DuetWifi driving me crazy
Which one is stable?
That version is fine. I'm not sure what your issue is then. I'm sure David will chime in soon.
I restarted everything again, now things are half-way working again. I can control the carriage and heat things up, Just can't change any of the system files without uploading them from the computer. Also that is the only way that I can upload a file to print, to the system folder, the gcode folder doesn't seem to exist to the Duet. If I could get that working then I think it would be smoother sailing
Have a look at the card structure on the SD card do you have a /sys and /gcode folder?
Hi, here are a couple of things to check:
1. If you connect Pronterface or S3D over USB and send M503, what response do you get? It should print the contents of config.g. The only folder and file you need on the SD card for that to work is sys/config.g.
2. Run M122 and look in the Platform Diagnostics section. After the "Free file entries" line there should be a line like this:
Do you see that line?
Our posts crossed. It sounds to me that your SD card is working OK now but you can't edit or upload files over WiFi. Is that what you are now finding? Does the System File Editor list the files in /sys, and does the GCode Files page list the files in /gcodes?
M503 now sends the config file, which is now working, just can't edit it from the Web interface.
M122 shows me what you posted (among other things).
The card works, I am running
Firmware Name:
RepRapFirmware for Duet WiFi
Firmware Version:
1.15e (2016-10-02)
WiFi Server Version:
1.02
Web Interface Version:
1.12I went back to the 1.15e to see if it was maybe the 1.16 beta that was causing problems.
Here is the complete diagnostic file incase it helps:
READ: === Diagnostics ===
READ: Used output buffers: 1 of 32 (11 max)
READ: === Platform ===
READ: Memory usage:
READ: Program static ram used: 19284
READ: Dynamic ram used: 83084
READ: Recycled dynamic ram: 32
READ: Current stack ram used: 2752
READ: Maximum stack ram used: 4108
READ: Never used ram: 24564
READ: Last reset 00:18:26 ago, cause: external
READ: Error status: 0
READ: Bed probe heights: 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
READ: Free file entries: 10
READ: SD card 0 detected, interface speed: 20.0MBytes/sec
READ: SD card longest block write time: 0.0ms
READ: MCU temperature: min 30.9, current 32.4, max 35.7
READ: Supply voltage: min 1.0, current 1.0, max 1.1, under voltage events: 0, over voltage events: 0
READ: Slowest main loop (seconds): 0.004517; fastest: 0.000000
READ: === Move ===
READ: MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
READ: === Heat ===
READ: Bed heater = 0, chamber heater = -1
READ: Heater 1 is on, I-accum = 0.0
READ: === GCodes ===
READ: Move available? no
READ: Stack pointer: 0 of 5
READ: macro is idle
READ: http is idle
READ: telnet is idle
READ: serial is ready with "M122"
READ: aux is idle
READ: file is idle
READ: === Network ===
READ: WiFiServer is running
READ: SPI underruns 0, overruns 0
READ: === Webserver ===
READ: HTTP sessions: 1 of 8
READ: ok
SENT: M105
READ: ok T:24.7 B:22.4
SENT: M105
READ: ok T:24.8 B:22.4
SENT: M105
READ: ok T:24.7 B:22.4 -
That is correct.
The system file editor now lists the /sys files, but the Gcode files are not listed in the /gcode -
What web browser are you using?
windows edge
Try using chrome or firefox. I haven't used windows edge but I know safari doesn't work well, and historically microsoft browsers are the worst in terms of supporting new features and frameworks.
But I just tried Firefox, I can now edit the config files with that and it saves them. Still can't see the gcodes file….
which is a step in the right direction, I can edit the configuration, just can't upload anything to print.
okay, found out what the problem was. The folder was named "gcodes-ormerod", apparently that is wrong and it must be just gcodes…. would love a slap forehead emoji right now...
can't tell my wife I have spent most of the day on this and it was a simple file name change…
I am glad you sorted it. For reference, you can find the required SD card folder structure here https://duet3d.com/wiki/SD_card_folder_structure.
The web interface should really support all browsers. This is 2016, not 1997.
It's not always possible. MS have never followed compliance. If all browsers were WebKit then 100% compliance could be achieved with ease.
