    Motors will not spin on Z and E
    • 3DPotterundefined
      3DPotter
      We are using two different kinds of motors, but for the Z and E we are using we are using Nema 23 bipolar 2.8 amps (JK57HS56-2804) with gear boxes for extra power. On the X and Y we are using iHSS57-36-10 closed loop.
      On other models of our printers we use iHSS57-36-10 for all motors which is working fine coming off of the expansion connector pins. They work Fine.
      We are now trying to use the main drives. (Drive 2 and Drive 3).
      Motors don't spin please help.
      Here is our config file:
      ;7 2/27/2019 3D Potter
      M111 S0 ; Debug off
      M550 Potterbot 7 ; Machine name and Netbios name (can be anything you like)
      M551 Preprap ; Machine password (used for FTP)
      ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
      ;networking
      M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
      M552 S1 ; start wifi S2 OR S1 network
      M555 P2 ; Set output to look like Marlin
      G21 ; Work in mm
      M584 X5 Y6 Z7 E9 ; Set drive mapping Axis and motor configuration
      M569 P5 S1 R0 T4 ; Drive 0 goes forwards X
      M569 P6 S1 R0 T4 ; Drive 1 goes forwards Y
      M569 P2 S0 R0 T4 D2 ; Drive 2 goes forwards Z
      M569 P3 S0 R0 T4 D2 ; Drive 6 goes forwards E
      M574 X1 Y2 Z2 S0 ; Endstop configuration
      M208 X420 Y370 Z550 ; set axis maxima and high homing switch positions (adjust to suit your machine)
      M208 X0 Y0 Z0 S1 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
      M92 X72.70 Y72.70 ; Set axis steps per unitX72.70 Y70.85
      M350 X16 Y16 Z16 E16 I1 ; Set 1x microstepping with interpolation
      M92 Z6359.75 E150 ; Steps/mm for Z and E WAS 8
      M906 X0 Y0 Z2000 E2000 I30 ; Set motor currents (mA) and increase idle current to 60%
      M201 X5000 Y5000 Z2000 E3000 ; Accelerations (mm/s^2)
      M203 X5000 Y5000 Z8000 E5000 ; Maximum speeds (mm/min)
      M566 X5000 Y5000 Z800 E5000 ; Maximum instant speed changes mm/minute
      M581 Z1 S1 C1 ;Configure external trigger
      ; Tool definitions
      M563 P0 D0 ;enable cold extrusion.M563 P0 D0 H1
      ;G10 P0 X0 Y0 Z0 ;Set tool 0 axis offsets
      G10 P1 ;Set initial tool 0 active and standby temperatures to 0C G10 P0 R00 S00
      T0
      M302 P1 ; cold extruder
      M140H-1 ; BED OFF
      ;*** If you are using axis compensation, put the figures in the following command
      ;M556 S78 X0 Y0 Z0 ; Axis compensation here
      ; Misc
      M83
      M302 P1
      ;M143 H1 S260 ; Maximum heater temperature
      ;M140 H-1 ; No bed heater
      ;M305 P1 T100000 B4138 C0 R4700 ; Thermistor parameters for heater 1
      ;M307 H1 A577.0 C199.0 D9.8 S1.00 B0
      Our heaters are turned off as we 3D print clay, there is no heater.
      https://3dpotter.com/
      The only dedicated 3D ceramic printer using real clay.
      https://www.instagram.com/3dpotter/
      https://www.youtube.com/c/3dpotter/
      https://www.facebook.com/3dpotter/
      https://www.reddit.com/user/3D_Potterbot
        T3P3Tony administrators
        @3dpotter said in Motors will not spin on Z and E:
        Ho do you have the motors connected? the M584 command has them connected to Drive 7 (Z) and Drive 9 (E) so on the expansion header or Duex5. The M569 command imples you have them connected to Drive 2 and Drive 3...
        • 3DPotterundefined
          3DPotter
          That was it. Thank you.
          Staring me right in the face.
