    Board unresponsive
    1.3k
    • elmoretundefined
      elmoret
      Tim here, from Filastruder. There's a hole in your 5 volt regulator, the part above the fan connectors. ICs don't work well with holes in them, it lets the magic smoke out 🙂
      Generally this happens when there's a short from Vin (12v/24v) to +5v in the printer wiring. I'll defer to @dc42 or @T3P3Tony on how to proceed.
      • Deanethiroundefined
        Deanethiro
        @elmoret said in Board unresponsive:
        oh WOW I cannot believe I didn't notice that until just now. Is this a component I can replace if I know someone who can do small scale soldering like that?
        • elmoretundefined
          elmoret
          Yes, if you know someone that can do hot air work. Other options are warranty coverage (unsure if this is covered, dc42/Tony would have the say), or repair through Filastruder (~$20).
            Deanethiro
            Well awesome you guys are the best, how long would repair through filastruder would be? Honestly if its fixable and not a whole hassle I totally would not mind spending 20 bucks and y'all are close I'm in Florida.
              If the board is within the warranty period, then it's covered for that fault. After 2 years of shipping many thousands of Duets and seeing zero failures of that chip, we've seen several in recent weeks and we don't yet know the cause. Possibly a substandard batch of chips.
                Deanethiro
                Okay awesome, Its not even 2 weeks old yet so it should be covered then
                  Deanethiro
                  Also can I just say @dc42 I have been super impressed over the last few months since I have joined team Duet how awesome the support here is
                    Thanks for your kind words, and for buying a genuine Duet!
                    Deanethiroundefined 1 Reply Last reply Reply Quote 0
                      Deanethiro @dc42
                      @dc42 So I sent back the broken board already, but I actually went ahead and started testing the Duex5 that was connected to it during the failure with a different Duet2 from one of my other printers and it seems none of the drivers want to work. Any ideas on troubleshooting or is the duex5 probably dead too?
                      Edit to provide more details: When the board is connected to the Duet2 and powered on no lights come on, but the 12V regulator is still regulating the 24Vin to 12V for the fans. When I go into the Settings page on the web interface it says "Duet WiFi 1.02 or later + DueX5". When I try to use any drivers to run a stepper motor it simply does nothing. The thermistor connectors work and show data, fan controllers seem to work fine as well. I did not test the heaters, but the PWM all seem to work fine as by BL touch is hooked up to PWM5 and it did its self test when I powered up the printer
                        That's an odd fault. The 3.3V feed to the DueX must be OK because it the Duet knows it is there, so the I2C expander chip on it is working. Normally I'd say that it looks like a missing VIN supply, but you report that you have a 12V output from the onboard regulator, so VIN must be present.
                        Please send M122 and report the output here, in particular the status of all the stepper drivers.
                        How did you try to use the stepper drivers on the DueX5?
                          Deanethiro
                          @dc42 said in Board unresponsive:
                          Here is the M122 results
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later + DueX5
                          Board ID: 08DGM-917DA-G4MSJ-6JTDJ-3SD6Q-TVN7A
                          Used output buffers: 3 of 20 (14 max)
                          Static ram: 25524
                          Dynamic ram: 98924 of which 0 recycled
                          Exception stack ram used: 328
                          Never used ram: 6296
                          Tasks: NETWORK(ready,544) HEAT(blocked,1232) MAIN(running,3844) IDLE(ready,200)
                          Owned mutexes:
                          Last reset 00:31:47 ago, cause: software
                          Last software reset at 2019-02-20 10:53, reason: User, spinning module GCodes, available RAM 6296 bytes (slot 3)
                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                          Error status: 0
                          Free file entries: 10
                          MCU temperature: min 32.3, current 33.6, max 33.9
                          Supply voltage: min 24.3, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                          Driver 5: standstill, SG min/max not available
                          Driver 6: standstill, SG min/max not available
                          Driver 7: standstill, SG min/max not available
                          Date/time: 2019-02-20 11:24:49
                          Slowest loop: 5.27ms; fastest: 0.07ms
                          I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                          Bed compensation in use: none
                          Bed heaters = 0 -1 -1 -1, chamberHeaters = 5 -1
                          Segments left: 0
                          Movement lock held by null
                          http is idle in state(s) 0
                          telnet is idle in state(s) 0
                          file is idle in state(s) 0
                          serial is idle in state(s) 0
                          aux is idle in state(s) 0
                          daemon is idle in state(s) 0
                          queue is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 14.07ms; fastest: 0.00ms
                          HTTP sessions: 1 of 8
                          • WiFi -
                            Network state is running
                            WiFi firmware version 1.21
                            WiFi MAC address 80:7d:3a:3f:f5:90
                            WiFi Vcc 3.44, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 15664
                            WiFi IP address 10.1.10.178
                            WiFi signal strength -35dBm, reconnections 0, sleep mode modem
                          I have 3 of the drivers ( 5 6 7 ) along with 2 as Z motor drivers and I have them mapped but when I try to do any Z moves only drive 2 moved
                            dc42 administrators @Deanethiro
                            @deanethiro said in Board unresponsive:
                            Please post the config.g file.
