Mesh Grid - Result is not ok
Yes it have 2 Z Motors
i will check your link
thanks
are you sure your x-axis height (to the bed) was equal left and right side, before you started measuring the bed? For a certain X position the z height is the same for the whole length of your Y...so it looks like your x-axis wasn't leveled.
@lui2004 for bed levelling you need to use 2 drivers for you 2 z motors
i dont understand the example from the wiki
https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motorscan you give me some help
thank you
New Automatic Calibration Results
what i can do to make it better without to buy new hardware is it possible ?
thanks
It looks like you had a large probing error at one particular point (the red one). Is it repeatable? Is there anything special about that point?
Which firmware version are you using?
No nothing particular on this point
Every mesh grid The same point
I use the last Firmware 2.02
I have read that i can use The E1 for a second z motor Drive? Is it correct ? So i can use The Wiki link Fromm dc42 ?
This is my 3dPrinter
Nothing?
I dont be forward still same Problem.
so i have made some changed
2 indepedet motors for Z ( ZA and E1 )
config.g
; generated by RepRapFirmware Configuration Tool v2 on Sun Jan 13 2019 14:56:09 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"AM8" ; Set machine name
M552 S1 ; Enable network
M587 S"WLAN-363335" P"luigello20101984" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P4 S0 ; Drive 4 goes backwards
M92 X100.00 Y100.00 Z400.00 E100.00 ; Set steps per mm
M566 X600.00 Y600.00 Z18.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; Set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
M906 X500.00 Y500.00 Z500.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M584 X0 Y1 Z2:4 ; two Z motors connected to driver outputs Z and E1
M671 X-20:220 Y0:0 S0.5 ; leadscrews at left and right of X axis
M208 X-33:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
;M208 X-33 Y-10 Z0 S1 ; Set axis minima
M208 X220 Y220 Z240 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S0 ; Set active low and disabled endstops; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M558 P1 H4 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
G31 P500 X0 Y0 Z1.697 ; Set Z probe trigger value, offset and trigger height
M557 X20:200 Y20:200 S40 ; Define mesh grid; Heaters
M305 P0 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S130 ; Set temperature limit for heater 0 to 130C
M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S275 ; Set temperature limit for heater 1 to 275C; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
T0 ; Select first toolbed.g
; bed.g
;M561 ; clear any bed transform
;G29 ; probe the bed and enable compensationG28 ; home
M401 ; deploy Z probe (omit if using bltouch)
G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
M402 ; retract probe (omit if using bltouch)thats my actual height map
But here you have only performed bed level with the leads crews. Not any mesh, i.e. G29. At least I don't see that in bed.g file.
There is something seriously wrong.... Why are the x and y coords of you sample points not in a grid? Isn't that that the plot straight from above?it must the perspective...
Why do you deploy for the ir sensor? -
Hi
Thanks for your answerAlso i have to add this code in bed.g
; mesh probe
G29 S0My english is not The best can you give a advise
i think i found the problem i have insert bed leveling with mesh
now i have only mesh
20.00,200.00,20.00,200.00,-1.00,40.00,40.00,5,5
0.015, 0.398, 0.325, 0.287, 0.205
0.322, 0.352, -0.173, 0.335, 0.265
0.342, 0.357, 0.882, 0.337, 0.280
0.305, 0.232, 0.317, 0.285, 0.305
0.168, 0.355, 0.245, 0.232, 0.385my new config.g
G31 P500 X0 Y0 Z2.180 ; Set Z probe trigger value, offset and trigger height
T0 ; Select first toolbed.g:
; bed.g
G29 ; probe the bed and enable compensationMy New Result Mesh:
Does your bed surface have a bit of a reflectiveness to it? Can you try probing your bed with a piece of plain white printer paper on it? I'm thinking maybe the IR probe isn't getting a good reading from your bed surface.
I have The buildtak Vertex
I will Test it tommorow
If its reflectiveness what i can use to probing?
You can try adding an A and S parameter to your M558 command to try and increase probing consistency.
M558 A10 S0.003
this will cause the probe to probe up to 10 times if the consistency of two consecutive probe results are within 0.003mm of each other.
Like this
M558 P1 H4 F120 T6000 A10 S0.003
@lui2004 Yes
Ok i i will test now
with white printer paper i got
Error: Z probe already triggered before probing move started
with M558 P1 H4 F120 T6000 A10 S0.003
i got
0.003, 0.548, 0.559, 0.647, 0.682
0.476, 0.589, 0.143, 0.761, 0.788
0.573, 0.633, 1.234, 0.772, 0.788
0.636, 0.613, 0.753, 0.771, 0.841
0.603, 0.835, 0.740, 0.761, 0.978
