    Firmware 2.03beta2 available
    Firmware installation
    25
    86
    12.1k
      deckingman @wilriker
      @wilriker Very nice ☺
        I've put an update to firmware 2.03beta2 for the Duet WiFi/Ethernet and Maestro at https://www.dropbox.com/sh/mk3jlsoi6gyxd8q/AABbEvX2qb19McbRe6UvRmI9a?dl=0. Changes in this version:
        • New M505 command to support multiple configurations more easily (see separate thread)
        • Bug fix for file selection on 12864 displays on the Maestro
        • Bug fix for CNC and laser machines (was complaining about attempts to move outside the allowed limits during homing)
        • Increase max numbers of extruders and heaters per tool to 8 on the Duet WiFi/Ethernet
        • Babystepping command (M290) now works on any axis, however at present only Z babystepping can jump moves in the movement queue
        • NicoLab28undefined
          NicoLab28
          there have been changes for the M291 triggers / messages in tool change macros?
            dc42 administrators @NicoLab28
            @nicolab28 said in Firmware 2.03beta2 available:
            M291 sets baby stepping, it has nothing to do with triggers.
              NicoLab28
              M290 is for baby stepping.
              I'm talking about blocking tool change macro with a message using trigger and M582.
              When we put M291 command in trigger#.g
              https://forum.duet3d.com/topic/8381/m291-s2-does-not-block-macro-execution
                My mistake, M291 is for displaying messages and optionally waiting for a response.
                What are you trying to use M291 in a trigger to do?
                  NicoLab28
                  Interrupt the tool change macro, to make a manual intervention, and resume.
                  In tfree.g tpre.g or tpost.g, if we make an M582, then an M291 in trigger # .g the message arrives after the end of the tool change.
                  As a result, the problem could not be resolved
                  • pawPrinterundefined
                    pawPrinter
                    CoreXY working well here, along with leadscrew bed levelling and sensorless homing
                      dc42 administrators @pawPrinter
                      @pawprinter said in Firmware 2.03beta2 available:
                      Thanks for your feedback.
                      • pkosundefined
                        pkos
                        One note from me (just in case you didn't notice this in the other thread) - I've been having quite a bit of issues with the metadata readout from Slic3r PE generated files. More often than not, I don't get info about object height and other parameters. I don't know what the rule is. Headers and footers of both good and bad files seem to be pretty much the same.
                        Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
                          dc42 administrators @pkos
                          @pkos said in Firmware 2.03beta2 available:
                          Can you provide samples of files that don't work? Or if you have already done so, point me towards that thread.
                          pkosundefined 1 Reply Last reply Reply Quote 0
                          • pkosundefined
                            pkos @dc42
                            @dc42 Here you go.
                            https://forum.duet3d.com/topic/8440/rrf-2-02-slic3r-pe-1-41-2-filament-used-and-print-times-wrong
                            I can generate loads of these.
                            So far, I have 8 files on my Duet. 6 don't have the data displayed (also in the new UI, which is actually causing errors thrown in the new UI) and 2 good ones.
                            I did upload just the header/footer, but if you need the whole thing, let me know and I'll get it all going.
                            • kraegarundefined
                              kraegar
                              2.03b2 is working great on the RailCore for me. 3 z leveling works fine, corexy motion is good. Thumbs up so far!
                              • gavatron3000undefined
                                gavatron3000
                                CoreXZ also working normally
                                  dc42 administrators @gavatron3000
                                  @gavatron3000 said in Firmware 2.03beta2 available:
                                  Thanks!
                                  • oliofundefined
                                    oliof
                                    I upgraded the MPSCARA bot we're discussing elsewhere to 2.03beta2, and behavior is stable.
