    Suggestion for change to implementation of baby-steps
    100
    10.0k
    • gnydickundefined
      gnydick @dc42
      @dc42 it's funny. The last time we spoke about baby-stepping, you said it was supposed to be reset at the end of a print.
      I don't think I am in a minority. If you swap filament materials, you're going to want to change your squish factor.
      I think you are missing the point I'm trying to make. I don't necessarily want it to reset baby-steps when you home, I want the position indicator to always be the physical position AND that the system doesn't store a magical offset, as far is it knows, there is just a delta to be applied to whatever commands come in. There really is a nuanced different there. The fact that it's a hidden value when you're not on the Job Status screen is bad. You can forget that it's applied. There are all sorts of things that you're not envisioning that people go through when they're iterating on a machine design, many unorthodox workflows happen. When my Z isn't stable and I have to frequently calibrate where zero is, I go through all sorts of gyrations, macros, etc. trying to make my life easier. If I zero the bed, record a value, then reboot the machine, my value is wrong because the position indicator didn't read the actual physical position. You'll say, "well, you have to remember to bring the nozzle to the bed, then reset the position with G92 Z0, then you can get an accurate delta." That's not acceptable. I build infrastructure for other engineers for a living. The tools I provide to them are unopinionated because they don't assume any specific workflow, nor do they require having to remember to do certain things in order to work correctly. When that happens, it's considered a bug. Imagine if you were coding and you dereferenced a pointer, but you had to determine if you needed to apply an offset to the memory address based on some condition. That wouldn't make much sense. This is the same thing. I want to read a register and it be correct.
      I think you really have to put yourself in you end-users' head and realize, it's not a single workflow device. That and this implementation is opinionated on that assumed workflow.
      It will be much simpler to just treat baby steps as a jog dial for the Z position.
      I'm curious if you've spent much time with a Prusa, tuning it up, calibrating, etc? The experience is much more intuitive.
      If my printer worked perfectly, it wouldn't really matter how baby-steps were implemented, because I'd practically never need to use them, though again, switching filament types does warrant it.
      But as a tinkerer, the logic behind this feature, and others, actually gets in the way because it is opinionated as I described. This is a controller for an industrial machine. What industrial machines do you know that don't show you the actual physical position? A CNC machine like a mill or router, etc., will all show you exactly where the tool is and if you need to calibrate it on the fly, that indicator changes. What we have here is just an antipattern.
      I've rambled a bit, but the overall point I'm trying to make is, you have to make things for people to use how THEY want to use them. I hope that came through clearly.
        deckingman
        @dc42 I was having a little difficulty understanding what the issue is here but now I think I do. If I understand correctly and cut through all the personal stuff, in simple terms, it looks more like a DWC issue than a firmware issue and I'd say it's nothing to do with the implementation of baby-stepping as such.
        So if one homes the printer, then go into the job status section of DWC and hit baby stepping a number of times, the bed will move (on a moving bed system) but the machine status section does not report the new position of Z. In my case, after homing, the bed is at 10mm. So hitting baby stepping say 10 times will give an offset of 0.5mm, the bed itself does indeed move 0.5mm but the displayed head position for Z does not change. In my case, it still shows Z being at 10mm. If one then re-homes the printer, with that 0.5mm offset still applied, then after homing the machine status section shows the Z height to be 10.5 mm which is the correct position.
        I think the only change that's needed is that DWC should show the Z position with whatever offset is applied as soon as that offset is applied (i.e. whenever the baby stepping button is hit). I think the physical position is correct - it's just not always being displayed correctly.
        HTH
        Edit - can't speak for the OP but I'm using the following firmware
        Firmware Electronics: Duet Ethernet 1.0 or 1.01 + DueX5
        Firmware Version: 2.02(RTOS) (2018-12-24b1)
        Web Interface Version: 1.22.6
          There are essentially two positions: the user position and the machine position. The user position is what the user asked for in GCode. The machine position is what the firmware moves the head reference point to after applying the tool offset, workplace coordinate offset, bed compensation, axis skew compensation, and babystepping.
