    Mesh Grid - Result is not ok
    2.9k
    • lui2004undefined
      lui2004
      New Automatic Calibration Results
      what i can do to make it better without to buy new hardware is it possible ?
      thanks
        1. It looks like you had a large probing error at one particular point (the red one). Is it repeatable? Is there anything special about that point?
        2. Which firmware version are you using?
        • lui2004undefined
          lui2004
          No nothing particular on this point
          Every mesh grid The same point
          I use the last Firmware 2.02
          I have read that i can use The E1 for a second z motor Drive? Is it correct ? So i can use The Wiki link Fromm dc42 ?
          • lui2004undefined
            lui2004
            This is my 3dPrinter
            • lui2004undefined
              lui2004
              Nothing?
              I dont be forward still same Problem.
              • lui2004undefined
                lui2004
                so i have made some changed
                2 indepedet motors for Z ( ZA and E1 )
                config.g
                ; generated by RepRapFirmware Configuration Tool v2 on Sun Jan 13 2019 14:56:09 GMT+0100 (Mitteleuropäische Normalzeit)
                M550 P"AM8" ; Set machine name
                M552 S1 ; Enable network
                M587 S"WLAN-363335" P"luigello20101984" ; Configure access point. You can delete this line once connected
                M586 P0 S1 ; Enable HTTP
                M586 P1 S0 ; Disable FTP
                M586 P2 S0 ; Disable Telnet
                M569 P4 S0 ; Drive 4 goes backwards
                M92 X100.00 Y100.00 Z400.00 E100.00 ; Set steps per mm
                M566 X600.00 Y600.00 Z18.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; Set maximum speeds (mm/min)
                M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
                M906 X500.00 Y500.00 Z500.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M584 X0 Y1 Z2:4 ; two Z motors connected to driver outputs Z and E1
                M671 X-20:220 Y0:0 S0.5 ; leadscrews at left and right of X axis
                M208 X-33:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                ;M208 X-33 Y-10 Z0 S1 ; Set axis minima
                M208 X220 Y220 Z240 S0 ; Set axis maxima
                M574 X1 Y1 S0 ; Set active low and disabled endstops
                M574 Z1 S2 ; Set endstops controlled by probe
                M558 P1 H4 F120 T6000 ; Set Z probe type to modulated and the dive height + speeds
                G31 P500 X0 Y0 Z1.697 ; Set Z probe trigger value, offset and trigger height
                M557 X20:200 Y20:200 S40 ; Define mesh grid
                M305 P0 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
                M143 H0 S130 ; Set temperature limit for heater 0 to 130C
                M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                M143 H1 S275 ; Set temperature limit for heater 1 to 275C
                M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M563 P0 D0 H1 ; Define tool 0
                T0 ; Select first tool
                bed.g
                ; bed.g
                ;M561 ; clear any bed transform
                ;G29 ; probe the bed and enable compensation
                G28 ; home
                M401 ; deploy Z probe (omit if using bltouch)
                G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
                G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                M402 ; retract probe (omit if using bltouch)
                thats my actual height map
                • AlexLinundefined
                  AlexLin
                  But here you have only performed bed level with the leads crews. Not any mesh, i.e. G29. At least I don't see that in bed.g file.
                  There is something seriously wrong.... Why are the x and y coords of you sample points not in a grid? Isn't that that the plot straight from above?it must the perspective...
                  Why do you deploy for the ir sensor?
                  • lui2004undefined
                    lui2004
                    Hi
                    Thanks for your answer
                    Also i have to add this code in bed.g
                    ; mesh probe
                    G29 S0
                    My english is not The best can you give a advise
                    • lui2004undefined
                      lui2004
                      i think i found the problem i have insert bed leveling with mesh
                      now i have only mesh
                      20.00,200.00,20.00,200.00,-1.00,40.00,40.00,5,5
                      0.015, 0.398, 0.325, 0.287, 0.205
                      0.322, 0.352, -0.173, 0.335, 0.265
                      0.342, 0.357, 0.882, 0.337, 0.280
                      0.305, 0.232, 0.317, 0.285, 0.305
                      0.168, 0.355, 0.245, 0.232, 0.385
                      my new config.g
                      G31 P500 X0 Y0 Z2.180 ; Set Z probe trigger value, offset and trigger height
                      bed.g:
                      ; bed.g
                      My New Result Mesh:
                        Does your bed surface have a bit of a reflectiveness to it? Can you try probing your bed with a piece of plain white printer paper on it? I'm thinking maybe the IR probe isn't getting a good reading from your bed surface.
                        • lui2004undefined
                          lui2004
                          I have The buildtak Vertex
                          I will Test it tommorow
                          If its reflectiveness what i can use to probing?
                            You can try adding an A and S parameter to your M558 command to try and increase probing consistency.
                            M558 A10 S0.003
                            this will cause the probe to probe up to 10 times if the consistency of two consecutive probe results are within 0.003mm of each other.
                            • lui2004undefined
                              lui2004
                              Like this
                              M558 P1 H4 F120 T6000 A10 S0.003
                                Phaedrux Moderator @lui2004
                                @lui2004 Yes
                                • lui2004undefined
                                  lui2004
                                  Ok i i will test now
                                  • lui2004undefined
                                    lui2004
                                    with white printer paper i got
                                    Error: Z probe already triggered before probing move started
                                    with M558 P1 H4 F120 T6000 A10 S0.003
                                    i got
                                    0.003, 0.548, 0.559, 0.647, 0.682
                                    0.476, 0.589, 0.143, 0.761, 0.788
                                    0.573, 0.633, 1.234, 0.772, 0.788
                                    0.636, 0.613, 0.753, 0.771, 0.841
                                    0.603, 0.835, 0.740, 0.761, 0.978
                                      @lui2004 said in Mesh Grid - Result is not ok:
                                      Try increasing your dive height perhaps? I'm not super familiar with the behaviour of the IR probes.
                                      I can't tell from the number grid if that's an improvement or not. Does the image look more consistent?
                                      lui2004undefined 1 Reply Last reply Reply Quote 0
                                      • Wyvernundefined
                                        Wyvern
                                        Is there any direct lighting around your machine? is your machine around any natural (outside) lighting? I have read that florescent lighting and possibly LED lighting can cause issues.
                                        • lui2004undefined
                                          lui2004 @Phaedrux
                                          @phaedrux Hi
                                          no the image is still the same nothing change
                                          hope everybody can help me to solve
                                          • lui2004undefined
                                            lui2004 @Wyvern
                                            @wyvern Hi
                                            no, no direct lighting to the machine.
                                            only normal natural lighting and no LED or somthing else
