    Firmware erroneously adds 4.25-4.50mm to Z height
    1.2k
      Phaedrux Moderator @Absensmentis
      @absensmentis said in Firmware erroneously adds 4.25-4.50mm to Z height:
      or do I have a problem?
      Yes, as I said, I think you should update your firmware.
      What is your z probe type? Do you only use it for probing?
      • Absensmentisundefined
        Absensmentis
        This is the most recent version available so I'm afraid updating again won't do much. I uploaded with SAM-BA and verified the MD5 hash when downloading to be 100% positive that every last bit was correct. I did this because my (real!) duet arrived in an erased state. For now I am using a nozzle mounted microswitch with a Z offset of 7.18mm and the actual Z height is about 718.55 at room temperature. I only use it for probing, I would like if I could use it to calculate Z also but I haven't seen anything about this FW being able to do such a thing. I just put "safe" values in to prevent a nozzle crash because my Z axis is strong enough to absolutely demolish the machine should it fail to stop at an appropriate distance
          Absensmentis
          re-uploading the DC42 firmware has not changed anything sadly
            Just to confirm, firmware version 2.02?
            https://github.com/dc42/RepRapFirmware/releases/tag/2.02
              One way to minimize the risk of this is to reduce the motor current to the bare minimum during probe and homing moves and reverting to normal afterwards.
              If you're confident that your microswitch accurately sets Z0 you can use it to home Z. Is there a particular reason you need to home to Z max, especially on such a long Z axis.
                Absensmentis
                I am rather confused, I downloaded it from that github but my version is 1.21???... I will get the actual latest version uploaded. As for the reduced current during homing, I will have to do that. thanks for the great suggestion.
                  You'll need to update to firmware 2.0 first using the normal method described here: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                  Then you can use the new simplified update method by uploading the entire 2.02a zip file. The Duet will extract the binaries and install what needs updating automatically.'
                  https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02a.zip
                  I would recommend taking a look at the release notes between 1.21 and 2.02 as well.
                    Absensmentis
                    No matter what I do it wont change from the following versions.
                    Firmware Version: 1.21RC1 (2018-01-25)
                    WiFi Server Version: 1.21
                    Web Interface Version: 1.21.2-dc42
                    it recognizes the bin files and claims to upload them but it lies. I guess now nuke the board and use SAM-BA again?
                      Absensmentis
                      Now I believe the current 2.02 bin file is incorrect, if I upload it to the board it becomes entirely unresponsive
                        Can you try the full version of 1.21 first?
                        https://github.com/dc42/RepRapFirmware/releases/tag/1.21
                        Then if that works, 2.0.
                        Then if that works, 2.02.
                        Are you using the "Usual procedure" as shown here? https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Usual_procedure
                        Samba should be the last option if the other fall back procedures don't work.
                        • Synapsisundefined
                          Synapsis
                          May not be your problem but I had a similar problem when homin it would stop above the bed by about that amount
                          found out it was my Z probe that if it was moved evey so little would get a bad read and trigger early.
                          Checking it was tight straight etc. it would home correctly. It drove me crazy as I thought it was something in the config.g
                          and tried so many things to no avail.
                            As you are on 1.21RC1 you may need to follow the procedure for updating from 1.20 to 1.21 or later. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_a_Duet_2_WiFi_or_Ethernet_to_firmware_1_21_or_later_from_1_20_or_earlier.
