    Migration from Maestro to Duet 2 WiFi
    1.3k
    • gnydickundefined
      gnydick
      My printer originally came with the Maestro, now I'm changing to Duet 2 WiFi, @dc42, can you point out the main differences to look for?
        https://duet3d.dozuki.com/Wiki/The_Duet_family_of_motion_control_electronics
        gnydickundefined 2 Replies Last reply Reply Quote 0
        • Vetiundefined
          Veti
          why are you changing? do you have a problem with your maestro?
            He blew it up in another thread.
            • gnydickundefined
              gnydick @Phaedrux
              @phaedrux sorry, I meant configuration wise. Iirc there were some repurposed connections.
              • Vetiundefined
                Veti
                the resistor for the thermistors is 4.7k
                  You should be able to use your existing config.g apart from the following differences:
                  • If you have R2200 in your M305 lines, change to R4700.
                  • Duet WiFi does not support stealthChop, so D3 in M569 won't work
                  • The way you set a static IP address is different on the WiFi, you can't set it in M552.
                  • In M350, interpolation only works in x16 mode.
                  That's all I can think of.
                  • gnydickundefined
                    gnydick @dc42
                    @dc42 wasn't also the z probe hooked up to a different input on the promega?
                    • gnydickundefined
                      gnydick @dc42
                      @dc42 oh, and thank you ☺
                      • gnydickundefined
                        gnydick @Phaedrux
                        @phaedrux based on your link, https://duet3d.dozuki.com/Wiki/The_Duet_family_of_motion_control_electronics, apparently i can power my fans externally somehow? I can't find it in the docs.
                        3 controlled fans, 1 always-on fan connector, voltage selectable between VIN, 5V or external supply in 2
                          There is a fan voltage pin that allows you to input your own voltage line that will power the fans. For example, I use it on my wifi to supply 12v from my 24v PSU through a buck converter.
                          You'd have to check the maestro diagram to see if it's also there, but if it's similar to the wifi it is in the block of fan connectors.
                          • gnydickundefined
                            gnydick @Phaedrux
                            @phaedrux I don't know what I'm looking for. I see an EXT 5V near the other fan headers. but that's only 5V 😞
                            https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/IU2QdUPV2BKihsm5.huge
                              Look for VFAN jumper selector
                              • gnydickundefined
                                gnydick @Phaedrux
                                @phaedrux yeah, I see those, but it only says VIN or 5V, nothing about external
                                  Phaedrux Moderator @gnydick
                                  @gnydick it's a jumper. You can either bridged the connection between VIn or 5v, or don't use the jumper and connect your own voltage supply straight to the pin.
                                  Get what I mean?
                                  • gnydickundefined
                                    gnydick @Phaedrux
                                    @phaedrux I understand jumpers, what I don't understand is where to connect my own supply.
                                      To the center pin.
                                      • gnydickundefined
                                        gnydick @Phaedrux
                                        @phaedrux and it can be a single wire from the positive of my 24V power supply?
                                          That's right. But if your duet power supply is 24v and you want to power the fans at 24v just use the jumper to connect Vin to vfan.
                                            https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
