    OOZNest WorkBee, screw driven
    CNC
    11
    36
    10.1k
    • Catalin_ROundefined
      Catalin_RO @Adamfilip
      @adamfilip I don't know if David has any CNC mill post processor for the Duet. All I can help you with is the CamBam 1.0 one. I have used it extensively and it is working very well with firmware 2.0 and newer. As I can't upload the file (it's name is Duet3D v2.0.cbpp), here is its content:
      <?xml version="1.0" encoding="utf-8"?>
      <PostProcessor xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Version="0.9.8.0">
      <ToolChange />
      <CutterCompOff />
      <WorkplaneXY />
      <VelocityModeExactStop />
      <VelocityModeConstantVelocity />
      <EndRewind />
      <Repeat />
      <SpindleCW>M3 {$s} G4 S30</SpindleCW>
      <SpindleOff>G4 P0 M5</SpindleOff>
      <RotaryAxis>B</RotaryAxis>
      </PostProcessor>
      • Adamfilipundefined
        Adamfilip
        I asked Ryan from Ooznest about the post processor they use for Duet and they said they just use standard GRBL
        dc42undefined Catalin_ROundefined 2 Replies Last reply Reply Quote 0
          dc42 administrators @Adamfilip
          It may be of interest that RRF 2.02RC7 supports Fanuc-style GCode in the sense that where you have a sequence multiple G0, G1, G2 or G3 commands, after the first line the subsequent lines can just specify the new coordinates (and feed rate if necessary), omitting the G command.
          moameenundefined 1 Reply Last reply Reply Quote 0
            @adamfilip GRBL might work as post processor with the latest firmware, I admit! 8 months ago that was not possible and I have added the dedicated CamBam post processor because of that.
            • 3DOesteundefined
              3DOeste
              With the latest rc7 firmware, fanuc postprocessor should work, I'll make a powermill post and post it here once it's done. It should be pretty easy now. It'll work with featurecam and artcam too.
              If you looked for it, any cam should include a fanuc post.
              • moameenundefined
                moameen @dc42
                @dc42 I am currently running the latest firmware on duet wifi but I am getting a bad command error on the line with no G command when running a GCode file. I don't know if I am missing something.
                For example:
                G1 X100 Y100 F2000
                X200 Y200
                G1 X0 Y0
                The gantry moves to X100 and Y100 then back to 0 only
                deckingmanundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  deckingman @moameen
                  @moameen said in OOZNest WorkBee, screw driven:
                  For example:
                  G1 X100 Y100 F2000
                  X200 Y200
                  G1 X0 Y0
                  You need to put G1 in front of the X200 Y200
                    dc42 administrators @moameen
                    For example:
                    G1 X100 Y100 F2000
                    X200 Y200
                    G1 X0 Y0
                    Have you set the machine mode to CNC, using M453 ?
                    • moameenundefined
                      moameen
                      I do not have a spindle hooked up to the duet. So if I use the M453 code on its own the GCode works correctly, but if I add the P and R parameter to the M453 it does not. The bad error command pops up. I am running an MPCNC and this is my config. Maybe there is some conflicting commands.
                      M111 S0 ; Debugging off
                      G21 ; Work in millimetres
                      M555 P2 ; Set firmware compatibility to look like Marlin
                      M564 H0 ; Allow axis movement prior to homing
                      M584 X0:4 Y1:3 Z2 A3:1 B4:0 ; Axis mapping
                      M208 X0 Y0 A0 B0 Z-80 S1 ; Set axis minima
                      M208 X650 Y650 A650 B650 Z5 S0 ; Set axis maxima
                      M453 P1 R5000
                      M574 X1 Y1 A1 B1 S1 ; Set endstops controlled by switch
                      M569 P0 S0 ; Drive 0 goes backwards X
                      M569 P1 S0 ; Drive 1 goes backwards Y
                      M569 P2 S1 ; Drive 2 goes forwards Z
                      M569 P3 S1 ; Drive 3 goes forwards A
                      M569 P4 S1 ; Drive 3 goes forwards B
                      M350 X16 Y16 Z16 A16 B16 I0 ; Configure microstepping without interpolation
                      M92 X80 Y80 Z400 A80 B80 ; Set steps per mm
                      M566 X400 Y400 Z100 A400 B400 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X10000 Y10000 Z600 A10000 B10000 ; Set maximum speeds (mm/min)
                      M201 X900 Y900 Z300 A900 B900 ; Set accelerations (mm/s^2)
                      M906 X800 Y800 Z800 A800 B800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      ;M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                      ;M305 P0 T10000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                      ;M143 H0 S120 ; Set temperature limit for heater 0 to 120C
                      ;M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                      ;M143 H1 S280 ; Set temperature limit for heater 1 to 280C
                      ;M563 P0 D-0 H-1 ; Define tool 0
                      ;M563 P1 D-1
                      ;M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      ;M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      ;M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      • moameenundefined
                        moameen @deckingman
                        @deckingman Have a look at @dc42's previous post on omitting the G1 command, It was implemented in RRF 2.02RC7 release
                          deckingman @moameen
                          Yes thank you. I missed the fact that this was a CNC related question. Apologies.
                          Edit (but you could try my suggestion because if it improves things then that information might be useful in diagnosing the problem).
                            @moameen, my guess is that the M453 command is failing because of a bad S or P parameter on that command. You can check which mode the machine is in by sending M450. You can also try sending the same M453 command from the GCode console that you have in config.g and see if you get an error message. One possible reason is that you have chosen a pin that is normally used as a heater to control the spindle, but you haven't first made it free by disabling the associated heater using M307.
                              Catalin_RO @moameen
                              @moameen Please re-check your axis mapping (M584)! I would strongly suggest that you start with my config.g example and modify it as needed.
                              Also it is important to differentiate between single homing switch on just one of the Y-axis or separate homing switches on the two Y-axis. What is your actual setup?
                              More important... how large is your WorkBee and is it screw or belt version?
                              • moameenundefined
                                moameen @dc42
                                @dc42 I have made the changes and disabled the heaters but i am still having the same problem. when I send the M453 command via web interface, a bad P parameter error is coming up.
                                M140 H-0 ; Disable bed heater
                                M307 A-1 C-1 D-1 ; Disable E0 heater
                                M307 A-2 C-2 D-2 ; Disable E1 heater
                                ;M563 P0 D-0 H-1 ; Disable P(Tool 0) D(E drive 0) H(heater 1)
                                ;M563 P1 D-1 H-2
                                M208 X650 Y650 A650 B650 Z40 S0 ; Set axis maxima
                                M453 P1 R24000 ; CNC mode using E0 heater pin (P1)
                                • moameenundefined
                                  moameen @Catalin_RO
                                  @catalin_ro I am running an MPCNC with dual x and dual y motors and separate homing switches on each axis so as to allow the machine to self square during homing.
                                    You haven't specified the heater numbers in the M307 commands to disable the heaters.
                                      T3P3Tony administrators
                                      .cbpp files can now be uploaded.
                                      • moameenundefined
                                        moameen @dc42
                                        @dc42 Thanks for the help. All sorted now
                                        brindoroundefined 1 Reply Last reply Reply Quote 0
                                        • brindoroundefined
                                          brindoro @moameen
                                          @moameen Can you share your config.g and other files? Perhaps running now with 2.05? Building an MPCNC
                                          moameenundefined 2 Replies Last reply Reply Quote 0
                                          • moameenundefined
                                            moameen @brindoro
                                            @brindoro haven't used the machine since the beginning of the year so not sure on what firmware version is currently on the duet. As soon as I am near the machine I will post the file
