Duet Web Control 2.0.0-RC3 is ready
It runs on v0.6 systems ok aside from a no available sessions message today after 4 hours work.
Aside from that only complaint is the temperature values being clipped when the window is resized so 230 was clipped down to 23.
@dc42 said in Duet Web Control 2.0.0-RC3 is ready:
@3dmntbighker, I think the issue you refer to was buffer exhaustion in the firmware that runs on the WiFi module of the Duet WiFi.
Is the web interface reliable when you run DWC 1.22.6?
Ah right. No I have not tried to back rev. The print ran all night. The laser sensor paused it this morning (grrr), and now that I have the display connected I could resume the print to completion. But the DWC stopped working around 11 last night.
Hi, I just updated to 2.0.0-RC3 just to check it out(still on an incomplete printer hardware build at the moment), and only one quibble so far. I got one error in a red message box in the corner: "Failed to get file list Directory 0:/filaments not found"
I was able to pull the sd card, pop into my PC to add the directory to the root, but could the WebControl possibly just create the directory automatically if it doesn't exist rather than throwing an error? Its just a slight inconvenience because root directories can't be added through the interface either as far as I can tell.
- If I go to G-Code Console, select a whole line by first clicking right of it and dragging all the way left and some more, then hit CTRL+C, then select the input box and hit CTRL+V, there's an extra TAB character in the copied text.
- The mesh grid calibration results are no longer displayed after running it. I need to hit F5 so that it gets the latest data and then manually go to the Height Map.
- I can't find a Diagnostics button anywhere.
- Extrude and retract buttons are unusable. config: 0_1547976629806_config_edit.g
The g-code console no longer logs a message at start of build. I found that behaviour useful.
Edit: Saves going through:
(current time) - (elapsed time) + (simulated time) = (accurate finish time) -
One minor headache I have with RC3 is that I can no longer enter tab characters using the config text editor.
I'm having an odd issue.
Duet Wifi 1.04
Firmware 2.02
Wifi server 1.22
DWC 2.0.0RC3Sometimes I want to adjust the home position for the Z axis manually, instead of letting the Z probe do it. (I know, I shouldn't need to, and I should just change the Z offset, but I get different results at different temperatures, so...)
Anyway, entering into the G code console:
M558 P0
Then using the "home Z" button or the "home all" button.
It mostly works as expected, but for whatever reason, on the dialog box to jog the Z axis, I can only press each button once. After that there is a spinning circle in place of the adjust amount, and it will not respond to another click.
It does work when running a G29 mesh level, and I can press the same button repeatedly with the probe set to 0/manual, but it does not work with homing the Z axis.
I didn't end up trying alternate browsers, I only used Chrome, but I did use the Chrome on my PC, and I also tried my phone.
@supraguy You share this issue with me and at least one other user.
I am also having a problem with the height adjustment buttons. If I try to run auto calibration and check height manually, my height adjustment buttons will not refresh. If I run the calibration and exit and then use the homeall or home X Y or Z axis the button will not refresh.
@supraguy said in Duet Web Control 2.0.0-RC3 is ready:
Same here when trying to run manual Delta calibration using G32.
config.g
containsM558 P0 G31 X0 Y0
Using the old DWC (
/reprap.htm
) the process does work, though.
