    Core-XY based on Rat Rig V-Core and Duet 2 Ethernet
    My Duet controlled machine
    15
    176
    27.0k
      deckingman @snoozer
      @snoozer Good luck.
      The temperature over shoot will go away when you tune the heater https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
      • snoozerundefined
        snoozer
        For my testing with the Duet 2 I thought its best to make some kind of stand so I can safely wire things up outside the printer and have a bit of cooling. I don't think is actually need the active cooling but just to be on the safe side I added a fan....
        https://www.thingiverse.com/thing:3481622
        Fusion 360 files are downloadable and linked on thingiverse.
        Have FuN!
        Jan
        Regards Jan
        My Printers:
        #1 Prusa i3 MK3 kit all stock (Retired)
        #2 Rat Rig V-Core Core-XY (Almost finished but fully usable)
        My Experiments:
        https://www.thingiverse.com/snoozer17/designs
          deckingman @snoozer
          @snoozer
          It's fun designing things but for info, you could have saved yourself a bit of time and printed a case that I designed and which takes a fan https://www.thingiverse.com/thing:1830918. ☺
          snoozerundefined 1 Reply Last reply Reply Quote 0
          • snoozerundefined
            snoozer @deckingman
            @deckingman
            Oh VERY nice !!! I did not even look for anything Just did a quick and dirty thing.... As a final solution I probably add a double layer of plastic sheet on the back side of the printer similar to what E3D has on their tool-changer prototype cause I will have PSU and Solenoid for the heated bed as well as a PSU for LED lights, cabinet temperature control and a Raspberry Pi or similar for the webcam there as well. That would also make for clean wiring I hope. For now what I printed will do me, easy access and no worries about heat and shorts....
            Jan
            Regards Jan
            My Printers:
            My Experiments:
            • snoozerundefined
              snoozer
              More parts have arrived.......
              My temporary solution for the heated bed, a adhesive 24V silicon heater pad, inductive proximity switch, end stops with roller levers and the spring steel sheet with adhesive PEI.
              The bed heating and print surface are temporary items just to start doing things. The goal remains to be a mains heated 1.1kW bed from E3D. I have not yet found a final solution for a print surface, so I am still on the look out for a factory coated spring steel sheet with PEI. I am also looking at a Piezo based Z-Probe, I may get hold of a alpha version from someone Tom's 3D printer forum, if that should work I may also consider a glass print surface but I have never printed on glass, so that's another experiment.
              The tubing is to guide the filament from the spool holder to the hotend, it is direct drive but I prefer the spool holder detached from the printer to avoid large masses amplifying potential resonances in the printers mechanic on quick moves. I have had a spool holder on my Prusa printer attached to the frame which caused a lot of movement.
              Jan
              Regards Jan
              My Printers:
              My Experiments:
              • snoozerundefined
                snoozer
                Before ppl mention it, no I very much dislike the location of the termistor, this was not clear to me before I ordered. I had preferred it to be near the middle of the heater. I do like the fact the cables are in a silicone tubing.
                Jan
                Regards Jan
                My Printers:
                My Experiments:
                  deckingman @snoozer
                  @snoozer said in Core-XY based on Rat Rig V-Core and Duet 2 Ethernet:
                  Jan
                  Depending on how thick the aluminium bed is, then having a thermistor close to the heating element is really bad idea. The reason is that it takes a certain amount of time for the heat to find it's way to the top surface of the plate. So what happens is, when the heater comes on, the thermistor "sees" the rise in temperature at the heating element so the firmware turns the heater off (or more precisely adjusts the PWM value if you aen't using "bang bang" mode). Then it waits a short time for the temperature to drop, then starts heating again but it very rapidly reaches a high temperature at the heater to plate interface so the heater turns off and the cycle repeats. The net result is that it takes a very long time for the upper surface of the build plate to reach the required temperature. What I did with my thick aluminium plate was to drill a small hole in the edge, close to the top surface and as deep as I could, the fitted the temperature sensor onto that hole.
                  • snoozerundefined
                    snoozer @deckingman
                    @deckingman
                    That sounds very plausible, if I was intending to use that set-up in the long run I would consider that suggestion. IDK for sure how E3D has done that, the documentation and spec sheet does not give away a lot of detailed info. I would just assume they know what they are doing. I am however still pondering over another issue. Making it magnetic for a spring steel sheet. I was thinking to machine little round holes in the bottom to maybe 0.3 mm below the top surface to add magnets from below the alumimium plate. Would the aluminium prevent the magnetism to work ? Sure on the E3D heater that would not work at all since the heater is fixed by the factory. An adhesive magnetic surface is really not what I think is the good way to go, then I'd rather use fixing clips at the edges I guess. Another idea was to have 2-3 index pins on the heated bed and corresponding precise holes in the print surface so there can be no lateral movement of the print surface but would that be bad for heat conductivity if there is only the weight of the print surface to make contact between bed and surface........ The print bed is for me personally the biggest challenge to figure out yet.