                                    • gideonundefined
                                      gideon
                                      hello I just updated the firmware to 2.03, I had an older version more 2.00
                                      now the next I have a corexy homex, homy, homez do not work well anymore, seems like everything goes the other way,
                                      home all does not work anymore,
                                      who can tell me what I am doing wrong M669 only used it because I had to think that I would miss some things again,
                                      who can help me
                                      ; homez.g
                                      ; called to home the Z axis
                                      T0; select tool
                                      G91
                                      M280 P3 S160 I1; relative coordinates
                                      G1 S1 Z0 F2000, lower bed
                                      G4 P500, wait for the bed to lower
                                      G90: absolute positioning
                                      G1 S1 X200 Y200 F3000, move to center
                                      M401, deploy the probe
                                      G30, calibrate Z-axis
                                      M402; Retract Probe
                                      ; homey.g
                                      M915 X Y S3 F0 R0; configure stall detection
                                      M574 X1 Y1 S3; set endstops to use motor stall
                                      M913 X50 Y50; reduce motor current to 50% to prevent belts slipping
                                      G91; use relative positioning
                                      G1 S1 Z0 F2000; lower bed
                                      G1 S1 Y-400 F3600; course home Y
                                      G1 S1 Y2; move away from end
                                      G90; back to absolute positioning
                                      M400; make sure everything has been stopped before we reset the motor currents
                                      M913 X100 Y100; motor currents back to normal
                                      ; homex.g
                                      G1 S1 X-400 F3600; course home X
                                      G1 S1 X2; move away from end
                                      M574 X1 Y1 S1; set endstops back to normal
                                      ; homeall.g
                                      ; Sensorless Homing test file
                                      M400; make sure everything has been stopped before we make changes
                                      M574 X0 Y0 S3; set endstops to use motor stall
                                      G1 S1 X-400 Y-400 F3600; move right / back 325mm, stopping at the endstop
                                      G1 X5 Y5; move away from home
                                      ; X or Y is homed at this point, now home the other axis
                                      G1 X-400 F3600 S1; move towards axis minimum
                                      G1 Y-400 F3600 S1; move towards axis minimum
                                      G1 X1 Y1; move away from home
                                      M913 X100 Y100; motor currents back to 100%
                                      M574 X1 Y1 S1; define active low microswitches
                                      ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
                                      ; Gideon
                                      ; generated by RepRapFirmware Configuration Tool on Tue Jan 02 2018 16:42:45 GMT + 0100 (Western Europe (standard time))
                                      M111 S0; Debugging off
                                      G21; Work in millimeters
                                      G90; Send absolute coordinates ...
                                      M83; ... but relative extruder moves
                                      M555 P2; Set firmware compatibility to look like Marlin
                                      M669 S1; Select CoreXY mode
                                      ; S1 for CoreXY, S2 for CoreXZ, and S3 for CoreYZ
                                      M208 X0 Y0 Z0 S1; Set axis minima S1 = minimum
                                      M208 x390 Y390 Z590 S0; Set axis maxima S0 = maximum
                                      M574 X1 Y1 S1; Set of active low end stops X1 Y1 S1
                                      M574 Z1 S2; Set endstops controlled by probe
                                      ; Z-probe (PNP LJ12-a3-4)
                                      M307 H3 A-1 C-1 D-1; Disable the 3th Heater to free up PWM channel 5 on the Duex board
                                      ; Connect the sensor output to one end of a resistor (call this R1), and connect one end of
                                      ; another resistor (call this R2) to GND on the Z-probe connector. Connect the free ends of R1 and R2
                                      ; together and to the IN pin of the Z-probe connector. The values ​​of R1 and R2 should be chosen so that
                                      ; about + 3V appears at their junction when triggered. If R2 is 10K, then suitable values ​​of R1 are 30K
                                      ; if the sensor is powered from + 12V
                                      ; Connect between the IN and GND terminals or the Z probe connector.
                                      M558 P8 X0 Y0 Z1 H3 I1 F100 T10000 A1 R0.5; also try mode 8 (= unfiltered faster mode 5)?
                                      ; Z1 = Z-probe is used to home this axis; XO, YO = z-probe not used for homing
                                      ; H = defines the Z probe dive height, which
                                      is the height above the trigger height from which probing starts.
                                      ; F = The speed of Z probing
                                      ; T = the speed at which the head travels to the Z probe coordinates are specified for bed probing
                                      ; R = defines the Z probe recovery time in seconds. The printer will pause for this time just before starting the probing move
                                      ; !!!! ABL Z-OFFSET !!!
                                      ; Volcano 08 nozzle
                                      ; G31 X30 Y0 Z1.35 P600
                                      G31 X30 Y0 Z1.085 P600; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                                      ; this must come after M558.
                                      ; !!! THE HIGHER the Z-offset, the deeper the nozzle goes into the bed !!!
