Can't move X axis after successful home (Core XY)
I've been searching these forums for a while and can't find anyone else mentioning an issue like this. I have a Tronxy X5S and have just finished wiring up my Duet Maestro.
I can home all axis successfully, and can manually move the Y and Z axis, however the X axis won't respond to manual move commands after homing. The odd time that it does, i get a horrible noise from the machine, as if the belt is jumping teeth or something.
Admittedly i may have gone beyond my skills with this project, but any help would be immensely helpful!
I've attached my config file for reference.
@jondaniel What firmware version are you using? I note that you have M667 S1 in your config.g but this is deprecated in firmware 2.03 and later. So, if you are using a later firmware, use M669 K1 instead of M667 S1. See release notes here https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
@deckingman Thanks for the quick reply! I'll check my firmware (update if necessary) and change that M667 code tonight and report back.
you might have x going in the opposite direction.
after it hits the endstop it might try going further but it cant since it already hit the endstop. -
@veti said in Can't move X axis after successful home (Core XY):
after it hits the endstop it might try going further but it cant since it already hit the endstop.That'd be my guess too.
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
Check your movement section against the guide here. Particularly the commissioning section to verify motor direction.Commissioning
During commissioning, you can test the X and Y motors independently by using the S2 modifier on the G1 command, like this:G91 ; relative mode
G1 S2 X10 ; move the X motor forward 10mm
G1 S2 X-10 ; move the X motor back 10mm
G1 S2 Y10 ; move the Y motor forward 10mm
G1 S2 Y-10 ; move the Y motor back 10mm
G90 ; back to absolute mode -
Thanks, i'll try that after i've checked firmware. I figured the motor direction wasn't an issue because the y axis moves properly. Wouldn't that mean that both the x and y motors are spinning correctly since they're both used for both axis?
Well the only reason it might be homing in the right direction is that the homing file is telling it to move backwards....
Thanks everyone that gave me direction on this one. I'm running firmware 2.02RC5(RTOS) (2018-11-28b1).
Turns out you were right @ phaedrux. I had my motors AND my endstops backwards, making it appear as though everything was playing nice. I flipped the motors and home code around and it's moving as expected now!
I really appreciate the help!