                    Jan
                    PS: Looking at the E3D assembly guide it looks as if the termistor is at least in the middle, if its in a machined groove or hole is not really clear to see.
                    https://e3d-online.dozuki.com/Guide/High+temperature+bed+assembly+guide./80?lang=en
                    Regards Jan
                    My Printers:
                    My Experiments:
                      deckingman @snoozer
                      @snoozer I don't know what E3d's heated bed is made of but from the pictures in the link you supplied, it doesn't look very thick. In which case, I doubt that there would be much of a problem with heat transfer from the underside to the top side. Quite how flat that heated bed would be is another matter.
                      I just kind of assumed that you would use something like 8mm thick aluminium tooling plate for you bed. I chose 10mm thick but in hind site, 8mm would have sufficient.
                      I've just noticed that in the RatRig kit you get a 3mm thick aluminium heat spreader. Personally, I'd simply throw that away....
                      • snoozerundefined
                        snoozer @deckingman
                        @deckingman
                        You are probably right with that, I have no experience with building my own yet. Nothing is set in stone for me only that is has to be Core-XY and I want to use the Duet 2. So you are using an adhesive heat pad ? Can that go to 110-120 degree c without issues ? E3D is recommending a glass surface, that should be level enough as long as there is no excessive force applied. True, that does not really give me any assurance regarding my spring steel sheet idea.
                        Jan P.
                        Regards Jan
                        My Printers:
                        My Experiments:
                        • snoozerundefined
                          snoozer
                          I had a look around for adhesive silicone heaters, in the usual places for 3D printers they don't show much actual tech specs and they seem rather cheap. If I look at RS Components for example they state continuous operating temperatures of 150-200 degree c. Is that realistic ? At RS they are around the 130-180 euro mark for heaters approx 300x300 or the imperial counterpart. The adhesive part would be the most worrying to me. Will it be durable or peel away from the aluminium plate......
                          Jan
                          Regards Jan
                          My Printers:
                          My Experiments:
                            deckingman
                            @snoozer I bought my heater from AliExpress. I can't off hand remember the seller, it might have been this one https://www.aliexpress.com/item/1400w-240V-400-x-400mm-Silicone-Heater-Bed-Heating-Pad-for-3D-Printer-Without-Hole-Office/32880041524.html. They will make any size, any voltage, any wattage. I know it's from China and like most of us, you might have reservations - I did initially. All I can say is that it has worked flawlessly for the past 3 to 4years.
                            As I said, I use flat, aluminium tooling plate, 10mm thick) although 8mm thick would be fine. The heater is stuck to the underside and I use two layers of semi-rigid insulation under that. I use 6mm thick glass on top because it is flat, cheap, and I like having a removable print surface so that as soon as one print is finished, I can start another without waiting for the bed to cool.
                            I use 3 lead screws, one near the each corner at the forint and one in the centre at the back. These are driven with a single motor via a continuous belt. Initial levelling is done by slackening the pulleys on the lead screws and adjusting each one. Subsequent levelling isn't needed. The bed is flat and level and stays that way.
                            I don't use any form of bed level or flatness compensation and I can do things like this https://www.youtube.com/watch?v=U733PMTou7M.
                            That's an old video - these days I use 3DLac on my glass which allows me print the first layer very much faster. In fact, I don't slow the speed down at all for the first layer so typically lay it down at 90mm/sec. Oh and I can also do things like this which requires very good bed adhesion https://www.youtube.com/watch?v=vG1WqijJ634
                            • snoozerundefined
                              snoozer @deckingman
                              @deckingman
                              Oh that's very nice. Did you machine your bed yourself or did you use Weerg or such ? I have never printed on glass, on the Prusa I can't try it cause it has an inductive probe and I don't want to start ripping things apart to do manual bed leveling. I will add that to my list to things to check out for the cost of getting a decent strong print bed machined. A continuous belt on the Z would not bother me to much. As long as the absolute position is correct after the move any flex should not matter. A three point mounting is understandably the best if the structure does allow for it.
                              I check that out regarding a custom print bed......
                              Jan
                              Regards Jan
                              My Printers:
                              My Experiments:
                                deckingman @snoozer
                                @snoozer
                                I bought aluminium tooling plate cut to size from a UK supplier.