          For most purposes, it's the user position that the user is interested in. If a user commands the head to X10 Y20 Z5 then it would appear odd if the reported position is something different. So it's the user position that DWC displays.
          However, RRF provides both the user position and the machine position to DWC. So it would be possible to change DWC to show the machine position instead, or to show both positions. I expect this will be an option in DWC2 in future. If you want to patch DWC to display machine position instead of user position, search the .js file for references to field ".xyz" of the status response and replace them by ".machine".
          deckingmanundefined 1 Reply Last reply Reply Quote 1
            deckingman @dc42
            @dc42 said in Suggestion for change to implementation of baby-steps:
            For most purposes, it's the user position that the user is interested in. If a user commands the head to X10 Y20 Z5 then it would appear odd if the reported position is something different. So it's the user position that DWC displays....................
            Personally, I don't give a damn as I don't have a need to use baby stepping. But, I think this is what the OP is complaining about. That is to say, if the user presses the baby stepping buttons to essentially command the head to move from say Z5 to Z4.5 then DWC still displays the position as being Z5.0 even though it is actually 4.5. I guess it depends on whether baby stepping is defined as a move command.
            So we have the situation where DWC shows the Z height without the offset (5.0) and also displays the offset (0.5). But then if the printer is homed still with this 0.5 offset applied, then after homing DWC will show the Z position as being 5.5 (i.e the Z position plus the offset) and also still shows the offset as being 0.5.
            So there is an inconsistency in how DWC displays the Z height depending on whether the printer is homed before or after baby stepping is applied. Maybe that's how it is but
            I can see how this would get confusing. i.e. prior to homing DWC displays the Z position without the offset, but then if the printer is re-homed, it shows the Z position including the offset. The offset value itself does not change when homing happens.
            So how can an end user know where the print head is in relation to the bed if the displayed value changes depending on whether the printer was homed prior or after the baby stepping buttons were pressed?
            As I said, personally I don't give a damn as I don't use baby stepping so I'll leave any further debate to others.
              dc42 administrators @deckingman
              @deckingman said in Suggestion for change to implementation of baby-steps:
              You make it sounds as though the displayed value for a given actual position depends on whether you home before or after babystepping; but that's not the case. Suppose your Z probe or Z endstop triggers at 5mm. If you home and then apply 1mm babystepping, the head will initially be at 5mm but after you apply the babystepping it will have been raised to 6mm. If you then home Z again, the head will be at 5mm above the bed (not 6mm) but 4mm will be displayed.
              All this ignores the fact that if you have a tool offset applied, or bed compensation applied, the height will be further adjusted.
              Perhaps one option would be for DWC to display the baby stepping offset alongside the Z coordinate.
                deckingman @dc42
                Sorry David but it is the case that the displayed value for Z depends on whether you home before or after baby stepping is applied. At least on my machine that's what happens.
                So in your example and in my actual usage case, I home Z at the end of which the head is at 10.00mm above the bed - actual real distance and that's what DWC shows. The trigger height is actually 0.4mm but that's irrelevant.
                Then I apply baby stepping repeatedly - actually 10 times - moving the bed downwards away from the nozzle. The bed moves each time, the current offset increments each time, but the head position for Z does not change. It stays at Z = 10.00mm. After 10 presses of the baby stepping button, the bed has moved 0.5mm further away from the nozzle, the current offset shows this 0.5mm but DWC still shows Z =10.00. At this point, the head position is actually 10.50 mm from the bed.
                So at this point, the displayed value for the actual head position is 10.00mm but the actual head position is 10.50 mm from the bed.
                Now, if I home Z again, without doing anything else - leaving the baby stepping offset at 0.5mm, after the homing sequence finishes, the displayed value of head position is Z=10.50mm.
                So the displayed value of actual head position in Z was 10.00 mm prior to homing, but it changed to 10.50 mm after homing.
                  So far, this is as I expect. The user Z coordinate is 10mm and you have applied +0.5mm babystepping.
