it when you command G1 E100 then your steps are calibrated correctly for the Titan. At that point if the amount of filament being extruded is less then you would suspect an issue with high pressure causing the extruder to skip steps/strip the filament, or in your diamond setup the hot filament taking an alternative path other than out the nozzle. All that does not apply though because you are experiencing too much extrusion, rather than too little.
                                          With that in mind can you explain why you believe it is over extruding? I suggest going back to printing a single wall cube with no base, using only one extruder with no extrusion multiplier set and see what results you get. Also try a different slicer (say cura) on the same simple object and then compare the gcode to see how much extrusion is being asked for.
                                          For a very simple print (say a single wall, single layer height square) you can measure the amount of filament that goes through the extruder for the.print and compare it to what the gcode extrusion amount was.
                                          Basically trying to locate if the error is with the slicer settings or the firmware having eliminated the mechanics of the extruder.
                                            deckingman
                                            Hi Tony,
                                            Thanks for the input. For these tests, I'm only using a single extruder so we can discount any effects of mixing ratios. Although the large, multi coloured vase I posted was printed using an extrusion factor of 0.7 so I'm fairly confident that the issue is common to all 3 extruders.
                                            Yesterday I started using DJDemon's calibration object from Thingiverse - (can't find it again otherwise I'd post a link).
                                            Using an extrusion multiplier of 1.00, the surface finish is crap with blobs all over it, there are bulges on the corners, lumps on the sides and lack of detail. The dimensional accuracy is good though. Printing again at with an extrusion factor of 0.9 makes little difference. Dropping to 0.8 gives a much better surface finish and good detail. Dropping it to 0.7 with this particular object shows signs of under extrusion with gaps appearing between the lines.
                                            I think what I need to do next is accurately measure the actual nozzle diameter.
                                            Not sure what you mean by the single wall, single layer height thing - can you elaborate please?
                                            Cheers