                                      M557 X32: 392 Y10: 360 S72: 50; Define mesh grid
                                      ; S = Probe point spacing
                                      M569 P0 S1; Drive 0 goes forwards
                                      M569 P1 S1; Drive 1 goes forwards
                                      M569 P2 S0; Drive 2 goes forwards
                                      M569 P3 S1; Drive 3 goes forwards
                                      M350 X16 Y16 Z16 E16 I16; Configure microstepping without interpolation E16
                                      M92 X80 Y80 Z400 E2667; Set of steps per mm E2670
                                      M566 X900 Y900 Z60 E50; Set maximum instantaneous speed changes "jerk" (mm / min) 40 -> 80 with 0.05 PA -> 120 with 0.04 -> 100 with 0.03 -> 400 -> 0.1 PA and 400 E80 E40
                                      M203 X18000 Y18000 Z600 E3600; Set maximum speeds (mm / min) Z400
                                      M201 X1000 Y1000 Z250 E140; Set of accelerations (mm / s ^ 2) X1000 Y1000 Z250 E400 E800 E1600 E140
                                      M906 X2000 Y2000 Z1500 E1500 I30; Set motor currents (mA) and motor idle factor in per cent
                                      M913 X100 Y100 Z100 E100; motor currents back to normal
                                      M84 S30; Set idle timeout
                                      M305 P0 T100000 B3950 C0 R4700; Set thermistor + ADC parameters for heater 0
                                      M143 H0 S130
                                      M307 A221.0 C312.8 D0.9 S1 V12.5; Set temperature limit for heater 0 to 120C
                                      M305 P1 T100000 B4725 H30 L0 R4700; Set thermistor + ADC parameters for heater 1
                                      M143 H1 S280; Set temperature limit for heater 1 to 280C
                                      M307 H1 A335.8 C120.0 D4.4 S1 V12.6; PID settings
                                      M303 H1 P0.85 S280
                                      Heater 1 model: gain 335.8, time constant 120.0, dead time 4.4, max PWM 1.00, calibration voltage 11.9
                                      Heater 1 model: gain 226.2, time constant 125.8, dead time 7.9, max PWM 0.60, calibration voltage 12.6
                                      Heater 1 model: gain 228.2, time constant 124.0, dead time 7.5, max PWM 0.60, calibration voltage 12.6
                                      ; Heater 0 model: gain 221.0, time constant 312.8, dead time 0.9, max PWM 1.00, calibration voltage 12.5
                                      M563 P0 D0 H1; Define tool 0
                                      G10 P0 X0 Y0 Z0; Set tool 0 axis offsets
                                      G10 P0 R0 S0; Set initial tool 0 active and standby temperatures to 0C
                                      ; pressure advance
                                      M572 D0 S0.08; 0.03 - 1 = waveguide time x 3 0.05 0.04 0.1 (1st WG)
                                      M550 PHEVO Gideon; Set machine name
                                      M552 P192.168.0.35; static IP
                                      M554 P192.168.0.1; gateway
                                      M552 P255.255.255.0; netmask
                                      M552 S1; Enable network
                                      ; *** Access point is configured manually via M587
                                      M586 P0 S1; Enable HTTP
                                      M586 P1 S1; Enable FTP
                                      M586 P2 S1; Enable Telnet
                                      M106 P0 S0 IO F500 H-1; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                      M106 P1 S1 IO F500 H1 T60: 140; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                      M106 P2 S1 IO F500 H1 T60: 140; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                      gavatron3000undefined 1 Reply Last reply Reply Quote 0
                                        gavatron3000 @gideon
                                        @gideon said in Firmware 2.03beta2 available:
                                        who can help me
                                        ; homez.g
                                        T0; select tool
                                        G91
                                        M402; Retract Probe
                                        ; homey.g
                                        ; homex.g
                                        ; homeall.g
                                        ; Gideon
                                        ; Volcano 08 nozzle
                                        M143 H0 S130
                                        M303 H1 P0.85 S280
                                        ; pressure advance
                                        M669 K1 instead of S1
                                        • gideonundefined
                                          gideon
                                          oke thanks
                                          • gideonundefined
                                            gideon
                                            I get 1 error when I want to print
                                            10-3-2019 15:26:18:: FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi / Ethernet FIRMWARE_VERSION: 2.03beta2 + 1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-02-23b1
                                            Canceled printing file 0: /gcodes/Body1.gcode, print time was 0h 2m
                                            Error: G0 / G1: insufficient axes homed