                            Thye M122 report looks OK, all the drivers appear to be responding to SPI commands.
                              Deanethiro
                              ; generated by RepRapFirmware Configuration Tool v2 on Mon Feb 11 2019 12:17:42 GMT-0500 (Eastern Standard Time)
                              M667 S1 ; Select CoreXY mode
                              M550 P"Hypercube 25" V1" ; Set machine name
                              M552 S1 ; Enable network
                              M587 S"MkMachine2.4" P"9545725995" ; Configure access point. You can delete this line once connected
                              M586 P0 S1 ; Enable HTTP
                              M586 P1 S0 ; Disable FTP
                              M586 P2 S0 ; Disable Telnet
                              M569 P5 S1 ; Drive 5 goes forwards
                              M569 P6 S1 ; Drive 6 goes forwards
                              M569 P7 S1 ; Drive 7 goes forwards
                              M569 P8 S1 ; Drive 8 goes forwards
                              M569 P9 S1 ; Drive 9 goes forwards
                              M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
                              M92 X80.00 Y80.00 Z1600.00 E420.00:420.00 ; Set steps per mm
                              M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
                              M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; Set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; Set accelerations (mm/s^2)
                              M906 X800.00 Y800.00 Z800.00 E800.00:800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X625 Y625 Z625 S0 ; Set axis maxima
                              M574 X1 Y2 S1 ; Set active high endstops
                              M574 Z1 S2 ; Set endstops controlled by probe
                              M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                              M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X0 Y-25 Z2.5 ; Set Z probe trigger value, offset and trigger height
                              M557 X15:550 Y15:550 S40 ; Define mesh grid
                              M141 H5 ; Assign chamber heater to heater 0
                              M307 H6 B0 S1.0 ; Enable bang-bang mode for the bed heater and set PWM limit
                              M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                              M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
                              M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 2
                              M143 H2 S280 ; Set temperature limit for heater 2 to 280C
                              M305 P5 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 6
                              M143 H5 S120 ; Set temperature limit for heater 6 to 120C
                              M106 P0 S0 I0 F500 H-1 C"Parts Cooler Fan0" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                              M106 P1 S1 I0 F500 H1 T45 C"Hotend Fan Fan1" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              M106 P3 S255 I0 F500 H-1 C"LED Strip Fan3"
                              M563 P0 D0 H1 ; Define tool 0
                              M563 P1 D1 H2 ; Define tool 1
                              G10 P1 X25.784 Y0 Z0 ; Set tool 1 axis offsets
                              G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                              M584 X0 Y1 Z6:7:5:2 ; Z Motor Mapping
                              M671 X-22.0:670.0:-22.75:670.0 Y127.0:127.0:500.0:500.0 S5. P2.
                                Your M584 command is in the wrong place. Please read the section on order dependency in the entry for M584 on the GCodes wiki page. Also the section flagged Important in bold.
                                  Deanethiro
                                  Yup there we go turns out I am just stupid 😅 😅 😅 thank you so much
