    Firmware erroneously adds 4.25-4.50mm to Z height
    1.3k
      We'd need to see your homing and bed.g files as well.
      Also what firmware version?
      • Absensmentisundefined
        Absensmentis
        Sure! here they are... This is 1.21RC1
        ; homeall.g
        ; called to home all axes
        ; generated by RepRapFirmware Configuration Tool v2 on Wed Feb 27 2019 21:47:03 GMT-0800 (Pacific Standard Time)
        G91 ; relative positioning
        ;G1 Z5 F6000 S2 ; lift Z relative to current position
        G1 S1 Y-705 F1800 ; move quickly to X or Y endstop and stop there (first pass)
        G1 S1 X-780 F1800 ; move quickly to X or Y endstop and stop there (first pass)
        G1 S1 Y-705 ; home Y axis
        G1 S1 X-780 ; home X axis
        G1 X5 Y5 F1000 ; go back a few mm
        G1 S1 Y-705 ; then move slowly to Y axis endstop
        G1 S1 X-780 F360 ; move slowly to X axis endstop once more (second pass)
        ;G1 Z-5 F6000 S2 ; lift Z relative to current position
        G1 S1 Z723 F1800 ; move Z up stopping at the endstop
        G90 ; absolute positioning
        ;G92 Z718 ; set Z to axis minimum (you may want to adjust this)
        ;G91 ; relative positioning
        ;G1 S2 Z5 F100 ; lift Z relative to current position
        ;G90
        ; homex.g
        ; called to home the X axis
        ; generated by RepRapFirmware Configuration Tool v2 on Wed Feb 27 2019 21:47:04 GMT-0800 (Pacific Standard Time)
        G1 S1 Y-780 F1800 ; move quickly to y axis endstop and stop there (first pass)
        G1 S1 X-780 F1800 ; move quickly to X axis endstop and stop there (first pass)
        G1 X5 F6000 ; go back a few mm
        ;G1 Z-5 F6000 S2 ; lower Z again
        ; homey.g
        ; called to home the Y axis
        G1 S1 Y-705 F1800 ; move quickly to Y axis endstop and stop there (first pass)
        G1 Y5 F6000 ; go back a few mm
        G1 S1 Y-705 F360 ; move slowly to Y axis endstop once more (second pass)
        ; homez.g
        ; called to home the Z axis
        G1 S1 Z723 F1800 ; move Z up until the endstop is triggered
        ;G92 Z718 ; set Z position to axis minimum (you may want to adjust this)
        ;G90 ; absolute positioning
        ; bed.g
        M557 X0:775 Y0:700 S36.8
        G29 ; probe the bed and enable compensation
          I think you may be affected by a z height bug that was present in that firmware version. Eitherway, release candidates aren't supported once the stable release is available. I would strongly suggest backing everything up and upgrading to 2.02 before proceeding with any more troubleshooting.
            Absensmentis
            I just now noticed the web interface said the "Maximum deviations: -4.265 / -2.827 mm" so I assumed the 4.25 is from the bed height map. I disabled the line "G29 S1 ; Enable" and it now shows the "true" z height value. I will try to get my deviation values lower with some manual leveling to see if it helps that value out... Is that normal or do I have a problem?
              One thing about Z max homing is that you need to know exactly how far your z max endstop is from the bed surface. As your homing files are now, it will set your height to be whatever the z axis maxima is set to from config.g. In this case 700mm. So I suspect that this isn't accurate.
              There are a few ways to address this. Here's how I do it with my Z max optical endstop. I have a macro that allows me to move the nozzle to just touch the nozzle to the bed, sets Z0, and then moves the z axis to my max z height, in my case, 300mm. I then adjust the flag of the endstop until it's just triggered so that I'm confident when the endstop triggers, it's actually 300mm from the bed surface.
                Phaedrux Moderator @Absensmentis
                @absensmentis said in Firmware erroneously adds 4.25-4.50mm to Z height:
                Yes, as I said, I think you should update your firmware.
                What is your z probe type? Do you only use it for probing?
                  Absensmentis
                  This is the most recent version available so I'm afraid updating again won't do much. I uploaded with SAM-BA and verified the MD5 hash when downloading to be 100% positive that every last bit was correct. I did this because my (real!) duet arrived in an erased state. For now I am using a nozzle mounted microswitch with a Z offset of 7.18mm and the actual Z height is about 718.55 at room temperature. I only use it for probing, I would like if I could use it to calculate Z also but I haven't seen anything about this FW being able to do such a thing. I just put "safe" values in to prevent a nozzle crash because my Z axis is strong enough to absolutely demolish the machine should it fail to stop at an appropriate distance
                    Absensmentis
                    re-uploading the DC42 firmware has not changed anything sadly
                      Just to confirm, firmware version 2.02?
                      https://github.com/dc42/RepRapFirmware/releases/tag/2.02
                        One way to minimize the risk of this is to reduce the motor current to the bare minimum during probe and homing moves and reverting to normal afterwards.
                        If you're confident that your microswitch accurately sets Z0 you can use it to home Z. Is there a particular reason you need to home to Z max, especially on such a long Z axis.
                          Absensmentis
                          I am rather confused, I downloaded it from that github but my version is 1.21???... I will get the actual latest version uploaded. As for the reduced current during homing, I will have to do that. thanks for the great suggestion.
                            You'll need to update to firmware 2.0 first using the normal method described here: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                            Then you can use the new simplified update method by uploading the entire 2.02a zip file. The Duet will extract the binaries and install what needs updating automatically.'
                            https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02a.zip
                            I would recommend taking a look at the release notes between 1.21 and 2.02 as well.
                              Absensmentis
                              No matter what I do it wont change from the following versions.
                              Firmware Version: 1.21RC1 (2018-01-25)
                              WiFi Server Version: 1.21
                              Web Interface Version: 1.21.2-dc42
                              it recognizes the bin files and claims to upload them but it lies. I guess now nuke the board and use SAM-BA again?
                                Absensmentis
                                Now I believe the current 2.02 bin file is incorrect, if I upload it to the board it becomes entirely unresponsive
                                  Can you try the full version of 1.21 first?
                                  https://github.com/dc42/RepRapFirmware/releases/tag/1.21
                                  Then if that works, 2.0.
                                  Then if that works, 2.02.
                                  Are you using the "Usual procedure" as shown here? https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Usual_procedure
                                  Samba should be the last option if the other fall back procedures don't work.
                                  • Synapsisundefined
                                    Synapsis
                                    May not be your problem but I had a similar problem when homin it would stop above the bed by about that amount
                                    found out it was my Z probe that if it was moved evey so little would get a bad read and trigger early.
                                    Checking it was tight straight etc. it would home correctly. It drove me crazy as I thought it was something in the config.g
                                    and tried so many things to no avail.
                                      As you are on 1.21RC1 you may need to follow the procedure for updating from 1.20 to 1.21 or later. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_a_Duet_2_WiFi_or_Ethernet_to_firmware_1_21_or_later_from_1_20_or_earlier.