                  Are you sure? That sounds the wrong way round to me. If you apply positive baby stappering, and then you home Z using a Z probe and optionally perform a relative Z move afterwards, then the displayed height after homing should be reduced by the babystepping amount. Which is what happens on my delta. The displayed Z coordinate after homing the second time in your example should be 9.5mm.
                    deckingman
                    Might have got that wrong. As I said, I don't normally use baby stepping. I thought I was lowering the bed when in fact the buttons relate to the tool head so the downward pointing icon actually moves the bed up. Therefore I was applying a negative offset hence 10.50 mm. And after homing with the offset, jogging the axis will only allow me to go to Z=0.5mm and no lower which I guess is to be expected.
                    Personally, I find it confusing that the displayed Z value changes depending on whether baby stepping is applied before or after homing but if that's the way it is, then fine. I don't use it so I don't really care.
                    • gnydickundefined
                      gnydick @dc42
                      @dc42 He is correct that the Z indicator doesn't show the actual position. If I baby step 100mm from position 5, it will always display 5.
                      I've said this before, but it doesn't seem to have weight with you, there are MANY more workflows than: click, print, finish.
                      Follow this...
                      I expect you to say to add baby step reset to the stop.gcode or to the slicer, but then that would defeat the ability to re-use the value.
                      And, since baby-steps impact, but not stored value, are transient between homings, as they are just a value applied, with no impact on the actual z height measure, you have to also reapply them between prints if even you don't reset them.
                      If we see a pattern and that we always need -.15 baby-step, you'll say to apply that offset in the config, but that can be filament specific. So you say, that's fine, keep it global, but when you use a differing filament, adjust the baby-step for that print. That only works for one print if you home between prints. So you say remove re-homing between prints. Well, I have a printer in development that may not be reliable, so I need to re-home between prints.
                      You see the cycle here? It's like the Three Stooges file cabinet. It's a never ending cycle of work arounds. if the baby-step was part of the z-height register AND remembered to be applied to the offset of the beginning position of a print, all of these situations would be handled without workarounds. Sure, if it seems to be a permanent need, put it in the config. But I don't want to stop what I'm doing, update the config, reset the printer, lose my heat, and start over. Maybe baby-stepping can store to its own file so it persists between reboots.
                      Like I said, the Live-Z Marlin feature just never fails, it never complicates things. Homing will always trigger at the same height, but the live-z offset both gets applied to the gcode for printing as well as effects the z-height register.
                        @gnydick said in Suggestion for change to implementation of baby-steps:
                        You're gonna hate me saying this, but you don't have to reset the printer. You can send the updated G31 through the gcode console and it will take effect immediately.
                          dc42 administrators @gnydick
                          Follow this...
                          You seem to be saying that the baby stepping offset is somehow remembered over homing but not actually applied. I don't believe that is the case; but I'm willing to be persuaded if you can provide a sequence of GCode commands (+ manual checking of nozzle height if needed) to demonstrate it. The other possibility that occurs to me is that you are homing to max Z and your printer is gradually getting hotter and expanding, so that you need increasing amounts of negative babystepping to counter the expansion.
                          gnydickundefined 1 Reply Last reply Reply Quote 1
                          • gnydickundefined
                            gnydick @dc42
                            @dc42 Baby-stepping is remembered after homing. Here's the simple sequence...
                            G28 ; home
                            G1 X150 Y150 Z0 ; roughly middle of the bed with nozzle touching
                            M290 S5
                            G28 Z ; re-home Z
                            G1 Z0 ; bring back the bed to the nozzle
                            M290 R0 S0 ; ***ENJOY THE CRASH***
                              G28 ; home
                              M290 S5
                              G28 Z ; re-home Z
                              What should happen is that the G1 Z0 command should leave the head at 0 + 5mm = 5mm above the bed. Then M290 R0 S0 should lower the head to the bed. Is that not what happens? How are you homing Z?
                              deckingmanundefined gnydickundefined 2 Replies Last reply Reply Quote 0
                                deckingman @dc42
                                For info, I just tried this out on my machine. It seems to work as you say with one exception. When I input M290 S5, I only get an offset of 1mm. I'm guessing that there is a 1mm limit on baby stepping? If not, then something is amiss.
