    Handling error codes to switch off power using M81
    • jer1001undefined
      jer1001
      I am trying to understand if there are any settings to get the duet to switch off the 24V power supply using the M81 command. As far as I can see the heaters are turned off if it detects an issue, but it does not turn off the power supply. I can switch the power on and off no issues and this is handy at the end of printing. However I am not sure about how error messages can be arranged to power down the 24 volt power supply.
      Many thanks
      Jeremy
      • AndreSundefined
        AndreS
        I think it is not possible at the moment, but will be possible with the introduction of conditional execution of gcode in some of the next firmware releases.
        • jer1001undefined
          jer1001
          Hi Andre
          Thanks for your help, makes sense.
          Jeremy
