    Command to move/rename files
    Firmware wishlist
    8
    29
    2.7k
    • wilrikerundefined
      wilriker @dc42
      @dc42 Marlin does use M31 to report current print time.
      The next unused M-Code according to https://reprap.org/wiki/G-code is M50. This is not used by Marlin or NIST CNC. It is though used by LinuxCNC and ReplicatorG according to a short research.
      Manuel
      My Tool Collection
      • Danalundefined
        Danal
        M31 is "time since start of SD print" on Marlin and many others.
        Perhaps, extend M33 instead. This is "get long name of file" in Marlin (and others) today.
          dc42 administrators @wilriker
          @wilriker said in Command to move/rename files:
          In that case I suggest we allocate an unused (by RRF/NIST/Marlin) M-code in the 500 range or possibly the M400 range, assuming that M33-M35 are already taken (I expect they are, because I allocated M36).
          • wilrikerundefined
            wilriker @dc42
            @dc42 said in Command to move/rename files:
            I need to check on NIST but M470 is looking good so far. Will allocate it tomorrow then and provide a PR.
            Manuel
            My Tool Collection
            • dragonnundefined
              dragonn
              Will it support renaming folders too?
              • wilrikerundefined
                wilriker @dragonn
                @dragonn said in Command to move/rename files:
                That's the plan.
                Also I just coincidentally stumbled across a request of the same feature by @resam that also asked for a way to create a directory via GCode. I will also allocate a M-Code for that and include it in my PR. Both a fairly trivial to do.
                Manuel
                My Tool Collection
                • 3dmntbighkerundefined
                  3dmntbighker @wilriker
                  Currently there are only two ways to move or rename a file: use DWC (which is using an HTTP call underneath) or remove the SD card from the Duet and do it on a computer.
                  I propose an M-Code command to do the same. Looking at https://reprap.org/wiki/G-code there is nothing unused in the M20..M39 range but at least RRF is not using M31 so far.
                  This ties into my suggestion that files with "._" and ".DS_Store" should at the very least be hidden. For that matter any file that starts with a period should really be ignored. Anyone who frequently mounts the SD card in Windows or Mac will likely find these droppings all over the place. I'd be just as happy if the Duet deleted all of these files when the SD card is mounted, but I realize that's not likely to happen. I'm mostly referring these files appearing in the 12864 file list.
                  Scratch built CoreXY with Maestro
                  Heavily modified Ender 3 with Maestro
                  MPCNC work in progress with Duet WiFi
                  • wilrikerundefined
                    wilriker
                    I reserved M470 for creating a directory and M471 for moving/renaming files/directories. PR with implementation somewhen later today.
                    Manuel
                    My Tool Collection
                      dc42 administrators @3dmntbighker
                      @3dmntbighker said in Command to move/rename files:
                      I am confused. RRF doesn't return files whose name begin with '.' to DWC. I have just tested this by uploading a menu file starting with '.' to a Maestro. It didn't appear in the file list after uploading it, even after pressing Refresh.
                      3dmntbighkerundefined 1 Reply Last reply Reply Quote 0
                      • wilrikerundefined
                        wilriker
                        And here's the Pull Request.
                        Manuel
                        My Tool Collection
                          3dmntbighker @dc42
                          I was referring to what I see in the 12864 directory list. Not the web console. When you go to print from the 12864 menus there are a bunch of these files littered everywhere that Windows must have left at some point. But I use a Mac.
                          • wilrikerundefined
                            wilriker @3dmntbighker
                            Just nitpicking: .DS_Store files are created by MacOS. 😉
                            Solution: use Linux. It won't add any unwanted files to your SD card. 😂
                            (Couldn't resist 😉 )
                            Manuel
                            My Tool Collection
                            3dmntbighkerundefined 1 Reply Last reply Reply Quote 2
                              Hehe, I manage Linux systems for a living. But I use a Mac to get actual work done.
                              • wilrikerundefined
                                @3dmntbighker Fair enough. I use Linux everywhere and wouldn't want it any other way. One of my professors once said to me it all boils down to what system fits best to your way of thinking and expectations. 🙂
                                Manuel
                                My Tool Collection
                                  deckingman @wilriker
                                  For me, that would mean a slide rule and log tables ☺
                                  • wilrikerundefined
                                    wilriker @deckingman
                                    @deckingman said in Command to move/rename files:
                                    I guess that would restrict our future communication to traditional mail then. 😂
                                    Manuel
                                    My Tool Collection
                                      Yes. Hand written with a quill, and sent by carrier pigeon.
                                      wilrikerundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      • wilrikerundefined
                                        Don't forget about the sealing wax - we have to make sure it arrives properly unopened!
                                        Manuel
                                        My Tool Collection
                                          Signed with a w.a.x. cert? 😉
                                            dc42 administrators @deckingman
                                            Two tin cans and a very long piece of string is faster 🙂