                                Anyway, here is what I got......
                                G28; home all - after which....
                                Measured nozzle height =10.00mm (as expected with the commands I use)
                                DWC shows Z= 10.00
                                Baby stepping offset shows 0 mm.
                                G1 Z0 - after which......
                                Measured nozzle height =0mm
                                DWC shows Z= 0.00
                                M290 S5 - after which....
                                Measured nozzle height =1.0mm
                                DWC shows Z= 0.00
                                Baby stepping offset shows 1 mm.
                                G28 Z - after which
                                Measured nozzle height =10.0mm
                                DWC shows Z= 9.00
                                G1 Z0 - after which
                                DWC shows Z= 0.00
                                M290 R0 S0 - after which
                                Measured nozzle height =0.0mm
                                DWC shows Z= 0.00
                                HTH
                                Edit. This is just for your info - I don't use baby stepping myself but I had a few minutes to spare so ran those tests.
                                  Thanks for running this test. There is indeed a limit of 1mm in any babystepping command, unless you use the R0 parameter to specify an absolute babystepping offset.
                                  Do you home Z using a homing switch or a Z probe? It might make a difference.
                                    deckingman @dc42
                                    That depends on your definition. Essentially it's a switch connected to the nozzle mount which can move in Z, so the nozzle is the probe. But because the switch has an LED in series, I have to use it as an analogue switch. I get a reading of about 524 when it isn't triggered and 1000 when it is.
                                    Here is relevant line from my config.g
                                    G31 P700 X0 Y0 Z-0.4
                                    Edit. Ohh and M558 P1 X0 Y0 Z1 F180 T6000 I0 (so yes, a P1 type probe).
                                    • gnydickundefined
                                      gnydick @dc42
                                      conditions here are that this is a moving bed with a switch at Z-max.
                                      That's not happening at all. When you home, the firmware automatically sets the Z position to the max. If baby-stepping is still on, your bed will indeed be at the correct max position. If you then G1 Z0, you will indeed position the bed at Z0. Then you reset baby-steps, and the bed tries to move opposite to the baby-steps. If it was positive baby-steps, the bed will crash into the nozzle. If it was negative baby-steps, the bed will move away from the nozzle.
                                        deckingman
                                        Just trying to get my head around this but wondering if you home to Z max, then do M290 S5, the bed would be constrained by the axis limit as defined in M208 which would prevent it from actually moving any further? But the baby-stepping offset might behave as if the bed had moved?
                                        So maybe the problem exists only if you home to Z max?
                                          Please share your homing files.
                                          • gnydickundefined
                                            gnydick @dc42
                                            homex
                                            ; homex.g
                                            ; called to home the X axis
                                            ; generated by RepRapFirmware Configuration Tool v2 on Fri Feb 08 2019 11:10:07 GMT-0800 (Pacific Standard Time)
                                            G91              ; relative positioning
                                            G1 Y50 S1 ; avoid pulley in corner
                                            ;G1 Z-5 F6000 S2   ; lift Z relative to current position
                                            G1 S1 X293 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                            G1 X-5 F6000     ; go back a few mm
                                            G1 S1 X293 F360  ; move slowly to X axis endstop once more (second pass)
                                            ;G1 Z5 F6000 S2  ; lower Z again
                                            G90              ; absolute positioning
                                            G92 X275
                                            homey
                                            M913 X40 Y40 ; reduce current
                                            ; generated by RepRapFirmware Configuration Tool v2 on Fri Feb 08 2019 11:05:47 GMT-0800 (Pacific Standard Time)
                                            G1 S1 Y365 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                            G1 Y-5 F6000     ; go back a few mm
                                            G1 S1 Y365 F360  ; move slowly to Y axis endstop once more (second pass)
                                            M913 X100 Y100 ; restore current
                                            homez
                                            G91
                                            G1 Z400  S1 F1500
                                            G1 Z-5
                                            G1 Z10 S1 F100
                                            G90