                                Personally I like printing on glass. Others hate the idea - mostly people who have never tried it.☺ But it doesn't have to be glass. What I like most is the ability to quickly remove one piece at the end of a print, slide in another piece and resume the next print quickly. Any removable build surface would do as long as it's flat. Glass happens to fit the bill, being relatively cheap but flat and 6mm thick is surprisingly difficult to break. I have 3 pieces and of course, you can use PEI, or 3D Lac or blue painters tape on each one and swap between them.
                                One word of caution - do not be tempted to have the glass toughened. The toughening process will distort it so stick with plain float glass. That was a lesson I learned the hard way. ☺
                                Edit. I did sort of machine the plate. But only drilling the fixing holes and then counter sinking them. It did it all with a hand held power drill - nothing special. Initially, I did mill a slot using a wood working router, on the underside of the plate to take the thermistor but later abandoned that in idea in favour of drilling a hole in the side.
                                • snoozerundefined
                                  snoozer @deckingman
                                  @deckingman
                                  I have flicked through some of your YT videos. Man what a machine !!!! The dynamic counter weight is absolutely stunningly well done and is works so well.
                                  I am beginning to seriously consider a chunky aluminium plate with adhesive silicone heater mat. I'd still go for main 230V powered cause i hate low voltage high current stuff, just does not sit well with me. I have just bough a reasonably decent but not to expensive router to be able to make the ends of the aluminum extrusions of the V-Core true and equal length assuming they are not machined properly. I suppose that could also work to cut a slot in the aluminium plate for the termistor and make it true and nice around the edge. I did a quick and non to elaborate aluminium plate in fusion 360 to upload to Weerg for a quote. It had 3 mounting slots 4.2 mm width and a slot to the middle for termistor. Weerg will not accept it for quoting cause the ratio of thickness to outside circumference on the 320x320x8mm plate is to much for them. I have the option for a manual quote but I leave that till I have a final design. The heater I have narrowed down to on a quick search is this:
                                  https://ie.rs-online.com/web/p/silicone-heater-mats/1065429/
                                  It is rated 150 degree c continuous operation and my experience with RS is 99% positive. I keep an open mind, once the V-Core kit arrives I have a better idea what may and may not work mechanically on that kit.
                                  Thanks for your suggestions and shared experience !!
                                  Jan
                                  PS: The quote from the Weerg website is
                                  "The morphology of the piece does not allow a safe realization.
                                  We do not execute objects whose perimeter exceeds100 times the height (now it's170.0 times).
                                  The reason is due to the fact that vibrations could reduce the workpiece precision during the machining process.
                                  Do you think the piece can be made?
                                  Do not hesitate to contact us, by clicking here."
                                  Regards Jan
                                  My Printers:
                                  My Experiments:
                                  deckingmanundefined 2 Replies Last reply Reply Quote 0
                                    deckingman @snoozer
                                    @snoozer That's a weird thing for Weerg to say IMO. The piece of tooling plate I bought is 400mm x 400mm which therefore has a perimeter of 1,600 mm. By their reckoning, it should be at least 16mm thick which I'd say is a bit crazy.
                                    Ref RS, yes I have an account with them. Yes they are good and delivery is fast but soooo expensive. 178 Euros !!. Suggest you shop around.
                                    Edit. Keenovo have a good reputation - worth checking them out https://www.keenovo.com/products/silicone-heater.html
                                    • snoozerundefined
                                      snoozer
                                      Uups..... just got quoted 515 EUR for the bed plate 320x320x8 with the milled slot for the termistor, 3 mounting slots 4.2x14 and rounded edges....... definitely NOT going for that. This was with Protolabs. I keep looking, there is no rush.
                                      Jan
                                      Regards Jan
                                      My Printers:
                                      My Experiments:
                                      • Vetiundefined
                                        Veti
                                        https://clever3d.de/epages/7a4290fc-7c7f-46cc-9b99-eadef22228e2.sf/de_DE/?ObjectPath=/Shops/7a4290fc-7c7f-46cc-9b99-eadef22228e2/Products/c3d-DP/SubProducts/c3d-DP-0039
                                        328x328x8 for 63,75 €
                                        • snoozerundefined
                                          snoozer @Veti
                                          @veti
                                          Oh wow, that looks promising !! I keep that on my link list for supplies. Thanks for sharing !!!
                                          Jan
                                          PS: Nice online shop, A lot of stuff I had spend days looking for and could not find. I never search in German on google, maybe that's why this never came up.
                                          Regards Jan
                                          My Printers:
                                          My Experiments:
                                          • Vetiundefined
                                            Veti
                                            the site says since they manufacture each plate individualy they can make it to your likeing. so 320x320x8 should also work
