Forum Feature - Mark as Question/Solved.
In order to make it easier to spot where a support question has been solved I have added a plugin to mark a topic as a question:
Once you have created the topic, then please mark it as a question if it is a support question.
It will then show up on the topic list as "unsolved":
Once its marked this way it can then be marked as solved:
Or reverted to a normal topic.
When it is marked as solved it shows up on the topic list as such:
Please help by marking topics as questions and then as solved where relevant. Also when you have a different unrelated question its best to start a new topic, you can link back to the old one if there is relavent information (such as a copy of your config.g) in the old topic.
@T3P3Tony
Hi Tony! I really like this feature and use it every now and then myself.
One thing I noticed though that might be improved: additionally to marking the topic as solved it is possible to select a reply as the correct answer to the question. This option is in the individual reply's 3-dot-menu - but only my own replies have the entry in the menu. Usually other people answer my questions but I cannot select their answers.Maybe this can be configured somewhere to allow every reply to be selected?
undefined T3P3Tony unpinned this topic
undefined infiniteloop referenced this topic
undefined T3P3Tony referenced this topic
