    Can't upgrade past firmware 1.20
    Firmware installation
    1.1k
    • mudcruzrundefined
      mudcruzr
      I don't have a Duet Wifi but I remember reading something about upgrading 1.19/1.20 that was different.
      Here it is:
      https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmware_or_DuetWebControl_files
        Download this zip file: Duet2Firmware-2.02a.zip https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02a.zip
        Extract it to a folder. Then use the DWC system tab to upload iap4e.bin and iap4s.bin, then upload Duet2CombinedFirmware.bin. It should prompt you to update the firmware. If not, you may need to rename the file to DuetWiFiFirmware.bin and upload it again.
        If that works properly, you can then uploadNow that you have the main firmware up to date you should be able to use the normal full update method. Take the full 2.02 zip file that I told you to extract above, but this time just upload the whole zip file without extracting it. It should update everything you need to the latest. Same procedure going forward.
        • planeguyundefined
          planeguy
          @Phaedrux I tried your procedure and it did the same thing: prompt for update, do something? then come back as 1.20. Is an older duet wifi incompatible, perhaps? I can't tell from here.
            Can you copy and paste the version information from the settings tab as well as the result of an M122 diagnostic in the console.
            • planeguyundefined
              planeguy
              Software Information
              Firmware Name: RepRapFirmware for Duet WiFi
              Firmware Electronics: Duet WiFi 1.0
              Firmware Version: 1.20 (2017-12-23)
              WiFi Server Version: 1.22
              Web Interface Version: 1.22.6
              Web Interface by Christian Hammacher
              Licensed under the terms of the GPL v3
              6:41:56 PM
              M122
              Used output buffers: 3 of 32 (14 max)
              RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0
              Board ID: 08DDM-9FAM2-LW4S4-6JKDA-3SD6T-K3SHW
              Static ram used: 15448
              Dynamic ram used: 99320
              Recycled dynamic ram: 4016
              Stack ram used: 1392 current, 4376 maximum
              Never used ram: 7912
              Last reset 01:23:39 ago, cause: software
              Last software reset details not available
              Error status: 0
              Free file entries: 10
              SD card longest block write time: 0.0ms
              MCU temperature: min 24.0, current 29.7, max 29.9
              Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0
              Driver 0: ok, SG min/max not available
              Driver 1: ok, SG min/max not available
              Driver 2: ok, SG min/max not available
              Driver 3: ok, SG min/max not available
              Driver 4: ok, SG min/max not available
              Date/time: 2019-02-05 18:41:55
              Slowest main loop (seconds): 0.022647; fastest: 0.000034
              MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
              Bed compensation in use: none
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              Network state is running
              WiFi firmware version 1.22
              WiFi MAC address ec:fa:bc:0b:fa:34
              WiFi Vcc 3.38, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 27232
              WiFi IP address 192.168.2.97
              WiFi signal strength -52dBm, reconnections 0, sleep mode modem
              HTTP sessions: 1 of 8
              Socket states: 0 2 0 0 0 0 0 0
              Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                Try updating to 1.21 first. If that doesn't work, try 2.0.
                • planeguyundefined
                  planeguy
                  No luck on 1.21 or 2.0 using your previous technique 😞
                    Try going through the fallback procedures described here: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                      Phaedrux Moderator @planeguy
                      @planeguy said in Can't upgrade past firmware 1.20:
                      I just noticed your supply voltage is really low. How are you powering the Duet?
                      • planeguyundefined
                        planeguy
                        I'm just plugged into the computer via USB right now. More importantly the fallback method 1 worked and got up to 2.0! 2.02 worked fine via the "usual" method after that. Thanks so much @Phaedrux !
                          Glad it's working. Be sure to check out the version release notes. A lot of things have been fixed and new features added since 1.18. Be sure to test your homing and movement carefully.
